Same here
works like a charm
I love this pluggin, but I been trying to install this plugin in volumio 3 and i’m getting some errors; Tried via WebUI and SSH, same result:
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/ir_controller/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/ir_controller/volumio/buster/armhf
Creando ubicación de instalación
Desempaquetado del complemento
Comprobando complemento duplicado
Copiando el complemento a la ubicación
Instalación de las utilidades necesarias
Installing LIRC
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
gir1.2-atk-1.0 gir1.2-freedesktop gir1.2-gtk-3.0 gir1.2-pango-1.0
gir1.2-vte-2.91 libftdi1-2 liblirc-client0 liblirc0 libusb-0.1-4
libvte-2.91-0 libvte-2.91-common libyaml-0-2 python3-yaml
Suggested packages:
lirc-compat-remotes lirc-drv-irman lirc-doc lirc-x setserial ir-keytable
The following NEW packages will be installed:
libvte-2.91-0 libvte-2.91-common libyaml-0-2 lirc python3-yaml
0 upgraded, 14 newly installed, 0 to remove and 15 not upgraded.
Need to get 0 B/2987 kB of archives.
After this operation, 6958 kB of additional disk space will be used.
Selecting previously unselected package gir1.2-atk-1.0:armhf.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% dpkg: unrecoverable fatal error, aborting:
files list file for package 'makedev' is missing final newline
Installation of lirc failed
Plugin failed to install!
Cleaning up...
Removing dependencies
Package 'lirc' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
Removing folder for custom LIRC configurations
Done
Removing plugin directory /data/plugins/system_hardware/ir_controller
Se produjo un error al instalar el complemento Error
How can i solve this? Thanks in advance!
I just installed the plugin without problems. In your case, for whatever reason, the file “/var/lib/dpkg/info/makedev.list” seems to be “damaged” in that it is missing a final newline.
On your own risk you could try the following:
Execute
sudo sh -c 'echo >> /var/lib/dpkg/info/makedev.list'in order to append a new line to “/var/lib/dpkg/info/makedev.list”.
Install the plugin from the plugin store.
I have about the same problem. first, i went over here to the GPIO configurations
Ihave a JustBoom IR Remote and set the IR Remote configuration to the JustBoom IR Remote and scrolled on down to GPIO configuration and set the GPIO to 24.
and connected the Jumper wires to 3.3v/ GPIO24/ Ground.
I connected the other end of the wires to to the IR sensor Modular
- Ground/ middle VCC or power/ s Single out.
So i have the wires to their right pin
ground to ground
VCC to 3.3v
S to gpio24.
I reboot the player SmartiPi Touch 2
and took the JustBoom remote to my hand and started pressing buttons, nothing happen.
Do i need to use the terminal window to enable the GPIO24
Good evening. please help with the installation of Lirc. I have an old macmini that I have been using as a player for a long time. I want to set up work with the remote control onkyo-rc-799m, but for some reason I do not work according to this instruction
lsusb
Bus 001 Device 002: ID 0b05:17f5 ASUSTek Computer, Inc.
Bus 005 Device 003: ID 05ac:8240 Apple, Inc. Built-in IR Receiver
Bus 005 Device 004: ID 05ac:8205 Apple, Inc. Bluetooth HCI
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 0c40:7a1c
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
volumio@volumio:~$ ls -l /dev/usb/
total 0
crw------- 1 root root 180, 0 Oct 16 15:10 hiddev0
volumio@volumio:~$ sudo apt-get install lirc
Reading package lists... Done
Reading state information... Done
gir1.2-atk-1.0 gir1.2-freedesktop gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0
gir1.2-pango-1.0 gir1.2-vte-2.91 libftdi1-2 liblirc-client0 liblirc0
libusb-0.1-4 libvte-2.91-0 libvte-2.91-common libyaml-0-2 python3-yaml
Suggested packages:
libusb-0.1-4 libvte-2.91-0 libvte-2.91-common libyaml-0-2 lirc python3-yaml
0 upgraded, 15 newly installed, 0 to remove and 0 not upgraded.
