PeppyMeter Templates width: 1480
  • Every subtopic contains the following information:
    • Resolution:
    • Template name
    • a 400 px width screenshot of the template
    • Instructions if needed
    • Download link, containing
		*.meters.txt (only for this template)
A B C D E F G H I J K L M N O P Q R S T U V X Y Z
C
E
F
G
H
I
J
K
O
P
Q
R
U
V
W
X
Z
Resolution: 1480x320
Screenshot:
116 SKINS 1480x320
down
Attention! The archive contains 2 folders: “templates” and “templates_spectrum”.
Unzip on your computer and move the folders to:
1. From the “templates” folder to: /data/INTERNAL/peppy_screensaver/templates" DO NOT CHANGE THE NAME.
2. From the “templates_spectrum” folder to: /data/INTERNAL/peppy_screensaver/templates_spectrum DO NOT CHANGE THE NAME.
You can delete unused resolutions, e.g. custom 800x480, 1920x515, 1920x1080 etc.
Hello in the meter.txt the entry for the modern skin is missing. The pictures are in the folder (Modern.jpg, etc).
Modern.zip (600 Bytes)
thanks works perfect
Hi,@Gelo5, and thank you for your pretious support.
In the entry 1480x320 The Accu and Accuphase jpg are missing but their desciption are in the meter.txt, so cay you add those missing pictures?
Thank’s !
Hi Roberto
Grzegorz
Thank’you Grzegorg !!!
THankyou dear @Gelo5
hi @Gelo5 i’d like to create new skins or transform existing ones into peppymeter with 1480x320 resolution, could you explain me (i’m an ignorant newbie) what needs to be done, how to proceed step by step. I could also be useful to others in the community. Thanks always
Thank’a lot,my friend !
Wow…coool brother
foud it,
Thank you a lot !!
i have this plugin who like me also, but how to make to see player (work only via web), Pi HDMI is just plugin… ?
Thank you for reply and help, Grzegorz !
We’re moving all our templates to GitHub, so this topic is officially retiring. Thanks for the memories, closing it now!
