Problem when i change file format Flac to DSD
Hi everyone, I have a problem with x86 volumio version. When I switch from a Flac to a DSD a pink noise comes out and I am forced to stop playback and then restart it. Sometimes it works but not always. It is impossible to create a playlist with mixed files because it freezes and makes noise, what can I do?
http://logs.volumio.org/volumio/hgfZ0NX.html
Volumio Version: 3.779 for x86_64 (6.6.32-volumio x86_64)
Dell Optiplex FX160
volumio
    description: Computer
    width: 64 bits
    capabilities: smp vsyscall32
  *-core
       description: Motherboard
       physical id: 0
     *-memory
          description: System memory
          physical id: 0
     *-cpu
          product: Intel(R) Atom(TM) CPU  230   @ 1.60GHz
          vendor: Intel Corp.
          physical id: 1
          bus info: cpu@0
          width: 64 bits
          capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx x86-64 constant_tsc arch_perfmon pebs bts nopl cpuid aperfmperf pni dtes64 monitor ds_cpl tm2 ssse3 cx16 xtpr pdcm movbe lahf_lm dtherm
     *-pci
          description: Host bridge
          product: 671MX
          vendor: Silicon Integrated Systems [SiS]
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 00
          width: 32 bits
          clock: 33MHz
          configuration: driver=agpgart-sis latency=32
          resources: irq:0 memory:f0000000-f7ffffff
        *-pci:0
             description: PCI bridge
             product: AGP Port (virtual PCI-to-PCI bridge)
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 00
             width: 32 bits
             clock: 66MHz
             capabilities: pci normal_decode bus_master
             resources: ioport:e000(size=4096) memory:fe900000-fe9fffff memory:d0000000-dfffffff
           *-display UNCLAIMED
                description: VGA compatible controller
                product: 771/671 PCIE VGA Display Adapter
                physical id: 0
                bus info: pci@0000:01:00.0
                version: 10
                width: 32 bits
                clock: 66MHz
                capabilities: vga_controller cap_list
                configuration: latency=0
                resources: memory:d0000000-dfffffff memory:fe9e0000-fe9fffff ioport:ec00(size=128) memory:c0000-dffff
        *-isa
             description: ISA bridge
             product: SiS968 [MuTIOL Media IO]
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 01
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master
        *-usb:0
             description: USB controller
             product: USB 1.1 Controller
             physical id: 3
             bus info: pci@0000:00:03.0
             version: 0f
             width: 32 bits
             clock: 33MHz
             capabilities: ohci bus_master
             configuration: driver=ohci-pci latency=32 maxlatency=80
             resources: irq:20 memory:fe8ff000-fe8fffff
        *-usb:1
             physical id: 3.1
             bus info: pci@0000:00:03.1
             version: 0f
             width: 32 bits
             clock: 33MHz
             resources: irq:21 memory:fe8fe000-fe8fefff
        *-usb:2
             product: USB 2.0 Controller
             physical id: 3.3
             bus info: pci@0000:00:03.3
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: ehci bus_master cap_list
             configuration: driver=ehci-pci latency=32 maxlatency=80
             resources: irq:22 memory:fe8fd000-fe8fdfff
        *-sata
             description: SATA controller
             product: AHCI IDE Controller (0106)
             physical id: 5
             bus info: pci@0000:00:05.0
             version: 03
             width: 32 bits
             clock: 33MHz
             capabilities: sata ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=128
             resources: irq:17 ioport:dc00(size=8) ioport:d800(size=4) ioport:d400(size=8) ioport:d000(size=4) ioport:cc00(size=32) memory:fe8fcc00-fe8fcdff
        *-pci:1
             product: PCI-to-PCI bridge
             physical id: 6
             bus info: pci@0000:00:06.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pci normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:0 memory:fea00000-feafffff
           *-network
                description: Ethernet interface
                product: NetXtreme BCM5764M Gigabit Ethernet PCIe
                vendor: Broadcom Limited
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: eth0
                version: 10
                serial: b8:ac:6f:b7:c2:ee
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=6.6.32-volumio firmware=5764m-v3.35 latency=0 link=no multicast=yes port=twisted pair
                resources: irq:16 memory:feaf0000-feafffff
        *-pci:2
             physical id: 7
             bus info: pci@0000:00:07.0
             version: 00
             width: 32 bits
             clock: 33MHz
             resources: irq:0 memory:feb00000-febfffff
           *-network
                description: Wireless interface
                product: RT3290 Wireless 802.11n 1T/1R PCIe
                vendor: Ralink corp.
