I noticed that too via ir (about 1 second). Generally searching, selecting and starting playing is all quicker.
The one, tiny quirk I have noticed is that going from a song selected via the plugin and then clicking on a track via the app often requires a second click. However after that it’s working perfectly through playlists.
OK, I did find a problem. Whilst playing a playlist of tracks via my NAS and then going to the Spotify app on my phone and playing a track, the original playlist continues and I see a Spotify api error. The better news is that I didn’t need to restart Volumio to fix it (as was the case with the old version). It was enough to delete the queue in Volumio and then click play again from the Spotify app. Switching between Spotify app and plugin is perfect.
I made a fresh installation of volumio V 3.396 with spotify plugin V 3.07 on a RP4.
I can search for music, albums… but when I try to start a title nothing will happen.
Tried this in normal and in pluin test mode with same result
Fair point McMuffin. That’s not what I meant to say.
It’s not that I blame Volumio, but for me Spotify is my main source for listening music. So the inconvenience is actually quite big for me, and could mean I have to find my solution elsewhere.
The ‘bad’ thing is though, the Volumio Rivo sounds so darn good! That makes it hard to return it
If I recall correctly, you were asked to put plugins in test mode to install pandora. then you installed the spotify plugin. Given what we discovered lately (a glitch in the plugin system). Can you:
Disable plugin test mode
Uninstall spotify plugin
Restart
Install the spotify plugin
Check which version is installed and report back here please
Let us know also if it works, and how you use it (via Connect functionality or via browsing via the UI)
In any case, for products, we’ve initiated the official Spotify integration request. We’ve not heard from them yet. But our plan for products is to deliver official implementation (given that Spotify grants us the SDK).
