I have reinstalled the plugin but is not ok
http://logs.volumio.org/volumio/4GibNCE.html
Still not working … what have reinstalled the plugin
Remove= uninstall + physically remove from RPi via FTP
Understood , where are located the plugins files please .
I have teied to install also the pillow package but it said : unable to locate package pillow
/data/plugins/user_intetface
/data/internal
/home/volumio
http://logs.volumio.org/volumio/S1yO7dG.html
Still not working
Impossible!!
When is around start to show spectrum immediately as the music is started or there is a delay ?
When the music starts. Follow steps 6 and 7. (APPLY)
And select another song from the list
I let the default spectrum … s1 s2 etc and screen type medium
For example: medium - then APPLY, s1 and APPLY again. A spectrum should appear, if there is a background and the bars don’t work - change to the next song
ONLY remember:
Multiroom - off
Mixer type: none or hardware
Peppymeter - off
Thanks for your support , but unfotunetally the bars does not show .
but the background appears?
Nothing appears
Hi @balbuze
I have reinstalled Volumio . Only touch display and peppy spectrum plugin but still not showing .
http://logs.volumio.org/volumio/O6F0UCM.html
Thanks for your help
Ok. I will try with a fresh install to see what happens.
Sorry for that.
PeppySpectrum v0.0.16
- fix for above issue…
- install on amd64 (x86) devices. Totally untested!
python3-pip was not installed.
Thanks for feedback!
This a beta, so enable plugin beta, remove previous, reboot, install, enjoy! ![]()
edit : v0.0.16
Thanks a lot ![]()
As soon as I get home I will try . Glad that I have found a bug , my job și a tester
also in real life :)))
Nice , very nice plugin .
thanks