Need to get 3088 kB of archives.
After this operation, 7557 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://deb.debian.org/debian buster/main amd64 gir1.2-atk-1.0 amd64 2.30.0-2 [25.3 kB]
Get:2 http://deb.debian.org/debian buster/main amd64 gir1.2-freedesktop amd64 1.58.3-2 [20.3 kB]
Get:3 http://deb.debian.org/debian buster/main amd64 gir1.2-gdkpixbuf-2.0 amd64 2.38.1+dfsg-1 [18.3 kB]
Get:4 http://deb.debian.org/debian buster/main amd64 gir1.2-pango-1.0 amd64 1.42.4-8~deb10u1 [55.8 kB]
Get:5 http://deb.debian.org/debian buster/main amd64 gir1.2-gtk-3.0 amd64 3.24.5-1 [252 kB]
Get:6 http://deb.debian.org/debian buster/main amd64 libvte-2.91-common all 0.54.2-2 [563 kB]
Get:7 http://deb.debian.org/debian buster/main amd64 libvte-2.91-0 amd64 0.54.2-2 [689 kB]
Get:8 http://deb.debian.org/debian buster/main amd64 gir1.2-vte-2.91 amd64 0.54.2-2 [529 kB]
Get:9 http://deb.debian.org/debian buster/main amd64 libftdi1-2 amd64 1.4-1+b2 [30.2 kB]
Get:10 http://deb.debian.org/debian buster/main amd64 liblirc-client0 amd64 0.10.1-6.3~deb10u1 [71.2 kB]
Get:11 http://deb.debian.org/debian buster/main amd64 libusb-0.1-4 amd64 2:0.1.12-32 [23.4 kB]
Get:12 http://deb.debian.org/debian buster/main amd64 liblirc0 amd64 0.10.1-6.3~deb10u1 [131 kB]
Get:13 http://deb.debian.org/debian buster/main amd64 libyaml-0-2 amd64 0.2.1-1 [47.2 kB]
Get:14 http://deb.debian.org/debian buster/main amd64 lirc amd64 0.10.1-6.3~deb10u1 [512 kB]
Get:15 http://deb.debian.org/debian buster/main amd64 python3-yaml amd64 3.13-2 [121 kB]
Fetched 3088 kB in 1s (3088 kB/s)
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_TIME = "ru_UA.UTF-8",
LC_MONETARY = "ru_UA.UTF-8",
LC_ADDRESS = "ru_UA.UTF-8",
LC_TELEPHONE = "ru_UA.UTF-8",
LC_NAME = "ru_UA.UTF-8",
LC_MEASUREMENT = "ru_UA.UTF-8",
LC_IDENTIFICATION = "ru_UA.UTF-8",
LC_NUMERIC = "ru_UA.UTF-8",
LC_PAPER = "ru_UA.UTF-8",
LANG = "ru_UA.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package gir1.2-atk-1.0:amd64.
(Reading database ... 48207 files and directories currently installed.)
Preparing to unpack .../00-gir1.2-atk-1.0_2.30.0-2_amd64.deb ...
Unpacking gir1.2-atk-1.0:amd64 (2.30.0-2) ...
Selecting previously unselected package gir1.2-freedesktop:amd64.
Preparing to unpack .../01-gir1.2-freedesktop_1.58.3-2_amd64.deb ...
Unpacking gir1.2-freedesktop:amd64 (1.58.3-2) ...
Selecting previously unselected package gir1.2-gdkpixbuf-2.0:amd64.
Preparing to unpack .../02-gir1.2-gdkpixbuf-2.0_2.38.1+dfsg-1_amd64.deb ...
Unpacking gir1.2-gdkpixbuf-2.0:amd64 (2.38.1+dfsg-1) ...
Selecting previously unselected package gir1.2-pango-1.0:amd64.
