When I try to run the plugin from console I get this error:
volumio@volumio:/data/plugins/user_interface/peppyspectrum$ bash startpeppyspectrum.sh
pygame 1.9.4.post1
Hello from the pygame community. Contribute - pygame wiki
File “spectrum.py”, line 712, in
pm = Spectrum(None, True)
File “spectrum.py”, line 63, in init
self.init_display()
File “spectrum.py”, line 113, in init_display
self.util.pygame_screen = pygame.display.set_mode((screen_w, screen_h), pygame.DOUBLEBUF | pygame.NOFRAME, depth)
pygame.error: Couldn’t set console screen info
I’m able to run peppymeter with some tweaks on file pam.d and running the .py with sudo -k (tried the same tweak on peppyspectrum but no luck).
This is a tweak that someone told here in the forum (sorry don’t remember now who). I know it breaks volumio but nothing that a good old factory reset won’t solve if there is the need
peppymeter runs 99% of all linear meters and 0% of circular meters (with circular ones it crashes and need reboot after some seconds).
Also, I appreciate your response. I’m not very knowledgeable about software. Please let me know how to set up Peppy Spectrum in detail( step by step ).
Im using 1280x400 HDMI screen.
@Naveen
run plugin test mode (volumio.local/dev) and install from plugin store.
Then download skins for your resolution (in this thread - PeppySpectrum - The plugin! - #80 by balbuze). Unzip and place in the Template folder.
You need to add it in spectrum.txt:
topping.height = 1
topping.step = 5
When I have some free time, I will change the spectrum.txt file
Yes. But you can have a look at my 99-bands-freq above.
It is ok except the size.
Remember the naming for the folder is:
My spectrum(widthxheightxnumberofbands). Example metal-spectrum(1980x400x50)
im totally confused… As i told you in my earlier message, im a beginner … Anyways let me try this… If anything goes wrong, then i will get back to you.
