Perfect! Thanks a lot! Started to work!
I even have remaped buttons to commands
Hello! For some reason, my Volumio subscription became inactive and the ability to install plugins disappeared. I can install the IR remote plug-in myself, but I donāt have the configuration files for the Microsoft MCE RC6 remote. I would be grateful if someone could give me the lircd.conf and lircrc files for MCE RC6 1039.
I checked on the lirc database, but couldnāt find it, tge only Microsoft remotes there are the xbox ones.
Edit: this might help
Thank you very much! About 2 weeks ago, after reinstalling Volumio, for some reason my subscription became inactive and all plugins from the store disappeared. Before that, I installed the IR remote plugin in the āmanage pluginsā section on my device. And in the settings of the installed āIR remoteā plugin, it was possible to select the MCE USB profile, which worked fine. Now I have manually installed the āir_controller_3.4.7ā plugin from SSH, but unfortunately there is no MCE profile there.
with a free account, you access to all plugins in the store!
I have a registered free account in which my Volimio runs on Raspberry Pi Compute Module 4. But about 2 weeks ago, after a complete clean reinstallation of Volumio, my subscription became inactive in my account and the ability to install plugins from the store disappeared. I can install the plugin manually, but I do not have the lircd.conf and lircrc files for MCE RC6 1039.
Dear Forum members! I express my gratitude to you for your participation. I found the latest version of the IR Remote Controller plugin on my own (including what I needed) here:
Maybe it will be useful to someone in the future.
May I have some questions to this plugin.
I use this at an RP4 and it works fine with an Apple remote control. Now I installed Volumio at an RP5, same settings, same plugins and the only thing which does not work ist the remote control.
I am sure it is not a hardware problem. Changed the TSOP4838 back to the RP4 and it works.
Changed the TSOP from the RP4 to RP5 and it does not work. GPIO port 18, settings and the file which will be needed is all the same at both devices. Unfortunate I am not a SW guy.
I get some error message at the RP5 like:
Registered IR keymap rc-rc6-mce
[ 311.874621] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver@17/rc/rc0
[ 311.874768] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
[ 311.874998] input: gpio_ir_recv as /devices/platform/ir-receiver@17/rc/rc0/input2
[ 373.490306] OF: ERROR: memory leak, expected refcount 1 instead of 2, of_node_get()/of_node_put() unbalanced - destroy cset entry: attach overlay node /ir-receiver@17
[ 373.490548] OF: ERROR: memory leak before free overlay changeset, /ir-receiver@17
[ 373.546567] Registered IR keymap rc-rc6-mce
[ 373.546721] rc rc0: gpio_ir_recv as /devices/platform/ir-receiver@12/rc/rc0
[ 373.546883] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
[ 373.547106] input: gpio_ir_recv as /devices/platform/ir-receiver@12/rc/rc0/input3
May some of you have an idea?
Thank you for your help!
Having the same issue with an RPi3. It looks like the the /etc/lirc/lirc_options.conf isnāt actually getting updated. If I manually alter the config and add:
[modinit]
code = /sbin/modprobe meson-ir
Then the meson-ir module isnāt actually available. This seems to be what the plugin is trying to do anyway.
Jan 20 07:30:02 dining-room volumio[883]: info: CoreCommandRouter::executeOnPlugin: ir_controller , saveGpioOptions
Jan 20 07:30:02 dining-room sudo[10266]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay -r 0
Jan 20 07:30:02 dining-room sudo[10266]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 20 07:30:02 dining-room kernel: OF: ERROR: memory leak, expected refcount 1 instead of 2, of_node_get()/of_node_put() unbalanced - destroy cset entry: attach overlay node /ir-receiver@1a
Jan 20 07:30:02 dining-room kernel: OF: ERROR: memory leak before free overlay changeset, /ir-receiver@1a
Jan 20 07:30:02 dining-room sudo[10266]: pam_unix(sudo:session): session closed for user root
Jan 20 07:30:02 dining-room volumio[883]: info: ir_controller: Overlay gpio-ir gpio_pin=26 gpio_pull=up removed.