                physical id: 0
                bus info: pci@0000:03:00.0
                logical name: wlan0
                version: 00
                serial: 48:5a:b6:5b:bd:37
                width: 32 bits
                clock: 33MHz
                capabilities: bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=rt2800pci driverversion=6.6.32-volumio firmware=0.37 ip=192.168.1.109 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                resources: irq:16 memory:febf0000-febfffff
           *-generic UNCLAIMED
                description: Bluetooth
                product: RT3290 Bluetooth
                physical id: 0.1
                bus info: pci@0000:03:00.1
                version: 00
                width: 32 bits
                clock: 33MHz
                resources: memory:febe0000-febeffff
     *-pnp00:00
          product: PnP device PNP0c02
          physical id: 2
          capabilities: pnp
          configuration: driver=system
     *-pnp00:01
          product: PnP device PNP0b00
          physical id: 3
          capabilities: pnp
          configuration: driver=rtc_cmos
     *-pnp00:02
          physical id: 4
          capabilities: pnp
     *-pnp00:03
          physical id: 5
          capabilities: pnp
     *-pnp00:04
          physical id: 6
          capabilities: pnp
     *-pnp00:05
          product: PnP device PNP0c01
          physical id: 7
          capabilities: pnp
Sorry I couldn’t find it on your log - what DAC are you using for playback?
You get noise with DSD if the volume is less than max.
Dac is integrated in my amplifier, volumio report this model: SXW CTUAD768 PRM-A
in setting volume is on max value.
This section is my Dac
Bus 001 Device 002: ID 2fc6:f801
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x2fc6
  idProduct          0xf801
  bcdDevice            2.01
  iManufacturer           1
  iProduct                2
  iSerial                 3
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x021d
    bNumInterfaces          3
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      bFunctionProtocol      32
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      bInterfaceProtocol     32
      iInterface              2
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               2.00
        bCategory               4
        wTotalLength       0x0065
        bmControls           0x00
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     10 (CLOCK_SOURCE)
        bClockID                5
        bmAttributes            3 Internal programmable clock
        bmControls           0x07
          Clock Frequency Control (read/write)
          Clock Validity Control (read-only)
        bAssocTerminal          0
        iClockSource            0
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bCSourceID              5
        bNrChannels             2
        bmChannelConfig    0x00000003
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bmControls         0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                 3
        bSourceID               1
        bmaControls(0)     0x0000000f
          Mute Control (read/write)
          Volume Control (read/write)
        bmaControls(1)     0x0000000c
        bmaControls(2)     0x0000000c
        iFeature                0
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             4
        wTerminalType      0x0301 Speaker
        bAssocTerminal          0
        bSourceID               3
        bCSourceID              5
        bmControls         0x0000
        iTerminal               0
        bLength                 8
        bDescriptorType        36
        bClockID               15
        bmControls           0x07
        bAssocTerminal          0
        iClockSource            0
        bLength                17
        bDescriptorType        36
        bTerminalID            10
        wTerminalType      0x0603 Line Connector
        bAssocTerminal          0
        bCSourceID             15
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bmControls         0x0000
        iTerminal               0
        bLength                12
        bDescriptorType        36
        bTerminalID            13
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             15
        bmControls         0x0000
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
      AudioStreaming Interface Descriptor:
        bLength                16
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           1
        bmControls           0x05
          Active Alternate Setting Control (read-only)
          Valid Alternate Setting Control (read-only)
        bFormatType             1
        bmFormats          0x00000001
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bSubslotSize            2
        bBitResolution         16
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x0308  1x 776 bytes
        bInterval               1
        AudioStreaming Endpoint Descriptor:
          bLength                 8
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bmControls           0x00
          bLockDelayUnits         0 Undefined
          wLockDelay         0x0000
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink           1
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink           1
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           2
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink           1
        bmControls           0x05
        bFormatType             1
        bmFormats          0x80000000
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              5
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink          13
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink          13
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLengthCouldn't open device, some information will be missing
                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink          13
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       4
      bNumEndpoints           1
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink          13
        bmControls           0x05
        bFormatType             1
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
I think is the same problem in this page:
Hi.
Ok, so your amp is an Emotiova XDA-3, which has an ESS ES9038Q2M SABRE DAC and uses a ComTrue CT7601 chip interface (SXW CTUAD768 PRM-A according to the manual (Xda-3 Rear Panel - Emotiva Differential Reference XDA-3 User Manual [Page 15] | ManualsLib).
From the link you provided (Volumio + Emotiva XDA-3 no native DSD (DSD via DoP only)) , it looks like you’ve already identified where the issue is, which seems to be in the firmware implementation on Emotiva’s side.
It is not a dac chip issue - I’ve run the same chip in native I2S hats and XMOS chips with no issue when playing native DSD or DSD over PCM. And the same with the ESS9039Q2M. Hopefully they get around to fix this soon!
