Hello again! I Uninstall beta Spotify plugin. Update to the latest version of Volumio to 3.324. I restarted Volumio, then looked for the latest version of the Spotify plugin and installed it. And I joined with my Spotify account.
I found the album and played it, everything sounds very good.
But there is a Problem!
As long as I donât touch any button on Playback, everything plays. As soon as I want to press the next song, it does not switch and starts playing the previous one from the beginning.
Also, when I select another song from the album list from the Queue, it is not played, but the previous song starts playing from the beginning.
Sometimes I manage to switch another song from the queue when I pause the previous one and then select from the list. But when I press the next song, the first song starts playing again.
But if nothing is touched, the songs are played according to the list.
Also, the time of the song does not always show the correct one already in the middle of the song, but it shows only a few seconds.
I also added a log:Preformatted textStarting Live LogâŚ
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
wlan0: Failed to initiate sched scan
volumio : unable to resolve host mjas-mzika
volumio : problem with defaults entries ; TTY=unknown ; PWD=/ ; USER=root ;
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
info: CoreCommandRouter::volumioPlay
[SpotifyConnect] unSetVolatile called
info: Spotify Unset Volatile called
[SpotifyConnect] Relinquishing Volumio State to another service
[SpotifyConnect] Spotify Received stop
info: CoreStateMachine::play index 15
info: CoreStateMachine::stop
info: CoreStateMachine::stPlaybackTimer
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CorePlayQueue::getTrack 33
info: CoreStateMachine::serviceStop
info: CoreCommandRouter::serviceStop
[Vollibrespot] : Pause
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, position_ms: 159503 }
[SpotifyConnect] Pause
[SpotifyConnect] pause
info: CoreStateMachine::play index undefined
info: CorePlayQueue::getTrack 15
info: CoreStateMachine::startPlaybackTimer
info: [1658232445431] ControllerSpotify::clearAddPlayTrack
info: Setting this device active
[Vollibrespot] : Event: SinkInactive
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track } }
[SpotifyConnect] Sweetest Pie
info: [1658232445520] ControllerSpotify::pushState
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus stop
[SpotifyConnect] Sink released
info: [1658232445540] ControllerSpotify::pushState
info: CoreStateMachine::syncState stateService stop
info: CoreStateMachine::syncState currentStatus play
info: [1658232445577] ControllerSpotify::clearAddPlayTrack
[SpotifyConnect] Device palyback is inactive
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track } }
[Vollibrespot] : error 400 for uri hm://autoplay-enabled/query?uri=
[Vollibrespot] : AutoplayError: MercuryError
[Vollibrespot] : Loading with Spotify URI
[Vollibrespot] : (201334 ms) loaded
[Vollibrespot] : (153190 ms) loaded
info: [1658232446467] ControllerSpotify::pushState
info: No code
[Vollibrespot] : Event: SinkActive
info: [1658232447107] ControllerSpotify::pushState
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, track_id: SpotifyId { id: 228114634485834096950694739414835929167, audio_type: Track } }
info: No code
[SpotifyConnect] Sink acquired
info: Continuing Spotify Session
info: Checking Spotify Web API
[SpotifyConnect] Vollibrespot Active
info: [1658232447179] ControllerSpotify::pushState
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 228114634485834096950694739414835929167, audio_type: Track } }
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 228114634485834096950694739414835929167, audio_type: Track }, track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track } }
[SpotifyConnect] Ghost
info: [1658232448029] ControllerSpotify::pushState
info: [1658232448059] ControllerSpotify::clearAddPlayTrack
rpi_firmware_get_throttled: 1 callbacks suppressed
Under-voltage detected! (0x000d0005)
info: Is Not Connect Playback
info: [1658232448748] ControllerSpotify::pushState
info: No code
ALSA lib pcm.c:8424:(snd_pcm_recover) underrun occurred
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track } }
info: [1658232449642] ControllerSpotify::pushState
info: [1658232449725] ControllerSpotify::pushState
info: Received Get System Version
info: [1658232450717] ControllerSpotify::pushState
Voltage normalised (0x00080008)
info: CoreCommandRouter::volumioRandom
info: CoreCommandRouter::writePlayerControls
info: CoreStateMachine::setRandom false
info: Spotify Random: false
info: [1658232458658] ControllerSpotify::pushState
[Vollibrespot] : Attempting to resolve page "hm://context-resolve/v1/"
[Vollibrespot] : Event: Shuffle { status: false }
[Vollibrespot] : error 404 for uri hm://context-resolve/v1/
[Vollibrespot] : ContextPollError: MercuryError
info: CoreStateMachine::play index 32
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, position_ms: 12785 }
info: CorePlayQueue::getTrack 32
info: [1658232462039] ControllerSpotify::clearAddPlayTrack
info: [1658232462204] ControllerSpotify::pushState
info: [1658232462231] ControllerSpotify::pushState
info: [1658232462260] ControllerSpotify::clearAddPlayTrack
[Vollibrespot] : (211649 ms) loaded