Jan 20 07:30:02 dining-room sudo[10282]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay gpio-ir gpio_pin=26 gpio_pull=down
Jan 20 07:30:02 dining-room sudo[10282]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 20 07:30:02 dining-room kernel: Registered IR keymap rc-rc6-mce
Jan 20 07:30:02 dining-room kernel: rc rc0: gpio_ir_recv as /devices/platform/ir-receiver@1a/rc/rc0
Jan 20 07:30:02 dining-room kernel: rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
Jan 20 07:30:02 dining-room kernel: input: gpio_ir_recv as /devices/platform/ir-receiver@1a/rc/rc0/input19
Jan 20 07:30:02 dining-room sudo[10282]: pam_unix(sudo:session): session closed for user root
Jan 20 07:30:02 dining-room volumio[883]: info: ir_controller: Overlay gpio-ir gpio_pin=26 gpio_pull=down loaded.
Jan 20 07:30:02 dining-room sudo[10294]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart lircd.service
Jan 20 07:30:02 dining-room sudo[10294]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 20 07:30:02 dining-room lircd[10156]: lircd-0.10.1[10156] Notice: caught signal
Jan 20 07:30:02 dining-room lircd-0.10.1[10156]: Notice: caught signal
Jan 20 07:30:02 dining-room systemd[1]: Stopping Flexible IR remote input/output application support...
Jan 20 07:30:02 dining-room systemd[1]: lircd.service: Main process exited, code=killed, status=15/TERM
Jan 20 07:30:02 dining-room systemd[1]: lircd.service: Succeeded.
Jan 20 07:30:02 dining-room systemd[1]: Stopped Flexible IR remote input/output application support.
Jan 20 07:30:02 dining-room systemd[1]: irexec.service: Succeeded.
Jan 20 07:30:02 dining-room systemd[1]: Starting lircd(8) initialization helper tool...
Jan 20 07:30:02 dining-room systemd-udevd[10274]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Jan 20 07:30:02 dining-room systemd-logind[554]: Watching system buttons on /dev/input/event0 (gpio_ir_recv)
Jan 20 07:30:03 dining-room lircd-setup[10297]: modprobe: FATAL: Module meson-ir not found in directory /lib/modules/6.1.58-v7+
Jan 20 07:30:03 dining-room lircd-setup[10297]: /usr/sbin/lircd-setup:37: DeprecationWarning: The SafeConfigParser class has been renamed to ConfigParser in Python 3.2. This alias will be removed in future versions. Use ConfigParser directly instead.
Jan 20 07:30:03 dining-room lircd-setup[10297]: parser = configparser.SafeConfigParser()
Jan 20 07:30:03 dining-room lircd-setup[10297]: Cannot execute: /bin/sh -c /sbin/modprobe meson-ir
Jan 20 07:30:03 dining-room lircd-setup[10297]: Command '['/bin/sh', '-c', '/sbin/modprobe meson-ir']' returned non-zero exit status 1.
Jan 20 07:30:03 dining-room systemd[1]: lircd-setup.service: Succeeded.
Jan 20 07:30:03 dining-room systemd[1]: Started lircd(8) initialization helper tool.
Jan 20 07:30:03 dining-room systemd[1]: Starting Flexible IR remote input/output application support...
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Info: lircd: Opening log, level: Info
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Version: lircd 0.10.1
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: System info: Linux dining-room 6.1.58-v7+ #1690 SMP Tue Oct 17 15:35:01 BST 2023 armv7l GNU/Linux
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Info: Initial device: /dev/lirc0
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: 'lirc' written to protocols file /sys/class/rc/rc0/protocols
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Info: [lirc] protocol is enabled
Jan 20 07:30:03 dining-room lircd[10305]: lircd-0.10.1[10305] Info: lircd: Opening log, level: Info
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: driver: default
Jan 20 07:30:03 dining-room lircd[10305]: lircd-0.10.1[10305] Warning: Running as root
Jan 20 07:30:03 dining-room lircd[10305]: lircd-0.10.1[10305] Info: Using remote: TEAC_RC-1091_TEAC_RC-957.
