Almost there ![]()
Internal QA is done. Now next QA with the mods and devs group ![]()
If that goes well, release is very very near
Almost there ![]()
i can’t wait for it
Most of my friends depend on this is working.
any chance to get into the magic circle for testing ?
Best Regards
Josef
Volumio Version: 3.512
Hardware: Rasp PI 4B
DAC: HiFiBerry Digi Pro
info: CoreStateMachine::play index undefined
info: CorePlayQueue::getTrack 1
info: CoreStateMachine::startPlaybackTimer
info: [1696772576367] ControllerSpotify::clearAddPlayTrack
info: CorePlayQueue::getQueue
info: Setting this device active
info: [GPIO_Control] *** musicStop ***
info: [GPIO_Control] Delaying: 0ms
info: [GPIO_Control] Turning GPIO 12 Off (musicStop)
info: touch_display: Setting screensaver timeout to 0 seconds.
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 6597951733573032606610955304546343246, audio_type: Track }, track_id: SpotifyId { id: 6597951733573032606610955304546343246, audio_type: Track } }
[Vollibrespot] : error 400 for uri hm://autoplay-enabled/query?uri=
[Vollibrespot] : AutoplayError: MercuryError
info: touch_display: Using Xserver unix domain socket /tmp/.X11-unix/X0
[Vollibrespot] : Pause
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 6597951733573032606610955304546343246, audio_type: Track } }
[SpotifyConnect] Cradled
[SpotifyConnect] Pause
[SpotifyConnect] PlaybackInactive
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 6597951733573032606610955304546343246, audio_type: Track }, track_id: SpotifyId { id: 214137770048703878492574283710770164039, audio_type: Track } }
[Vollibrespot] : Loading with Spotify URI
[Vollibrespot] : (1440013 ms) loaded
[Vollibrespot] : Alsa error PCM open ALSA function 'snd_pcm_hw_params_set_buffer_size_near' failed with error 'EINVAL: Invalid argument'
[Vollibrespot] : Could not start audio: Alsa error: PCM open failed
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 214137770048703878492574283710770164039, audio_type: Track } }
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 214137770048703878492574283710770164039, audio_type: Track }, position_ms: 43 }
[SpotifyConnect] Octavarium
[SpotifyConnect] Device palyback is loading
[SpotifyConnect] pause
thread '' panicked at 'called `Option::unwrap()` on a `None` value', /build/cache/git/checkouts/librespot-6f197fd632ef9380/08d8bcc/playback/src/audio_backend/alsa.rs:129:35
stack backtrace:
0: 0x9b8444 - std::backtrace_rs::backtrace::libunwind::trace::h40a4eff66330a36d
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/../../backtrace/src/backtrace/libunwind.rs:93:5
1: 0x9b8444 - std::backtrace_rs::backtrace::trace_unsynchronized::hbce01963451b0cd5
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/../../backtrace/src/backtrace/mod.rs:66:5
2: 0x9b8444 - std::sys_common::backtrace::_print_fmt::h95da650d09c7e00b
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:66:5
3: 0x9b8444 - ::fmt::h33b23b1d14f668ff
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:45:22
4: 0x9e10dc - core::fmt::write::h6320fb0e6ac90e58
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/core/src/fmt/mod.rs:1190:17
5: 0x9b04c4 - std::io::Write::write_fmt::h33b25d4810ca481f
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/io/mod.rs:1657:15
6: 0x9baef4 - std::sys_common::backtrace::_print::h7e61c5be69c715ef
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:48:5
7: 0x9baef4 - std::sys_common::backtrace::print::h3cee176d7c8dab8b
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:35:9
8: 0x9baef4 - std::panicking::default_hook::{{closure}}::h2d0211dd2e97dc43
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:295:22
9: 0x9bab14 - std::panicking::default_hook::hcbdb3b7c40dca30c
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:314:9
10: 0x9bb694 - std::panicking::rust_panic_with_hook::h4ce49e7a343dc12b
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:698:17
11: 0x9bb360 - std::panicking::begin_panic_handler::{{closure}}::h4961100fae529fe9
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:586:13
12: 0x9b89c4 - std::sys_common::backtrace::__rust_end_short_backtrace::hf2e68e62c7a80f1f
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:138:18
13: 0x9bb098 - rust_begin_unwind
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:584:5
14: 0x49e6f4 - core::panicking::panic_fmt::h84c42730e4a50809
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/core/src/panicking.rs:143:14
15: 0x49e5c8 - core::panicking::panic::h929d4344847bfdba
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/core/src/panicking.rs:48:5
16: 0x5d9158 - ::write::h2857e81996e06a1e
17: 0x5bb814 - ::poll::hf6331a81451dbb28
18: 0x4e36c0 - futures::task_impl::std::set::hb731921744f9247e
19: 0x4d4708 - futures::task_impl::Spawn::poll_future_notify::h08f2c87ba9a4eead
20: 0x4e8158 - std::sys_common::backtrace::__rust_begin_short_backtrace::hb598e9d2970dbf13
21: 0x514e70 - core::ops::function::FnOnce::call_once{{vtable.shim}}::h7f140b0cfa5289e1
22: 0x9bfebc - as core::ops::function::FnOnce>::call_once::hbc4d03a1815e028a
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/alloc/src/boxed.rs:1853:9
23: 0x9bfebc - as core::ops::function::FnOnce>::call_once::h6055603e421418e8
24: 0x9bfebc - std::sys::unix::thread::Thread::new::thread_start::h0518d9d0e6b0ba31
at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys/unix/thread.rs:108:17
info: Is Not Connect Playback
info: [1696772577471] ControllerSpotify::pushState
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus stop
info: [1696772577948] ControllerSpotify::pushState
An update will be released soon
Hi, so as it seems, that there are a lot of people having interesting issues with this plugin (and I think not too less people use Spotify here) - a more “precise” timeframe than soon would help us during this time suffering with this and that issue…
Also in case you need testers - please let me know, could not be worser than now ![]()
The post above from @volumio is as precise in terms of a robust testing schedule as can reasonably be expected. There’s no point in giving an exact release date until this stage of testing is completed satisfactorily.
"Internal QA is done. Now next QA with the mods and devs group.
If that goes well, release is very very near"
hi
I am using volumio 3.512 on a raspberry pi with spotify plugin 3.0.9.
I was just wondering if it is to be expected that this spotify plugin falters so often: I will for instance select an album to play, and after perhaps 4 tracks it will just stop. This happens very often.
Is that “normal” or can I perhaps try to do something about it?
regards, Danny.
This is just one of the “problems” Spotify currently has…
Mine is a bit funnier but still annoying…
Looking forward to get notified that the Beta reaches public.
any update on that?
The new plugin has been released. For sake of clarity and tidyness, we’re locking this thread.
Let’s continue on the new thread for the 2023 plugin.
