what do you mean by doesn’t start? The plugin can’t start or spectrum don’t move?
for the first use after installation, you must save spectrum folder Select spectrum
you can send log How to send a log link for a bug report?
Hi, @balbuze. The plugin can’t start, my display show only the cover of the track performed, but no spectrum appearson the screen.
My peppyspectrum configuration is the same of your.
I see you use the old spotify connect! Should not work… But this is not the problem. Something is missing in installation, see
May 21 17:02:55 volumio volumio[935]: info: peppyspectrum Daemon Started
May 21 17:02:55 volumio volumio[7305]: pygame 1.9.4.post1
May 21 17:02:55 volumio volumio[7305]: Hello from the pygame community. https://www.pygame.org/contribute.html
May 21 17:02:55 volumio volumio[7305]: Traceback (most recent call last):
May 21 17:02:55 volumio volumio[7305]: File "spectrum.py", line 30, in
May 21 17:02:55 volumio volumio[7305]: from spectrumutil import SpectrumUtil
May 21 17:02:55 volumio volumio[7305]: File "/data/plugins/user_interface/peppyspectrum/PeppySpectrum/spectrumutil.py", line 19, in
May 21 17:02:55 volumio volumio[7305]: from PIL import Image
May 21 17:02:55 volumio volumio[7305]: ModuleNotFoundError: No module named 'PIL'
May 21 17:02:55 volumio systemd[1]: peppyspectrum.service: Main process exited, code=exited, status=1/FAILURE
May 21 17:02:55 volumio systemd[1]: peppyspectrum.service: Failed with result 'exit-code'.
So remove the plugin, reboot, install the plugin, try to play and send log please.
ok, now i try.
But i was trying to use old spotify connect because using new spotify plugin + peppymeter i have more clicks performing music from spotify that getting me mad !
I made a fresh volumio installation,installed touch display and then Peppyspectrum.
In the option of peppyspectrum at first i select a package,them download (1280x400 gelo and 1480x320 gelo),then select folder spectrum,then spectrum (Random)…nothing. on the display i see only now playing screen…
Via SSh in data/internal/peppyspectrum/templetase there are the 2 folder downloaded 1280x400 Gelo that contains several template and 1480x320+99-99bars-balbuze that is empty. Howeve choosing 1280x400 gelo nothing appears on my screen.
http://logs.volumio.org/volumio/OmOmD2K.html
I can’t see the plugin installation in your log…
But there’s still an error with a missing python lib.
In a ssh console, can you try
sudo apt-get install python3-pygame python3
And see what it returns
Good morning @balbuze I
This is my shh message after “sudo apt-get install python3-pygame python3”
volumio@volumio:~$ sudo apt-get install python3-pygame python3
Reading package lists… Done
Building dependency tree
Reading state information… Done
python3 is already the newest version (3.7.3-1).
python3-pygame is already the newest version (1.9.4.post1+dfsg-3).
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
Started again volumio, performed music and…nothing appears on my screen.
http://logs.volumio.org/volumio/OdeiRGV.html
I didn’t make skins for this resolution. You didn’t make a mistake?
hi @Gelo5 , i see in the template folder 1480x320 that is empty and so i choose other resolutions too and it don’t change anything.
can you try
pip3 install Pillow
volumio@volumio:~$ pip3 install Pillow
-bash: pip3: command not found
It’ my terminal SSH response…
And
pip install Pillow
volumio@volumio:~$ pip install Pillow
-bash: pip: command not found
Hi!
I found the issue. Python3-pip was not installed…
Please update to v0.0.24
let me know
TY
hI @balbuze!
I’ve installed new version 0.0.24, and finally spectrum appears on the screen
P.s.i’ve installed Nowplaying (as you write on readme.file)
All is ok i i perform music from nas or webradios but if i try to perform music from Spotify it’s not possible, music isn’t performed (i tried several combination nowplayng off/on but no music from Spotify and Spotify disconnects)
With Spotify on,Peppyspectrum on,now playing off, music returns to be performed but i see only the backgrounds of the spectrum but without
Volumio latest version
Spotify connect 4.0.4
Now playing 0.6.0
Touchdisplay 3.4.0
http://logs.volumio.org/volumio/ccZJOSZ.html
You found a mistake… Now playing is not necessary…
Try to disable and renable Spotify plugin.
The spectrum may take several seconds to start.
It randomly stops and restart while playing.
This is a known bug. But seems to comes from peppyspectrum or peppy Alsa.
I don’t know how to fix it…
PeppySpectrum v0.0.26 stable
Enjoy!
Hi, guru @balbuze and have a good sunday!
Installed new version.
My new version report:
Source: 1) Spotify 4.0.4 to performs music and Peppyspectrum On, Spotify disconnects continuosly,
so it’s not possible to use it to listen music.Ssometimes the connection stabilizes but no
music is reproduced (silence) and you only see the background of the spectrum and no
moving bars.
2) NAS & webradios to perform music and Peppyspectrum On: Music performs but spectrum
appears but bars move for several seconds and then disappear and randomly apper
moving and so on.
Thanks for your feedback.
Did you test peppymeter and if yes, does it work?
Can you send log when using Spotify?
I tested on a Rpi4 and it is ok with headphones as output…
Peppymeter is ok (with the old and eternal audio issue (for my system) of clicks and stutterings using Spotify)
http://logs.volumio.org/volumio/izVlyaP.html
