[PLUGIN] IR Remote Controller feedback thread
Hi Gvolt,
I use the Audiophonics Mini, not the Raspdac, and I already have installed a higher version of the img. Volumio. and use the DAC and mini board without the LCD of the mini, but want to use the remote
Thanks for your time
I didn’t find an ā€œAudiophonics Miniā€ without ā€œRaspdacā€. So, before we talk past each other: Do have you a link to the device?
oh sorry the its a raspdac mini
AUDIOPHONICS RASPDAC MINI LCD Kit DIY Streamer for Raspberry Pi 4 & DAC ES9038Q2M - Audiophonics.
where can i find this?
i use WINSCP
I guess this is still valid.
Using WinSCP alternatively to accessing Volumio’s Samba share ā€œInternal Storageā€ should also be possible. I am not familiar with WinSCP as I rarely use Windows, but you should be able to establish an SFTP connection from your PC to Volumio and copy the extracted folder ā€œAudiophonics RaspDAC Miniā€ to ā€œ/data/INTERNAL/ir_controller/configurationsā€ on your Volumio system. It’s probably just drag’n’drop.
if i open INTERNAL its empty
Did you already install the IR Controller plugin?
just drag and drop this two files
or the map
No, extract " Audiophonics RaspDAC Mini.zip". Then drag and drop the extracted folder ā€œAudiophonics RaspDAC Miniā€ (containing the two files ā€œlircd.confā€ and ā€œlircrcā€) into ā€œ/data/INTERNAL/ir_controller/configurationsā€ on your Volumio system.
P.S. Did you install the IR Controller plugin?
no i did not install the IR controller plugin, i do now
i have install the plugin i have drag and drop the extracted folder
i have install it select the mini what must I do with the GIO configuration
You need to select the GPIO number corresponding to the pin the IR receiver is connected to on the Pi.
how can i see that?
the ir has three pins
on the board GIO 04
GND
3V3
Could you post a picture?