info: [1658232462996] ControllerSpotify::pushState
info: No code
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, track_id: SpotifyId { id: 152674314396362002746270549442642159350, audio_type: Track } }
info: [1658232464413] ControllerSpotify::pushState
info: No code
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 152674314396362002746270549442642159350, audio_type: Track } }
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 152674314396362002746270549442642159350, audio_type: Track }, track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track } }
[SpotifyConnect] Hot Shit (feat. Ye & Lil Durk)
info: [1658232465856] ControllerSpotify::pushState
info: No code
info: [1658232465930] ControllerSpotify::pushState
info: [1658232466606] ControllerSpotify::pushState
info: CoreCommandRouter::volumioPause
info: CoreStateMachine::pause
info: CoreStateMachine::servicePause
info: CoreCommandRouter::servicePause
info: Spotify Received pause
info: [1658232467910] ControllerSpotify::pushState
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, position_ms: 4786 }
info: [1658232468789] ControllerSpotify::pushState
info: [1658232468803] ControllerSpotify::pushState
info: [1658232470529] ControllerSpotify::clearAddPlayTrack
info: [1658232471648] ControllerSpotify::pushState
info: CoreStateMachine::syncState stateService pause
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 152674314396362002746270549442642159350, audio_type: Track }, position_ms: 285 }
info: [1658232472701] ControllerSpotify::pushState
info: [1658232473389] ControllerSpotify::pushState
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 152674314396362002746270549442642159350, audio_type: Track } }
info: [1658232474519] ControllerSpotify::pushState
info: [1658232474537] ControllerSpotify::pushState
info: [1658232474561] ControllerSpotify::clearAddPlayTrack
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 152674314396362002746270549442642159350, audio_type: Track }, track_id: SpotifyId { id: 152674314396362002746270549442642159350, audio_type: Track } }
info: [1658232476383] ControllerSpotify::pushState
info: No code
info: [1658232479798] ControllerSpotify::pushState
Voltage normalised (0x00080000)
info: [1658232491356] ControllerSpotify::pushState
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, position_ms: 16000 }
info: [1658232491886] ControllerSpotify::pushState
info: [1658232491901] ControllerSpotify::pushState
info: CoreStateMachine::play index 48
info: CorePlayQueue::getTrack 48
info: [1658232493536] ControllerSpotify::clearAddPlayTrack
[Vollibrespot] : (148064 ms) loaded
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, track_id: SpotifyId { id: 264823415039530225937335634782640469355, audio_type: Track } }
info: [1658232494574] ControllerSpotify::pushState
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 264823415039530225937335634782640469355, audio_type: Track } }
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 264823415039530225937335634782640469355, audio_type: Track }, position_ms: 381 }
[SpotifyConnect] SUPERMODEL
info: [1658232495000] ControllerSpotify::pushState
[Vollibrespot] : Event: PlaybackStopped { track_id: SpotifyId { id: 264823415039530225937335634782640469355, audio_type: Track } }
info: [1658232495418] ControllerSpotify::pushState
info: [1658232495449] ControllerSpotify::clearAddPlayTrack
info: [1658232495673] ControllerSpotify::pushState
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 264823415039530225937335634782640469355, audio_type: Track }, track_id: SpotifyId { id: 264823415039530225937335634782640469355, audio_type: Track } }
info: No code
info: [1658232496018] ControllerSpotify::pushState
info: No code
[Vollibrespot] : Event: TrackChanged { old_track_id: SpotifyId { id: 264823415039530225937335634782640469355, audio_type: Track }, track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track } }
info: [1658232496080] ControllerSpotify::pushState
info: No code
info: [1658232497582] ControllerSpotify::pushState
info: [1658232504764] ControllerSpotify::pushState
[Vollibrespot] : Event: Pause { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, position_ms: 8458 }
info: [1658232505331] ControllerSpotify::pushState
info: [1658232505338] ControllerSpotify::pushState
info: CoreCommandRouter::volumioVolatilePlay
info: CoreStateMachine::volatilePlay
info: Spotify Play
info: [1658232506881] ControllerSpotify::pushState
[Vollibrespot] : Event: Play { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track }, position_ms: 8888 }
[SpotifyConnect] play
info: [1658232507406] ControllerSpotify::pushState
info: CoreCommandRouter::volumioNext
info: CoreStateMachine::next
info: Spotify next
[Vollibrespot] : Event: Next { track_id: SpotifyId { id: 321686394502750714320166474221213508625, audio_type: Track } }
info: [1658232509776] ControllerSpotify::pushState
info: [1658232509783] ControllerSpotify::pushState
info: [1658232509794] ControllerSpotify::clearAddPlayTrack
info: [1658232510706] ControllerSpotify::pushState
info: No code
info: [1658232511169] ControllerSpotify::pushState
info: No code
info: WARNING: Cannot execute Action because no volatile plugin is defined
info: WARNING: No play method for volatile plugin undefined
process exited with code null`Preformatted text`
