Why do you aways find something useful?
It seems this is the case indeed, need to look into this, where to modify this within Volumio.
Thanks!!
Thanks!!
it’s been fixed on kernel 6.6
you can download this file, rename it to “vc4-kms-dsi-waveshare-panel-fixed.dtbo” and place it on /boot/overlays
then you can use this fixed overlay changing the declaration in userconfig.txt
dtoverlay=vc4-kms-dsi-waveshare-panel-fixed,2_8_inch
Darn, love the community.
Dario is faster than I can read. Yeah I know that’s nothing new, he does it all the time…
But yes that fixed the stuff.
Thanks @gvolt for pointing me in the correct direction
Thanks @Darmur for giving the solution, faster than I could read the topic.
So… i have set my volumio unit to turn off screen after 2 hours of inactivity (via the touch screen plugin)
To wake it up again i just start playing a song, and after aprox. 10 seconds the display turns on again…
The problem is that after that the display doesn’t turn off again after 2 hours of inactivity but stays on for days or until i turn off or restarts my unit.
Ant fix for this or am i doing something wrong? =)
Please provide some more information:
1.Latest version volumio
2.Latest vetsion touch display
3.Display is 7.9" waveshare
4.Volumio running on Rpi4 with IQ audio pro dac
5. No, dont matter what time i set it to
Thx !
Instead of “latest” please give the concrete version numbers.
ad 1: 3.695?
ad 2: 3.4.0?
HDMI or DSI?
Volumio version 3.703
Touch Display version 3.40
Display is HDMI
But i had this problem with previous versions also !
Please post the output of
cat /boot/userconfig.txt
hdmi_group=2
hdmi_mode=87
hdmi_blanking=1
enable_uart=1
display_lcd_rotate=3
display_hdmi_rotate=3
Please check if the display still works if you substitute
hdmi_group=2
hdmi_mode=87
hdmi_blanking=1
with
dtoverlay=vc4-kms-v3d
and if the behaviour of the screensaver changes.
Nope still the same behaviour im afraid… plus, the image on the display is smaller than the display itself…
BUT… if i press the touch screen to start it up again it seems to work!! Just noticed =)
Strange have exact the same screen, just adding the settings from Waveshare does the trick for me.
max_usb_current=1
hdmi_group=2
hdmi_mode=87
display_rotate=3
The only thing that differs is that you have a “max usb current” but that shouldnt affect my problem i guess…
Just to be clear… this is only a problem when i wake my display up with my app on my phone (start playing music)
As i just found out, everything works fine if i wake it back up using my touch screen =)
I guess i have to get my ass out of my couch and walk the 3.5 meters to press my display
Does the same issue occur if you use a browser instead of the app to control Volumio?
Ooh, good question… i’ll give that a try !
You see, good music and a workout life is perfect
Nope… same issue using the browser !!
As @Weathen pointed out, it’s strange. I don’t have a Waveshare 7.9“ HDMI display, but with an original Raspberry Pi 7” DSI display the screensaver timeout works as expected, both when waking up the screen by touch and when starting playback from the (Android) app or from a browser.
P.S. Do you have other plugins enabled? Does the problem persist when only the Touch Display plugin is enabled?