Preparing to unpack .../03-gir1.2-pango-1.0_1.42.4-8~deb10u1_amd64.deb ...
Unpacking gir1.2-pango-1.0:amd64 (1.42.4-8~deb10u1) ...
Selecting previously unselected package gir1.2-gtk-3.0:amd64.
Preparing to unpack .../04-gir1.2-gtk-3.0_3.24.5-1_amd64.deb ...
Unpacking gir1.2-gtk-3.0:amd64 (3.24.5-1) ...
Selecting previously unselected package libvte-2.91-common.
Preparing to unpack .../05-libvte-2.91-common_0.54.2-2_all.deb ...
Unpacking libvte-2.91-common (0.54.2-2) ...
Selecting previously unselected package libvte-2.91-0:amd64.
Preparing to unpack .../06-libvte-2.91-0_0.54.2-2_amd64.deb ...
Unpacking libvte-2.91-0:amd64 (0.54.2-2) ...
Selecting previously unselected package gir1.2-vte-2.91:amd64.
Preparing to unpack .../07-gir1.2-vte-2.91_0.54.2-2_amd64.deb ...
Unpacking gir1.2-vte-2.91:amd64 (0.54.2-2) ...
Selecting previously unselected package libftdi1-2:amd64.
Preparing to unpack .../08-libftdi1-2_1.4-1+b2_amd64.deb ...
Unpacking libftdi1-2:amd64 (1.4-1+b2) ...
Selecting previously unselected package liblirc-client0:amd64.
Preparing to unpack .../09-liblirc-client0_0.10.1-6.3~deb10u1_amd64.deb ...
Unpacking liblirc-client0:amd64 (0.10.1-6.3~deb10u1) ...
Selecting previously unselected package libusb-0.1-4:amd64.
Preparing to unpack .../10-libusb-0.1-4_2%3a0.1.12-32_amd64.deb ...
Unpacking libusb-0.1-4:amd64 (2:0.1.12-32) ...
Selecting previously unselected package liblirc0:amd64.
Preparing to unpack .../11-liblirc0_0.10.1-6.3~deb10u1_amd64.deb ...
Unpacking liblirc0:amd64 (0.10.1-6.3~deb10u1) ...
Selecting previously unselected package libyaml-0-2:amd64.
Preparing to unpack .../12-libyaml-0-2_0.2.1-1_amd64.deb ...
Unpacking libyaml-0-2:amd64 (0.2.1-1) ...
Selecting previously unselected package lirc.
Preparing to unpack .../13-lirc_0.10.1-6.3~deb10u1_amd64.deb ...
Unpacking lirc (0.10.1-6.3~deb10u1) ...
Selecting previously unselected package python3-yaml.
Preparing to unpack .../14-python3-yaml_3.13-2_amd64.deb ...
Unpacking python3-yaml (3.13-2) ...
Setting up gir1.2-freedesktop:amd64 (1.58.3-2) ...
Setting up libvte-2.91-common (0.54.2-2) ...
Setting up gir1.2-gdkpixbuf-2.0:amd64 (2.38.1+dfsg-1) ...
Setting up gir1.2-atk-1.0:amd64 (2.30.0-2) ...
Setting up libyaml-0-2:amd64 (0.2.1-1) ...
Setting up python3-yaml (3.13-2) ...
Setting up libvte-2.91-0:amd64 (0.54.2-2) ...
Setting up libusb-0.1-4:amd64 (2:0.1.12-32) ...
Setting up libftdi1-2:amd64 (1.4-1+b2) ...
Setting up gir1.2-pango-1.0:amd64 (1.42.4-8~deb10u1) ...
Setting up liblirc-client0:amd64 (0.10.1-6.3~deb10u1) ...
Setting up liblirc0:amd64 (0.10.1-6.3~deb10u1) ...
Setting up gir1.2-gtk-3.0:amd64 (3.24.5-1) ...
Setting up gir1.2-vte-2.91:amd64 (0.54.2-2) ...