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: output: /var/run/lirc/lircd
Jan 20 07:30:03 dining-room lircd[10305]: lircd-0.10.1[10305] Notice: /etc/lirc/lircd.conf: TEAC_RC-1091_TEAC_RC-957: Multiple definitions of: KEY_SLEEP
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: nodaemon: 1
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: plugindir: /usr/lib/arm-linux-gnueabihf/lirc/plugins
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: logfile: syslog
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: immediate-init: 0
Jan 20 07:30:03 dining-room lircd[10305]: lircd-0.10.1[10305] Notice: lircd(default) ready, using /var/run/lirc/lircd
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: permission: 666
Jan 20 07:30:03 dining-room systemd[1]: Started Flexible IR remote input/output application support.
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: driver-options:
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: pidfile: /var/run/lirc/lircd.pid
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: listen: 0
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: connect: (null)
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: userelease: 0
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: effective_user: (null)
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: release_suffix: _EVUP
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: allow_simulate: 0
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: repeat_max: 600
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: configfile: /etc/lirc/lircd.conf
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Options: dynamic_codes: (null)
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Current driver: default
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Driver API version: 3
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Driver version: 0.10.0
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: Driver info: See file:///usr/share/doc/lirc/plugindocs/default.html
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Warning: Running as root
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Info: Using remote: TEAC_RC-1091_TEAC_RC-957.
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: /etc/lirc/lircd.conf: TEAC_RC-1091_TEAC_RC-957: Multiple definitions of: KEY_SLEEP
Jan 20 07:30:03 dining-room volumio[883]: info: ir_controller: systemctl restart lircd.service succeeded.
Jan 20 07:30:03 dining-room lircd-0.10.1[10305]: Notice: lircd(default) ready, using /var/run/lirc/lircd
The āmeson-irā is not the module to be used on a Pi but on certain Odroid devices.
Please post the output of
cat /etc/lirc/lirc_options.conf
when the file hasnāt been modified manually.
Also post the output of
journalctl --no-tail | grep ir_controller
journalctl --no-tail | grep gpio_ir
and
journalctl --no-tail | grep lirc
after the system has booted.
BTW: What is your Volumio version? Do you have other hardware connected?
Hi, iāve found the issue. Thereās no case for āpiā to update the /etc/lircs/lircs_options.conf file. The file never gets modified unless i manually do it. Iāve added the below and now the config file gets updated. However Iām no good with nodejs so I donāt know how to populate the variables for gpioInPin and activeLow. They donāt seem to be used anywhere when writing the config, so unsure how itās supposed to work with gpio on the pi?
data = data.replace(new RegExp('^#? *driver *=.*$', 'm'), 'driver = default')
.replace(new RegExp('^#? *device *=.*$', 'm'), 'device = /dev/lirc0');
switch (device) {
case 'odroidc1':
case 'odroidc2':
case 'odroidc4':
case 'odroidn2':
data = data.replace(new RegExp('^#? *\\[modinit]$', 'm'), '[modinit]')
.replace(new RegExp('^#? *code *=.*$', 'm'), 'code = /sbin/modprobe meson-ir');
break;
case 'pi':
.replace(new RegExp('^#? *code *=.*$', 'm'), '/sbin/modprobe gpio-ir-recv gpio_nr=' + gpioInPin + ' active_low=' + activeLow);
Thatās intentional (i did write the code). The file should not (needed to be) modified for Pi - at least it wasnāt necessary in the past.
Please post the logs and information I requested.
