[PLUGIN] Touch Display
Hello, can you help me with this? I couldn’t still fix this,
I reformat my 32gb sdcard as fat32 using raspberry pi imager. And write the latest volumio.
-Insert the sd card on raspberry pi 4b and boot.
-ssh to configure user:volumio pass:volumio.
-Configure webui.
-on userconfig.txt comment out parameters
  • then on a terminal i do this :Date Time issues rPi4 - #73 by Wheaten
  • double check date/time
    -install plug in touch display. (success then enable)
    -plug hdmi&powercord display to rpi.
    -turn on the backlight
    -on the terminal sudo reboot.
It shows black screen.
Doesn’t your post above show the display working?
Is the display connected to the HDMI port next to the USB-C port of your Pi 4?
What does that mean in concrete terms?
What is the output of
cat /boot/userconfig.txt
Hi gvolt,
I’m here to ask for help,
I’m having a hard time to setup my 7 inch touch screen,
First, I’m done with this Prepare Raspberry Pi for boot from USB/NVMe and successfully boot from usb/ssd using prototype volumio image.
On my webui i am successfully installed the plugin touch display however i couldn’t control or can’t even touch my screen.
I am currently using raspberry pi 4 model b 2gb ram, and my display hdmi and power are connected to raspberry pi. Another problem is i can’t play spotify cause it’s says "failed to open alsa.
Please connected to Volumio via SSH, execute
ls -al /dev/input
and post the output.
Also post the output of
cat /var/log/Xorg.0.log
You might open a dedicated thread for this problem to get some attention or post the issue in an already existing spotify related thread.
P.S. Regarding the touch function problem: Did you already try another USB cable?
Thanks gvolt! I changed the usb cord and i can control the touchscreen however, i don’t know what’s the problem with my spotify it seems it can’t access properly can’t even play or load to a main screen. Here’s the video : https://drive.google.com/file/d/1p9qV9YgHzdrlPJ0gBKXbR3uH3HZdurk7/view?usp=drivesdk
And webradio said failed to open alsa.
login as:
volumio volumio@[192.168.100.119](https://l.facebook.com/l.php?u=http%3A%2F%2F192.168.100.119%2F%3Ffbclid%3DIwAR193ONqOH1KndGWihjTLD0182kUo9gQinduqNafeEav7yEVBDNQ3Y8mso8_aem_AajhD_5B5IFJSFhFmOVXyKEc9znDDyh9qhb79OUpWtPxXNaviIzGDd-PSRU9MOkgRdQt7QxsRZJEdTB6RWZ_4JSD&h=AT2SgYxo2GkAS0702369tgN_Ey7MWWVo0pLJMsoujaF-lalXOJ5zXTat5EJHTCQjqA5M9uujIykiA6uo7Mob2qX8WpBv1Eu_MQicAS_4PNuOz2C7CSUgPc65KRCixP62cWCQ7g)'s password: *_* /\_ \ __ *_ _* *__\//\ \ _* *_ __ _* /\_\ *_* /\ \/\ \ / __`\\ \ \  /\ \/\ \ /' __` __`\/\ \ / __`\ \ \ \_/ |/\ \L\ \\_\ \_\ \ \_\ \/\ \/\ \/\ \ \ \/\ \L\ \ \ \___/ \ \____//\____\\ \____/\ \_\ \_\ \_\ \_\ \____/ \/__/ \/___/ \/____/ \/___/ \/_/\/_/\/_/\/_/\/___/ Free Audiophile Linux Music Player - Version 3.0 © 2015-2021 Michelangelo Guarise - Volumio Team - Volumio.org Volumio Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Welcome to Volumio for Raspberry Pi (6.1.69-v7l+ armv7l) volumio@volumio:~$ ls -al /dev/input total 0 drwxr-xr-x 4 root root 140 Apr 3 13:27 . drwxr-xr-x 16 root root 3820 Apr 3 13:27 .. drwxr-xr-x 2 root root 60 Apr 3 13:27 by-id drwxr-xr-x 2 root root 60 Apr 3 13:27 by-path crw-rw---- 1 root input 13, 64 Apr 3 13:27 event0 crw-rw---- 1 root input 13, 63 Apr 3 13:27 mice crw-rw---- 1 root input 13, 32 Apr 3 13:27 mouse0 volumio@volumio:~$
volumio@volumio:~$ cat /var/log/Xorg.0.log [ 45.318] X.Org X Server 1.20.4 X Protocol Version 11, Revision 0 [ 45.318] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian [ 45.318] Current Operating System: Linux volumio 6.1.69-v7l+ #1710 SMP Thu Dec 21 13:17:38 GMT 2023 armv7l [ 45.318] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:01:41:E4 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=UUID=953e0832-2d16-41f6-b22e-c097902dd0c1 imgfile=/volumio_current.sqsh bootpart=UUID=9AB2-0FD6 datapart=UUID=2d601a02-cd85-4e6c-99b8-18f8950b09a6 bootconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0 [ 45.318] Build Date: 04 April 2023 07:50:56AM [ 45.318] xorg-server 2:1.20.4-1+rpt4+deb10u9 ([https://www.debian.org/support](https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.debian.org%2Fsupport%3Ffbclid%3DIwAR1QO9ifOs72_H1N-xQ7gyqsoND5ZBjUbvnC_2KqLEadUkWHJD2PyxIDEVI_aem_AaiGUg-sfVOJgaPlHKRJq7W9OHMUZjXbsG9CvBY5Cj69_KIAzICFdsdCQLsy8zjNtMahK5C9b0-xWGw0zQoQy4iN&h=AT2SgYxo2GkAS0702369tgN_Ey7MWWVo0pLJMsoujaF-lalXOJ5zXTat5EJHTCQjqA5M9uujIykiA6uo7Mob2qX8WpBv1Eu_MQicAS_4PNuOz2C7CSUgPc65KRCixP62cWCQ7g)) [ 45.318] Current version of pixman: 0.36.0 [ 45.318] Before reporting problems, check [http://wiki.x.org](https://l.facebook.com/l.php?u=http%3A%2F%2Fwiki.x.org%2F%3Ffbclid%3DIwAR3GBqk7Ce3A3tBDyCQ-wz536vteah_4u-8_ZM7NlTWT9BA4J4gpR5-WQNk_aem_Aaj75UXk6fV7fLUhrA7CyKpV6jzCwJH9QG2_kJ5Hfv-kWlhCSbC8aAHQNfEXjFKKePzp1uW9vwYzHUwtcyMojK98&h=AT2SgYxo2GkAS0702369tgN_Ey7MWWVo0pLJMsoujaF-lalXOJ5zXTat5EJHTCQjqA5M9uujIykiA6uo7Mob2qX8WpBv1Eu_MQicAS_4PNuOz2C7CSUgPc65KRCixP62cWCQ7g) to make sure that you have the latest version. [ 45.318] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 45.319] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Apr 3 13:27:36 2024 [ 45.352] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 45.352] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 45.387] (==) No Layout section. Using the first Screen section. [ 45.387] (==) No screen section available. Using defaults. [ 45.387] (**) |-->Screen "Default Screen Section" (0) [ 45.387] (**) | |-->Monitor "<default monitor>" [ 45.388] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 45.388] (==) Automatically adding devices [ 45.388] (==) Automatically enabling devices [ 45.388] (==) Automatically adding GPU devices [ 45.392] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 45.397] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 45.397] Entry deleted from font path. [ 45.404] (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 45.404] (==) ModulePath set to "/usr/lib/xorg/modules" [ 45.404] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 45.404] (II) Loader magic: 0x1fdf80 [ 45.404] (II) Module ABI versions: [ 45.404] X.Org ANSI C Emulation: 0.4 [ 45.404] X.Org Video Driver: 24.0 [ 45.404] X.Org XInput driver : 24.1 [ 45.404] X.Org Server Extension : 10.0 [ 45.405] (--) using VT number 2 [ 45.405] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 45.406] (II) no primary bus or device found [ 45.407] (II) LoadModule: "glx" [ 45.412] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 45.458] (II) Module glx: vendor="X.Org Foundation" [ 45.458] compiled for 1.20.4, module version = 1.0.0 [ 45.458] ABI class: X.Org Server Extension, version 10.0 [ 45.458] (==) Matched modesetting as autoconfigured driver 0 [ 45.458] (==) Matched fbdev as autoconfigured driver 1 [ 45.458] (==) Assigned the driver to the xf86ConfigLayout [ 45.458] (II) LoadModule: "modesetting" [ 45.460] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 45.469] (II) Module modesetting: vendor="X.Org Foundation" [ 45.469] compiled for 1.20.4, module version = 1.20.4 [ 45.469] Module class: X.Org Video Driver [ 45.469] ABI class: X.Org Video Driver, version 24.0 [ 45.469] (II) LoadModule: "fbdev" [ 45.469] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 45.477] (II) Module fbdev: vendor="X.Org Foundation" [ 45.477] compiled for 1.20.3, module version = 0.5.0 [ 45.477] Module class: X.Org Video Driver [ 45.477] ABI class: X.Org Video Driver, version 24.0 [ 45.477] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 45.477] (II) FBDEV: driver for framebuffer: fbdev [ 45.479] (WW) Falling back to old probe method for modesetting [ 45.479] (EE) open /dev/dri/card0: No such file or directory [ 45.479] (WW) Falling back to old probe method for fbdev [ 45.479] (II) Loading sub module "fbdevhw" [ 45.479] (II) LoadModule: "fbdevhw" [ 45.479] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 45.481] (II) Module fbdevhw: vendor="X.Org Foundation" [ 45.481] compiled for 1.20.4, module version = 0.0.2 [ 45.481] ABI class: X.Org Video Driver, version 24.0 [ 45.481] (II) FBDEV(0): using default device [ 45.481] (II) FBDEV(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 45.481] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32 [ 45.481] (==) FBDEV(0): RGB weight 888 [ 45.481] (==) FBDEV(0): Default visual is TrueColor [ 45.481] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0) [ 45.481] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 1500kB) [ 45.481] (DB) xf86MergeOutputClassOptions unsupported bus type 0 [ 45.481] (II) FBDEV(0): checking modes against framebuffer device... [ 45.481] (II) FBDEV(0): checking modes against monitor... [ 45.481] (II) FBDEV(0): Virtual size is 800x480 (pitch 800) [ 45.481] (**) FBDEV(0): Built-in mode "current" [ 45.481] (==) FBDEV(0): DPI set to (96, 96) [ 45.481] (II) Loading sub module "fb" [ 45.481] (II) LoadModule: "fb" [ 45.481] (II) Loading /usr/lib/xorg/modules/libfb.so [ 45.485] (II) Module fb: vendor="X.Org Foundation" [ 45.485] compiled for 1.20.4, module version = 1.0.0 [ 45.485] ABI class: X.Org ANSI C Emulation, version 0.4 [ 45.485] (**) FBDEV(0): using shadow framebuffer [ 45.485] (II) Loading sub module "shadow" [ 45.485] (II) LoadModule: "shadow" [ 45.485] (II) Loading /usr/lib/xorg/modules/libshadow.so [ 45.486] (II) Module shadow: vendor="X.Org Foundation" [ 45.486] compiled for 1.20.4, module version = 1.1.0 [ 45.486] ABI class: X.Org ANSI C Emulation, version 0.4 [ 45.486] (II) UnloadModule: "modesetting" [ 45.486] (II) Unloading modesetting [ 45.500] (==) FBDEV(0): Backing store enabled [ 45.506] (==) FBDEV(0): DPMS enabled [ 45.511] (II) Initializing extension Generic Event Extension [ 45.511] (II) Initializing extension SHAPE [ 45.512] (II) Initializing extension MIT-SHM [ 45.512] (II) Initializing extension XInputExtension [ 45.517] (II) Initializing extension XTEST [ 45.518] (II) Initializing extension BIG-REQUESTS [ 45.518] (II) Initializing extension SYNC [ 45.519] (II) Initializing extension XKEYBOARD [ 45.519] (II) Initializing extension XC-MISC [ 45.520] (II) Initializing extension SECURITY [ 45.521] (II) Initializing extension XFIXES [ 45.521] (II) Initializing extension RENDER [ 45.522] (II) Initializing extension RANDR [ 45.523] (II) Initializing extension COMPOSITE [ 45.523] (II) Initializing extension DAMAGE [ 45.524] (II) Initializing extension MIT-SCREEN-SAVER [ 45.525] (II) Initializing extension DOUBLE-BUFFER [ 45.525] (II) Initializing extension RECORD [ 45.526] (II) Initializing extension DPMS [ 45.526] (II) Initializing extension Present [ 45.527] (II) Initializing extension DRI3 [ 45.527] (II) Initializing extension X-Resource [ 45.527] (II) Initializing extension XVideo [ 45.528] (II) Initializing extension XVideo-MotionCompensation [ 45.528] (II) Initializing extension SELinux [ 45.528] (II) SELinux: Disabled on system [ 45.528] (II) Initializing extension GLX [ 45.529] (II) AIGLX: Screen 0 is not DRI2 capable [ 46.297] (II) IGLX: Loaded and initialized swrast [ 46.297] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 46.297] (II) Initializing extension XFree86-VidModeExtension [ 46.297] (II) Initializing extension XFree86-DGA [ 46.298] (II) Initializing extension XFree86-DRI [ 46.299] (II) Initializing extension DRI2 [ 46.467] (II) config/udev: Adding input device WaveShare WS170120 (/dev/input/event0) [ 46.467] (**) WaveShare WS170120: Applying InputClass "libinput touchscreen catchall" [ 46.467] (**) WaveShare WS170120: Applying InputClass "Touch rotation" [ 46.467] (II) LoadModule: "libinput" [ 46.467] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 46.486] (II) Module libinput: vendor="X.Org Foundation" [ 46.486] compiled for 1.20.3, module version = 0.28.2 [ 46.486] Module class: X.Org XInput Driver [ 46.486] ABI class: X.Org XInput driver, version 24.1 [ 46.486] (II) Using input driver 'libinput' for 'WaveShare WS170120' [ 46.486] (**) WaveShare WS170120: always reports core events [ 46.486] (**) Option "Device" "/dev/input/event0" [ 46.486] (**) Option "_source" "server/udev" [ 46.505] (II) event0 - WaveShare WS170120: is tagged by udev as: Touchscreen [ 46.507] (II) event0 - WaveShare WS170120: device is a touch device [ 46.507] (II) event0 - WaveShare WS170120: device removed [ 46.590] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:0EEF:0005.0001/input/input1/event0" [ 46.590] (II) XINPUT: Adding extended input device "WaveShare