Setting up lirc (0.10.1-6.3~deb10u1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/lircd.service → /lib
/systemd/system/lircd.service.
Created symlink /etc/systemd/system/sockets.target.wants/lircd.socket → /lib/sys
temd/system/lircd.socket.
Processing triggers for systemd (241-7~deb10u8) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10+deb10u1) ...
volumio@volumio:~$ sudo su
[sudo] password for volumio:
bash-5.0# cd /etc/lirc
bash-5.0# nano hardware.conf
bash-5.0# cd boot/
bash: cd: boot/: No such file or directory
bash-5.0# nano cmdline.txt
bash-5.0# cd /boot/
bash-5.0# nano lirc_options.conf
bash-5.0# sudo irrecord -H macmini -d /dev/usb/hiddev0 /etc/lirc/lircd.conf
Warning: Running as root.
Using driver macmini on device /dev/usb/hiddev0
Only first remote definition in file "/etc/lirc/lircd.conf" used
irrecord - application for recording IR-codes for usage with lirc
Copyright (C) 1998,1999 Christoph Bartelmus(lirc@bartelmus.de)
This program will record the signals from your remote control
and create a config file for lircd.
A proper config file for lircd is maybe the most vital part of this
package, so you should invest some time to create a working config
file. Although I put a good deal of effort in this program it is often
not possible to automatically recognize all features of a remote
control. Often short-comings of the receiver hardware make it nearly
impossible. If you have problems to create a config file READ THE
DOCUMENTATION at https://sf.net/p/lirc-remotes/wiki
If there already is a remote control of the same brand available at
http://sf.net/p/lirc-remotes you might want to try using such a
remote as a template. The config files already contains all
parameters of the protocol used by remotes of a certain brand and
knowing these parameters makes the job of this program much
easier. There are also template files for the most common protocols
available. Templates can be downloaded using irdb-get(1). You use a
template file by providing the path of the file as a command line
parameter.
Please take the time to finish the file as described in
https://sourceforge.net/p/lirc-remotes/wiki/Checklist/ an send it
to <lirc@bartelmus.de> so it can be made available to others.
Press RETURN to continue.
Checking for ambient light creating too much disturbances.
Please don't press any buttons, just wait a few seconds...
No significant noise (received 0 bytes)
Enter name of remote (only ascii, no spaces) :KEY_PREVIOUS
Using KEY_PREVIOUS.lircd.conf as output filename
Please enter the name for the next button (press <ENTER> to finish recording)
KEY_PREVIOUS
Now hold down button "KEY_PREVIOUS".
KEY_NEXT
Now hold down button "KEY_NEXT".
KEY_REWIND
Now hold down button "KEY_REWIND".
Timeout (10 seconds), try again (29 retries left).
Timeout (10 seconds), try again (28 retries left).
Timeout (10 seconds), try again (27 retries left).
Timeout (10 seconds), try again (26 retries left).
Timeout (10 seconds), try again (25 retries left).
Timeout (10 seconds), try again (24 retries left).
Timeout (10 seconds), try again (23 retries left).
Timeout (10 seconds), try again (22 retries left).
^[Timeout (10 seconds), try again (21 retries left).
Timeout (10 seconds), try again (20 retries left).
Timeout (10 seconds), try again (19 retries left).
Timeout (10 seconds), try again (18 retries left).
Timeout (10 seconds), try again (17 retries left).
Timeout (10 seconds), try again (16 retries left).
qq
Timeout (10 seconds), try again (15 retries left).
Timeout (10 seconds), try again (14 retries left).
Successfully written config file KEY_PREVIOUS.lircd.conf
bash-5.0#
bash-5.0# qq
bash: qq: command not found
bash-5.0#
parameter.
Enter name of remote (only ascii, no spaces) :onkyo_rc-799m
Using onkyo_rc-799m.lircd.conf as output filename
KEY_PREVIOUS
KEY_NEXT
The name must not contain any whitespace.Press RETURN to continue.