Thanks @gvolt . Iāve resolved this now by adding the overlay config to /boot/userconfig.txt and reverting the manual change to lircd_options.conf. Iāve actually got 2x IR sensors (one built into the DAC and an external one), so added the following to get 2x lirc devices.
dtoverlay=gpio-ir,gpio_pin=25
dtoverlay=gpio-ir,gpio_pin=6
Oh, I see. The plugin is not designed for the configuration of two IR receivers.
@domb84 @gvolt - ok - then it may work to use 2 diodes and connect the 2 receivers to 1 GPIO port
receiver1 output -------->|āāāā
receiver2 output -------->|-------ā“-------GPIO port
I only use 1. Maybe thereās some documentation Iāve missed around adding the config to the userconfig.txt file. That was my missing piece. Changing the order of the overlay means I can switch round lirc0 and lirc1 so the device I need working is at lirc0.
Hi, regarding my error I did try a few things, but so far it does not work. I am using an Apple A1294 remote control. At the RP4, same settings, same IR receiver, everything works fine.
These are the default options to lircd, if installed as
/etc/lirc/lirc_options.conf. See the lircd(8) and lircmd(8)
manpages for info on the different options.
Some tools including mode2 and irw uses values such as
driver, device, plugindir and loglevel as fallback values
in not defined elsewhere.
[lircd]
nodaemon = False
driver = default
device = /dev/lirc0
output = /var/run/lirc/lircd
pidfile = /var/run/lirc/lircd.pid
plugindir = /usr/lib/arm-linux-gnueabihf/lirc/plugins
permission = 666
allow-simulate = No
repeat-max = 600
#effective-user =
#listen = [address:]port
#connect = host[:port]
#loglevel = 6
#release = true
#release_suffix = _EVUP
#logfile = ā¦
#driver-options = ā¦
[lircmd]
uinput = False
nodaemon = False
[modinit]
code = /usr/sbin/modprobe lirc_serial
code1 = /usr/bin/setfacl -m g:lirc:rw /dev/uinput
code2 = ā¦
[lircd-uinput]
add-release-events = False
release-timeout = 200
release-suffix = _EVUP
Jan 21 11:49:57 volumio-hifi volumio[1054]: info: Loading plugin āir_controllerāā¦
Jan 21 11:49:57 volumio-hifi volumio[1054]: info: Applying required configuration parameters for plugin ir_controller
Jan 21 11:49:58 volumio-hifi volumio[1054]: info: ir_controller: File permissions successfully set on /etc/lirc/*.
Jan 21 11:49:58 volumio-hifi volumio[1054]: error: ir_controller: Error copying configurations: Error: Missing ālircrcā and / or ālircd.confā files.
Jan 21 11:49:58 volumio-hifi volumio[1054]: info: ir_controller: HAT already loaded /proc/device-tree/ir_receiver!
Jan 21 11:49:36 volumio-hifi kernel: rc rc0: gpio_ir_recv as /devices/platform/ir-receiver@12/rc/rc0
Jan 21 11:49:36 volumio-hifi kernel: rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
Jan 21 11:49:36 volumio-hifi kernel: input: gpio_ir_recv as /devices/platform/ir-receiver@12/rc/rc0/input0
Jan 21 11:49:37 volumio-hifi systemd-logind[639]: Watching system buttons on /dev/input/event0 (gpio_ir_recv)
Jan 21 11:49:37 volumio-hifi systemd[1]: Listening on lircd.socket.
Jan 21 11:49:58 volumio-hifi sudo[1231]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod -R a+rwX /etc/lirc/irexec.lircrc /etc/lirc/lirc_options.conf /etc/lirc/lircd.conf /etc/lirc/lircd.conf.d /etc/lirc/lircmd.conf /etc/lirc/lircrc
dtoverlay=gpio-ir
If all works as intended there shoud be no need to modify ā/boot/userconfig.txtā but the necessary overlay should be loaded on the pluginās start.
If this should still not work (i.e. with no manually added overlay to ā/boot/userconfig.txtā) I can only ask again to provide the information requested in post #372.
@Heuboda Please post the output of
ls -al /data/plugins/system_hardware/ir_controller/configurations/