WS170120" (type: TOUCHSCREEN, id 6) [ 46.590] (**) Option "AccelerationScheme" "none" [ 46.590] (**) WaveShare WS170120: (accel) selected scheme none/0 [ 46.590] (**) WaveShare WS170120: (accel) acceleration factor: 2.000 [ 46.590] (**) WaveShare WS170120: (accel) acceleration threshold: 4 [ 46.600] (II) event0 - WaveShare WS170120: is tagged by udev as: Touchscreen [ 46.602] (II) event0 - WaveShare WS170120: device is a touch device [ 46.605] (II) config/udev: Adding input device WaveShare WS170120 (/dev/input/mouse0) [ 46.605] (II) No input driver specified, ignoring this device. [ 46.605] (II) This device may have been added with another device file. volumio@volumio:~$
Just a tip,
It would benefit if you elaborate a bit more, then just copy paste some errors, that you think are helpfull.
Like
  • Used hardware
  • Volumio version
  • Error description.
  • Complete log
ls -al /dev/input
hi gvolt here’s as you request.
regading in touch screen function i change the usb cord and it seems working
Thanks! But since the touch function has fortunately been working since the USB cable was changed, this was no longer necessary. :grinning:
Thanks gvolt, another question dev. I’m having a hard time to fix this and i don’t know what’s the real problem. The touch screen function is fine. however, i don’t if the spotify and webradio is compatible with the latest prototype volumio image.
Can you check this video. https://drive.google.com/file/d/1pFpY-JjTXFEp2CZdiCatI0E-EZ5aETA-/view?usp=drivesdk
Sorry, I can’t help with your spotify and webradio issues. Also, as suggested earlier, I recommend to open a dedicated thread for these issues since this thread is about the Touch Display plugin. :wink:
Ohh isee gvolt, thank you so much for your help.
Gvolt, can i ask? Where do i find the peppymeter screensaver link to download in this thread?
Nowhere in this thread (which is about the Touch Display plugin :wink:), but probably somewhere here.
Thanks gvolt! Another question can i? I don’t know how to enable the keyboard so i can type to log the google that spotify required or do i need to post on the spotify thread?
Take a look here:
Hi wheaten! It’s been a while.
I just want to ask you how to fix this, I’m having a hard time to install touch display plugin on raspberry pi 4 model b 2gb with a latest version 3.669. My internet is connected to router direct wire. And my internet speed is pretty good. I set test mode on.
After configuring the webui, i set my time-date and set the parameters also.
Then after installing the plugin this is showing on my laptop screen.
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/touch_display/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/touch_display/volumio/buster/armhf
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Hit:1 https://deb.nodesource.com/node_14.x buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Get:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Reading package lists...
Running apt-get update failed
Plugin failed to install!
Cleaning up...
Removing dependencies
Building dependency tree...
Reading state information...
Package 'chromium-browser' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Package 'openbox' is not installed, so not removed
Deleting /opt/volumiokiosk.sh
Deleting /data/volumiokiosk
Enabling login prompt
Done
Removing temporary directory /tmp/touch_display-ebaKpxi3Jj
you mention laptop display?
There is no need to install this plugin on a x86 device
@gvolt
Seems I need some help.
Running a waveshare 2.8Inch DSI IPS screen.
Wiki: Waveshare 2.8 inch, DSI, IPS
Added to userconfig.txt:
dtoverlay=vc4-kms-v3d
dtoverlay=vc4-kms-dsi-waveshare-panel,2_8_inch
display_lcd_rotate=1
display_hdmi_rotate=1
So far so good. Layout is rotated correct (90deg), but the touchscreen is acting weird.
The rotation of the touch orientation is correct, but I can only use it for about 70% of the screen width.
The area in the red box;
Installed xinput-calibrator, but the calibration is failing as I can’t calibrate the right part:
Any suggestion?
I haven’t had time to take a closer look, but it might be related to this issue.
