Please remove previous version first and reboot as running update from the plugin page causes V3.0.4 to fail to login.
I am still getting OAuth errors when trying to use the Volumio UI.
http://logs.volumio.org/volumio/pTYr6E7.html -
When I reboot device, and immediately go to spotify app, select the device, and then play something (queue has been cleared), nothing plays
It does load that track into the Volumio IO, and the attached screen, however it doesnāt actually play
http://logs.volumio.org/volumio/DbQTnkj.html
I restarted, cleared queues everywhere, and tried again, same result. It seems to play for 0.4 seconds and then pause. http://logs.volumio.org/volumio/WLagwKz.html
Hi @wcndave ,
You get an error:
error: An error occurred while listing Spotify new albums WebapiError: API rate limit exceeded
This was mentioned in this topic
I do see that when you use Spotify connect, it start skipping again.
Did you uninstall V3.03 and reboot before installing V3.0.4?
Hi @Wheaten,
I did uninstall 3.0.3, rebooted and installed 3.0.4 after direct updating failed.
I then Enabled, entered credentials and pressed the āSpotify Loginā button, which seems OK, no errors there.
However, I am still getting the OAuth error when clicking Spotify from the left menu.
error: An error occurred while listing Spotify featured playlists WebapiError: Bad OAuth request
error: An error occurred while listing Spotify new albums WebapiError: Bad OAuth request
yeah, got the same issue now on my 2nd rPi.
Asfar as I understood it, Volumio is hitting Spotify to often, causing a time-out, hence the Bad OAuth or API rate limit error.
There is a work around, but @volumio replied itās not possible.
I also uninstalled, restarted, installed new version, then restarted againā¦
This new version should not hit Apis so hard, so as soon as enough people update to this new version, the issue will be hopefully solved.
In case thatās not true, then we will be recompile vollibrespot with an alternative api key, so those who do update wonāt have such issue
Today, one player is having issues.
Bad 0Auth request
And WebApi Api rate limit was exceeded.
Has anyone else experienced this?
please read the last 10-15 posts in this topic
Yeah sorry, for some reason the post was halfway up the page, and not showing current feed.
Letās hope this will be soon. Currently one working, one failing.
info: Error : CoreCommandRouter::executeOnPlugin: No method [getMultiroom] in plugin multiroom
info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
info: In handleBrowseUri, curUri=spotify
error: An error occurred while listing Spotify featured playlists WebapiError: API rate limit exceeded
error: An error occurred while listing Spotify categories WebapiError: Bad OAuth request
@volumio Are you sure itās that? I was trying at various times of day, including when the US is asleep, when Europe is asleep⦠and I get it with every single click⦠I donāt even get one success⦠seems the odds would be (if itās rate limiting), that I would get 1 success, and this didnāt happen at all with 3.0.3, did the number of users suddenly jump in the last 2 days?
If it can be to any help for you, here“s my log:
http://logs.volumio.org/volumio/eZ1yYGo.html
Keep up your good work!
regards/C
⦠bad Oauth request
Sent logs
http://logs.volumio.org/volumio/eoP8jyr.html
And still heavy volume events over connect
http://logs.volumio.org/volumio/ZhDWhNo.html
Best regards
Josef
i keep my fingers crossed
However is anyone able to play from the Spotify app? I am not, which was working in previous version, so now no working method to play Spotify tracks. Most of the reports are about the Volumio UI at the momentā¦
Spotify app on PC ā connect to Volumio is possible for me
(but sudden Volume changes still appear)
Spotify over Volumio UI is broken with 3.0.4
(uninstall and install 3.0.3 if you need UI function)
Yessā¦me too.
WebApi Api rate limit was exceeded and Bad Oauth request.
Tnx Volumio Teamsā¦
Is a very hard challengeā¦but i know you will win!
Yes, what a challenge! And considering that I donāt get ANY of the symptoms you guys report on my system, makes it even harder to fixā¦
But, not stopping until everything is fine
Josh, I am starting to get some hints on why you have your volume act funny.
2 questions that will help me:
- do you know which plugin uses the process usr/local/bin/admutd.py?
- you have piano dac plus, which has a unique volume implementation. Can you use audio jack out and report if this issue persists?
i removed admutd.py (it is the only modification)
other users also reported the volume behaviour
will test on 3,5mm jack tomorrow