KEY_NEXT
'EY_NEXT' is not in name space (use --disable-namespace to override)
KEY_NEXT
KEY_NEXT
KEY_PLAY
Now hold down button "KEY_PLAY".
KEY_PAUSE
Now hold down button "KEY_PAUSE".
KEY_STOP
Now hold down button "KEY_STOP".
KEY_REWIND
Timeout (10 seconds), try again (13 retries left).
Timeout (10 seconds), try again (12 retries left).
Timeout (10 seconds), try again (11 retries left).
Timeout (10 seconds), try again (10 retries left).
Successfully written config file onkyo_rc-799m.lircd.conf
bash-5.0#
bash-5.0#
bash-5.0#
bash-5.0#
bash-5.0#
bash-5.0# sudo service lirc restart
Failed to restart lirc.service: Unit lirc.service not found.
bash-5.0# sudo service lircd restart
bash-5.0# irw
tried to install the plugin but it hangs tightly in the system, I don’t speak English, translated by a translator, so sorry for the errors
I assume your macmini is an x86 machine. The plugin is not made for x86 systems. Therefore it should not be available from the plugin store on an x86 Volumio system. Did you try to install the plugin manually (i.e. not using the plugin store)?
Yes system x86, plugin put manually according to the instructions, above nothing happened. Now i am interested in manual installation of lirc, what I do wrong and why it does not work?
At this point you’ve only have lirc leraned the codes transmitted by your remote control.
Next thing is create a file that performs an action on the received data.
“onkyo_rc-799m.lircd”
This should contain the sent IR-Code and action Volumio needs to take.
like:
begin
prog = irexec
button = KEY_PLAYPAUSE
config = /usr/local/bin/volumio toggle
end
begin
prog = irexec
button = KEY_UP
config = node /data/plugins/user_interface/randomizer/randomAlbum
end
begin
prog = irexec
button = KEY_NEXT
config = /usr/local/bin/volumio seek plus
end
begin
prog = irexec
button = KEY_PREVIOUSSONG
config = /usr/local/bin/volumio previous
end
begin
prog = irexec
button = KEY_NEXTSONG
config = /usr/local/bin/volumio next
end
not exactly, I’m stuck on the process -
```after that i open the file onkyo_rc-799m.lircd.conf `
# Please take the time to finish this file as described in
# https://sourceforge.net/p/lirc-remotes/wiki/Checklist/
# and make it available to others by sending it to
# <lirc@bartelmus.de>
# This config file was automatically generated
# using lirc-0.10.1(macmini) on Sun Oct 16 18:54:36 2022
# Command line used: -H macmini -d /dev/usb/hiddev0 /etc/lirc/lircd.conf
# Kernel version (uname -r): 5.10.139-volumio
# Remote name (as of config file): onkyo_rc-799m
# Brand of remote device, the thing you hold in your hand:
# Remote device model nr:
# Remote device info url:
# Does remote device has a bundled capture device e. g., a
# usb dongle? :
# For bundled USB devices: usb vendor id, product id
# and device string (use dmesg or lsusb):
# Type of device controlled
# (TV, VCR, Audio, DVD, Satellite, Cable, HTPC, ...) :
# Device(s) controlled by this remote:
begin remote
name onkyo_rc-799m
driver macmini
bits 0
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 32
pre_data 0x0
gap 132799
toggle_bit_mask 0x0
frequency 38000
begin codes
KEY_PREVIOUS 0x0
KEY_NEXT 0x0
KEY_PLAY 0x0
KEY_PAUSE 0x0
KEY_STOP 0x0
KEY_REWIND 0x0
end codes
end remote
remote codes are empty
The service to start is named lircd and the command would be
systemctl start lircd.service
You can check the status of the service running
systemctl status -l lircd.service
doc@htpc:~$ ssh volumio@192.168.2.12
volumio@192.168.2.12's password:
___
/\_ \ __
__ __ ___\//\ \ __ __ ___ ___ /\_\ ___
/\ \/\ \ / __`\\ \ \ /\ \/\ \ /' __` __`\/\ \ / __`\
\ \ \_/ |/\ \L\ \\_\ \_\ \ \_\ \/\ \/\ \/\ \ \ \/\ \L\ \
\ \___/ \ \____//\____\\ \____/\ \_\ \_\ \_\ \_\ \____/
\/__/ \/___/ \/____/ \/___/ \/_/\/_/\/_/\/_/\/___/
Free Audiophile Linux Music Player - Version 3.0
© 2015-2021 Michelangelo Guarise - Volumio Team - Volumio.org
permitted by applicable law.