This is an oversimplification.
The problem is that @mastri81 has the same issue as me, and he doesn’t have an Emotiva XDA-3.
He has a third-party amplifier with a built-in DAC based on SABRE’s ESS ES9038 and ComTrue CT7601 USB interface, which is analogous to Emotiva. It certainly does not use Emotiva firmware.
It is therefore possible to conclude that the trouble lies in Volumio’s (actually Linux) inadequate interaction with DACs based on the ESS ES9038 SABRE and ComTrue CT7601 USB interface in general.
The problem was signalled by me and seemed to apply only to Emotiva particular case, but as you can see it is a wider issue and as yet unsolved.
Guys trust me, the issue is related to the CT7601 firmware or in the register settings applied to the ES9038 DAC.
I have here on my desk this very same combination, with both CT7601 firmware and ES9038 registers developed and fine-tuned by myself. I have absolutely no problems with DSD playback and DSD ↔ PCM switch, with default Volumio settings.
I can also confirm no issues with the ES9038Q2M in other implementations using both native i2s interfaces and XMOS chips on my end, so everything does seem to point to this being a specific issue with the ComTrue CT601 / ES9038Q2M implementation cited.
Hi Darmur,
I am 101% convinced that you know what you are saying and that you have checked it out.
The question is different, how can regular users of these DACs like @mastri81 and myself deal with this?
What do we need to do to make it work well?
Please instruct us on what to do and how to do it, if that is possible of course.
starwars-sos
Yes, I have also checked other DACs with XMOS. Everything worked without a problem.
My previous DAC DA-400 - TAGA Harmony was on XMOS.
the most obvious solution is to contact the manufacturer of the DAC, explaining the problem in details and asking for a fix with a firmware update.
I agree that it seems to be a specific issue affecting devices that use certain Comtrue USB interface chips. However apparently those devices work normally with other sources.
To me this suggests that the source is “recognizing that it is talking to a Comtrue chip rather than some other specific chip or an unknown generic UAC2 device” and then implementing some sort of extra actions. To me this points to some “special handling” that is being done at the Linux kernel driver level only when it detects a Comtrue chip in the receiving device - and that, in this case, has undesirable results. (And the solution would be to have the option to disable this “special behavior” in the Linux internal driver.)
Incidentally, I work for Emotiva, and I can tell you that the XDA-3 was originally tested successfully with both DoP and “native DSD” - using Foobar2000 in Windows 10 - with no such issues noted.
Hi, and thanks for chiming in - I appreciate the fast response times and dedication at Emotiva! Part of the issue here is that there appear to be devices or set-ups running the same ComTrue + ESS ES9038Q2M configuration that are working correctly. And, out of curiosity regarding device compatibility, would it help to test the device with macOS, iOS, Linux, and Android as well?
On Android 14 whit Neutron Player no issue.
On PiCore player, MoOde and Audirvana linux core - problems.
BlueOS (Bluesound Node n130) - as well.
Thanks for this! I wonder what the device is using - ALSA, OSS, or something custom (by the Neutron engine).
Interesting - maybe BluOS is also using ALSA?
I don’t exactly disagree with you… The problem is that there are a lot of different Linux distributions - and each does or may act differently in different ways. So testing a product with one Linux distro provides little assurance of how it will act with others. And, for that matter, there are a lot of products that simply use proprietary distros or hardware altogether. Emotiva is primarily an audio company - so the USB interface part of the XDA-3 was developed for us by an outside engineering team. When we received the prototype, we tested it with both Windows and Apple devices, as well as with a few Android devices, and it worked fine with all of them. It is also, as far as we are able to determine, compliant with the USB Audio Class 2 standard.
In this case it appears as if the issues some people are experiencing with some devices are due to certain Linux-based devices accessing certain features or capabilities of the Comtrue chip which we don’t use… and which extend beyond the standard. Likewise, we process DoP packets as per the standard… so we assume that the drivers inside a particular Linux distro are encapsulating the DSD audio into “standard DoP packets”… and we handle those as per the standard as well. Unfortunately we lack the resources to test each of our products with every other product out there… or to work with individual vendors to optimize our products to work with theirs… so we follow the standards and assume that other products do as well. (And we offer a return period to protect customers against the unlikely situation where one of our products has any sort of “compatibility issues” with other products in their system.)
As it turns out we are in the final stages of releasing a new streamer product, which we developed in conjunction with Volumio, and which runs the Volumio operating system. Our new streamer has its own internal high-quality DACs, so I doubt many folks will be using it with an XDA-3, but we will test how well they work together, and report the results.
(You will usually find discussions about Emotiva products, including the XDA-3, in the Emotiva Forums… and, since we’re developing the new streamer with Volumio, probably here as well. )
