100% agree
Additionally I have complains on volumio GUI issues which of course didn’t fixed in new 3x version (because they stick to same ideology)
With last increase to 60 Eur/year Volumio just became ridiculous pain in ass to all smart people.
And last word - min raspberry pi 4 kit cost as much as wiim mini, but you should add here volumio subscription which in 3-4 years will accumulate to hundreds of money and probably only increase wiith time - its 100% dumb …
I do not think that you can eat 4 pizza, 4 beers and 4 juice in these days … with 60 euros …in a restaurant .
And the pizzas look disgusting after a few months!
Considering how much time I spend enjoying music via Volumio, I find the fee is more than ok. Plus there’s a pretty full functioning free version.
NOTICE:
There is currently an issue with the download of the spotify plugin from the Volumio plugins store. Basically the install of the plugin will fail.
We are aware of the issue and we are working around the clock to fix it, we will update here when its fixed. Sorry for the inconvenience
The 3.0.4 version still works for a quick and temporary fix.
(only accessable by setting Volumio in “Plugin test mode” at volumio.local/dev)
I think at this point it is clear that the volumio dev team doesn’t have the skill set to solve this problem. Every other audio company in the world has made a smooth transition to the new spotify api, only volumio can’t get it done.
I’m cancelling my subscription. I will give moode audio a try, despite not liking their GUI.
Maybe you should consider giving up volumio and builda GUI for Moode, since your programming skills seem rather limited.
I know these are harsh words, but as I paying customer I feel that I don’t deserve to be treated like this. If you can’t get your job done, at least don’t charge for it.
Sorry to read your unfunded response, that mainly consist with made up facts. You should be proud and consider writing fairy tails!!!
The first Spotify plugin was written by the community, when the used library was cancelled by Spotify and no-one within the community wanted to take over development, Volumio stepped in and filled the gap. Even though they have little resources to do it, they did. And yes there are still some issues that will be resolved during the course of time.
Where did you pay for Spotify, not with volumio?
if you don’t understand the plugin system, it’s not smart to act like you do or even claim you paid for it.
If you have something constructive to say, please do. If not don’t reply.
What an unnecessarily nasty comment. It is of course your right to cancel if you are unhappy and impatient, but really no need to throw insults around.
@volumio
Just updated the Spotify plugin to v 3.0.7 and the queuing issues seem to be completely gone!
Tried playing a playlist from within the plugin, all played in the right order without skipping (this already worked for me). Then I played a different playlist from the Spotify app on my phone and everything still worked perfectly (this did not work in 3.0.6 for me). Switching back and forth between plugin and app and everything is working exactly as it should be. Thanks!
Rpi4, USB DAC, Volumio 3.396, Spotify 3.0.7
thank you simon, what a brillant move, Santa Claus has to behave himself
@chourmovs_vs Is it the same for you? I’ve been running a huge Spotify playlist for the last 2 hours and so far it’s faultless.
Hi, just tested and yes the most significant issues seem to be fixed - YIPPIE YEAHHH !!!
Tested on Volumio v3.398 and Spotify v3.07 on a Raspberry3 with ALLO BOSS.
The only thing i can see, that still is not working is pressing the play button directly from the list of search results - i still have to click on it first an press play there - then it is working perfect. But that’s no show stopper - as long as one is aware of this behaviour.
So supercool - best Xmas gift.
I will go on using it and will report any other issue - if still exists.
Thank you so much - to whom ever fixed it so far.
And to the ones that could not live with the previous version - i could - by strictly only using the “connect” part - which never did really annoy me since this worked correctly ( think since v3.03). But i also prefer to be able to select from the Volumio UI as well.
My superbest Regards
Josef
didn’t test yet, tomorrow I’ ll give it a try also
Who did the job exactly at volumio ?
It’s really fixed. Searching within the plugin and switching tracks, playlists is also faster. Zero anomalies when switching between app and plugin. Congratulations to the devs!
(Made a backup of my SD card, always good to have a perfect iteration on the shelf!)
Hard truth is:
The update did not have any change, it was just a version bump to solve an issue with the plugin manager. The plugin in itself did not have any change.
Then, there are 2 explanations for the improved behavior that you are experiencing:
The plugin behaviour is very unpredictable, since it’s infuenced by Spotify’s API state, which kind of tracks you play and how it’s used in conjunction with other plugins. This also explains why it’s so hard to get it right for us in the first place (and why librespot needs a rewrite).
There was a bug in the plugin manager which until now was serving another version of the plugin, which did not include all the fixes done.
Let us know how it keeps going, I would really love to be N2 but that is the least likely option…
Hi, for me also - its working now
A long time with new installations is over
Iam so happy! Thank U so mutch!!! If there is a fixed plan for a premium subscription I would like to join. Greetings to Italy michael
and thanks again you are the best
Haha, that’s funny. See how far it’s already solved
I also guess it’s N1.
tested both version bridged in music source and spotifyconnect and everything seems to work fine.
For having mess with plugin manager and plugin submission lately, I won’t be surprised that github and devs were in the center of this “side effect” bug. I bet for N2
A simple example is : dev make commit and push and don’t change version number, then on the same version you have slightly difference that by the game of cache client side explain that people get different behavior depending on their setup oldness.
Then the only way to reorder things is dev take an old backup that was functioning and publish a new version number on github
Maybe I’m totally wrong
Actually it can have far more meanings. There were an awful lot of people in the station (emphasis). You are an awful lot of children (bad), etc… coming from “full of awe”, you can read “awful lot of integrations” as a bad bunch of integrations, as well as a lot of integrations… context important!
i have installed spotify version 3.0.7 and i notice that clicking next song via infrared remote controller plugin is now faster.
in previous versions there was always a delay of about 4 seconds.
is this issue also addressed in version 3.0.7?