Welcome to Volumio for x86_64 (5.10.139-volumio x86_64)
Last login: Sun Oct 16 18:57:26 2022 from 192.168.2.3
bash-5.0# systemctl start lircd.service
bash-5.0# systemctl status -l lircd.service
● lircd.service - Flexible IR remote input/output application support
Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: en
Active: active (running) since Sun 2022-10-16 18:55:54 UTC; 14h ago
Docs: man:lircd(8)
http://lirc.org/html/configure.html
Main PID: 9203 (lircd)
Memory: 636.0K
CGroup: /system.slice/lircd.service
└─9203 /usr/sbin/lircd --nodaemon
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/de
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Info: initializing '/dev/usb/hiddev0
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new cl
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: removed client
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb
Oct 16 19:13:58 volumio lircd-0.10.1[9203]: Info: removed client
Oct 16 19:13:58 volumio lircd-0.10.1[9203]: Info: closing '/dev/usb/hiddev0'
lines 1-20/20 (END)
Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: ena
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/r
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Info: initializing '/dev/usb/hiddev0'
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new cli
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/r
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/
lines 1-20/20 (END)
Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: enab
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/ru
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new clie
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/ru
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/h
lines 1-20/20 (END)
Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: enabl
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/u
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new clien
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/hi
lines 1-20/20 (END)
Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: enable
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/us
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/hid
lines 1-20/20 (END)...skipping...
Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: enabled
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/l
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/l
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/hidd
lines 1-20/20 (END)
Loaded: loaded (/lib/systemd/system/lircd.service; enabled; vendor preset: enabled)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/li
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client o
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/li
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/hidde
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/h
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lir
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lir
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/hiddev
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/hi
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/hiddev0
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/hid
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/
Oct 16 19:13:58 volumio lircd[9203]: lircd-0.10.1[9203]: Info: closing '/dev/usb/hiddev0'
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/hidd
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/l
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /v
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/l
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/hidde
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/li
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /va
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/li
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/hiddev
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lir
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lir
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/hiddev0
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lirc
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lirc
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 18:56:01 volumio lircd[9203]: lircd-0.10.1[9203]: Info: initializing '/dev/usb/hiddev0'
Oct 16 18:56:01 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lircd
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/r
Oct 16 19:00:27 volumio lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lircd
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/ru
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/l
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/li
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lir
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/l
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/li
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lir
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lirc
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Oct 16 19:00:27 volumio lircd[9203]: lircd-0.10.1[9203]: Notice: accepted new client on /var/run/lirc/lircd
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
lines 1-20/20 (END)
Docs: man:lircd(8)
Memory: 636.0K
````doc@htpc:~$ ssh volumio@192.168.2.12
___
/\_ \ __
Last login: Mon Oct 17 09:19:13 2022 from 192.168.2.3
volumio@volumio:~$ sudo irrecord -H macmini -d /dev/usb/hiddev0 /etc/lirc/lircd.conf
Running as regular user volumio
parameter.
