Same for me, I also found Peppyalsa.postPeppyalsa.11.conf.tmpl and not Peppyalsa.postPeppyalsa.5.conf.tmp.
regards /C
regards /C
Sorry, my mistake. I mean 11 not 5 ![]()
In my Volumio Peppy Meter not working on TouchDisplay 3.3.8. I tried few times and always TD need to be downgrade to 3.3.7. I tried with upgrade from 3.3.7 and from clean install with 3.3.8 at first.
Who else had this problem ??
@2aCD, if you plan to release a new version, move the skins to another place (skins only) e.g. /data/INTERNAL/Peppyscreen/Templates. There will be no questions: where to put the skins? It would also be good to include resolutions; custom 1920x515… 1480x320…1280x400… etc. Thank you.
Hey Gelo5, I have speak with peppy player about a configurable config entry to define a separate data folder. He will include it at weekend. Then I can change our integration to use the Internal folder.
For other custom resolutions I can generate empty folders to put the templates. Which resolutions do you need exactly?
1280x400
1480x320
1920x515
you go tiger ![]()
Only those popular among users: 1920x1080, 1920x515, 1920x480, 1280x800, 1280x400, 1480x320, 1024x600, 800x480,1600x720. There are such screens on the forum.
@balbuze solved it very nicely in Peppyspectrum
auto set screen size, can we use the name including size for the folder like:
800x480_collection
Only Custom 5 doesn’t work. Latest Volumio, latest Touch screen, latest Now playing and Peepy 1.3.0 works.
I have done many reinstalls and only Peppy 1.3.0 works for me. I’ve been working on it for two days and I’m already afraid to touch it.
I will try tomorrow.
I had the same problem. tried to uninstall touch display from UI and then tried to install td ver3.3.8. That didn’t work so I had to flash a new volumio 3.611and then install touch display 3.3.8. After that there was no problem to install peppy screensaver 1.3.8 and other plugins.
Best Regards/ C
Sorry, not all “hearts” are correct. I’m browsing the forum on my smartphone and while scrolling, I touch the “heart”.
Do not understand the question
1480x320 you place well (in 1920x1080)
What does it mean? Other resolutions work?
Here’s a test
Gelo5_1600x720.zip (2.9 MB)
Yes. I tried about three others and they worked. Of course with the wrong resolution. If I copy the 1480x320 files to custom5, it didn’t work.
Full story. In January, a new version of Volumio was released that guaranteed RPI5 functionality with Waveshare 1480x320. I did a fresh install plus Touch sreen, Now playing and Peppy 1.3.9. Everything worked and when testing the skins, I switched my Peppymeter random 600s to switch tracks to make notes of which skins to delete… Everything worked ok. Then after about a week the Volumio update came, so I turned off all the plugins, did the update and turned on the plugins. Everything worked ok again until I switched the Peppy random 600s to switch by track. Then Peppy didn’t work at all and two days of trying followed.
I’m using a translator so hopefully it will be understandable
You need to touch heart one more time and will disappear.
Yes. PM works till I install TD 3.3.8.
Now I trying third clean install on 3.3.8 without succes.
I probably stay with 3.3.7. For me only difference is that on 3.3.8 I need only rotate Waveshare, on 3.3.7 I need modify one command more.
Really, try it after an hour
Maybe not work, I do it immediately after a mistake.
Where do you copy them?
Thank you all, thanks to this forum I installed Volumio and Peppymeter without any problems.