KEY_PREVIOUS
KEY_NEXT
KEY_PLAY
KEY_PAUSE
KEY_STOP
KEY_REWIND
Please post the result of
cat /etc/lirc/lirc_options.conf
bash-5.0# cat /etc/lirc/lirc_options.conf
# These are the default options to lircd, if installed as
# /etc/lirc/lirc_options.conf. See the lircd(8) and lircmd(8)
# manpages for info on the different options.
# Some tools including mode2 and irw uses values such as
# driver, device, plugindir and loglevel as fallback values
# in not defined elsewhere.
[lircd]
nodaemon = False
driver = macmini
device = /dev/usb/hiddev0
output = /var/run/lirc/lircd
pidfile = /var/run/lirc/lircd.pid
plugindir = /usr/lib/x86_64-linux-gnu/lirc/plugins
permission = 666
allow-simulate = No
repeat-max = 600
#effective-user =
#listen = [address:]port
#connect = host[:port]
#loglevel = 6
#release = true
#release_suffix = _EVUP
#logfile = ...
#driver-options = ...
[lircmd]
uinput = False
nodaemon = False
# [modinit]
# code = /usr/sbin/modprobe lirc_serial
# code1 = /usr/bin/setfacl -m g:lirc:rw /dev/uinput
# code2 = ...
# [lircd-uinput]
# add-release-events = False
# release-timeout = 200
# release-suffix = _EVUP
bash-5.0#
mode2 --driver devinput --device /dev/usb/hiddev0
Using driver devinput on device /dev/usb/hiddev0
Trying device: /dev/usb/hiddev0
Using device: /dev/usb/hiddev0
code: 0x000000ff00000000000000ff00000000000000ff00000000
Partial read 8 bytes on /dev/usb/hiddev0volumio@volumio:~$ mode2 --driver devinput --device /dev/usb/hiddev0
“lirc_options.conf” looks ok to me, but I currently I have no idea why
occur. Maybe check your “lircrc” and “lircd.conf” file for syntax / formatting errors and / or try if starting lircd succeeds when using the original “lircrc” and “lircd.conf” files.
Unfortunately I have no x86 system with an IR receiver to check myself.
Technics RAK-SL404WH.zip (1.6 KB)
Panasonic EUR643824.zip (1.6 KB)
I found a couple of unnecessary remotes. Easy to connect. Thanks to the author of the plugin. I want to expand the functionality (menu navigation, source selection). Not only Stop, Play, Forward, Backward.
If you need other functions than default provided, you’ll need to create your own scripts and call it via
lirc, like:
begin
prog = irexec
button = KEY_SHUFFLE
config = node /data/plugins/user_interface/randomizer/randomTracks
end
These are the ones that are provided:
[[PLAYBACK STATUS]]
status Gives Playback status information
volume Gives Current Volume Information
volume <desired volume> Sets Volume at desired level 0-100
volume mute Mutes
volume unmute Unmutes
volume toggle Mutes/Unmutes
volume plus Increases Volume of one step
volume minus Decreases Volume of one step
seek plus Forwards 10 seconds in the song
seek minus Backwards 10 seconds in the song
seek <seconds> Plays song from selected time
repeat Toggles repetition of queue
random Toggles randomization of queue
[[PLAYBACK CONTROL]]
play
pause
toggle Toggles between play/pause
next
previous
stop
clear
@Andron66 Do you mind if I add both configurations to the plugin? In “lircrc” I would however remove “/usr/local/bin/volumio status” and add “config = systemctl poweroff” for “KEY_POWER”.
If you want to use your configurations in the posted or modified version, you can save them to “/data/INTERNAL/ir_controller" as described here.
I used both remotes. The configurations were installed as you indicated. I just gave them as an example. You can use them as you want. You can fix it as it seems to you correctly.
Could you please tell which physical keys of the Techniks remote correspond to the key names “disc”, “generalvol-”, “generalvol+”, “spiral”, “winampvol+”, “winampvol-” and “off-winamp” in “lircd.conf” and if “KEY_ENTER” represents the remote’s “Recall” button?
File “lircd.conf” taken from the model Technics_RAK-SL948WK. The buttons you listed are not in the model Technics RAK-SL404WH. Entries can be deleted.
