you need the touch display plugin… no matter what…
we have to wait for @gvolt he knows more than me …
I know, did the reinstall and no improvement…
here’s some info
Blockquote
ls -al /usr/share/X11/xorg.conf.d
total 40
drwxr-xr-x 2 root root 4096 Jul 9 08:29 .
drwxr-xr-x 1 root root 4096 Jul 9 08:38 …
-rw-r–r-- 1 root root 1099 Sep 24 2016 10-evdev.conf
-rw-r–r-- 1 root root 1350 Nov 11 2016 10-quirks.conf
-rw-r–r-- 1 root root 776 Jul 9 08:27 40-libinput.conf
-rw-r–r-- 1 root root 1099 Jul 9 08:17 45-evdev.conf
-rw-r–r-- 1 root root 2747 Oct 28 2016 70-wacom.conf
-rw-r–r-- 1 root root 609 Jul 9 08:01 99-fbturbo.conf
Blockquote
Blockquote
ls -al /dev/input
total 0
drwxr-xr-x 3 root root 120 Jul 9 08:35 .
drwxr-xr-x 15 root root 3800 Jul 9 08:35 …
drwxr-xr-x 2 root root 60 Jul 9 08:35 by-path
crw-rw---- 1 root input 13, 64 Jul 9 08:35 event0
crw-rw---- 1 root input 13, 63 Jul 9 08:35 mice
crw-rw---- 1 root input 13, 32 Jul 9 08:35 mouse0
Blockquote
cat /dev/input/event0 doesn’t detect anything
still shows “40-libinput.conf”. After renaming it to “40-libinput.conf.bak” reboot.
because I changed it back.
But now I did it again.
total 40
drwxr-xr-x 2 root root 4096 Jul 9 09:00 .
-rw-r–r-- 1 root root 776 Jul 9 08:27 40-libinput.conf.bak
Ok.
Please post the output of
cat /var/log/Xorg.0.log
Okay, something is wrong…
[ 39.789]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 39.789] X Protocol Version 11, Revision 0
[ 39.789] Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
[ 39.789] Current Operating System: Linux touchvol 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
[ 39.789] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=480 bcm2708_fb.fbheight=320 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:CF:54:AA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash quiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyS0,115200 kgdboc=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=0 snd-bcm2835.enable_compat_alsa=1 snd_bcm2835.enable_headphones=1
[ 39.789] Build Date: 11 November 2016 11:59:59AM
[ 39.789] xorg-server 2:1.18.4-2+rpi1 (Debian -- User Support)
[ 39.789] Current version of pixman: 0.32.6
[ 39.789] Before reporting problems, check http://wiki.x.org
[ 39.790] Markers: (–) probed, () from config file, (==) default setting,
[ 39.790] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jul 9 09:01:29 2021
[ 39.793] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 39.793] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 39.800] (==) No Layout section. Using the first Screen section.
[ 39.800] (==) No screen section available. Using defaults.
[ 39.800] () |–>Screen “Default Screen Section” (0)
[ 39.800] () | |–>Monitor “”
[ 39.804] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 39.804] () | |–>Device “Allwinner A10/A13/A20 FBDEV”
[ 39.804] (==) No monitor specified for screen “Default Screen Section”.
[ 39.804] (==) Automatically adding devices
[ 39.804] (==) Automatically enabling devices
[ 39.804] (==) Automatically adding GPU devices
[ 39.807] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 39.809] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 39.809] Entry deleted from font path.
[ 39.812] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 39.812] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 39.812] (II) The server relies on udev to provide the list of input devices.
[ 39.812] (II) Loader magic: 0x613f20
[ 39.812] (II) Module ABI versions:
[ 39.812] X.Org ANSI C Emulation: 0.4
[ 39.812] X.Org Video Driver: 20.0
[ 39.812] X.Org XInput driver : 22.1
[ 39.812] X.Org Server Extension : 9.0
[ 39.814] (–) using VT number 2
[ 39.814] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 39.814] (II) no primary bus or device found
[ 39.815] (II) LoadModule: “glx”
[ 39.817] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 39.855] (II) Module glx: vendor=“X.Org Foundation”
[ 39.855] compiled for 1.18.4, module version = 1.0.0
[ 39.855] ABI class: X.Org Server Extension, version 9.0
[ 39.855] (==) AIGLX enabled
[ 39.855] (II) LoadModule: “fbturbo”
[ 39.856] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 39.859] (II) Module fbturbo: vendor=“X.Org Foundation”
[ 39.859] compiled for 1.18.4, module version = 0.5.1
[ 39.859] Module class: X.Org Video Driver
[ 39.859] ABI class: X.Org Video Driver, version 20.0
[ 39.859] (II) FBTURBO: driver for framebuffer: fbturbo
[ 39.860] (WW) Falling back to old probe method for fbturbo
[ 39.860] (II) Loading sub module “fbdevhw”
[ 39.860] (II) LoadModule: “fbdevhw”
[ 39.860] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 39.862] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 39.862] compiled for 1.18.4, module version = 0.0.2
[ 39.862] ABI class: X.Org Video Driver, version 20.0
[ 39.862] (II) FBTURBO(0): using /dev/fb1
[ 39.862] (II) FBTURBO(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 16/16
[ 39.862] (==) FBTURBO(0): Depth 16, (==) framebuffer bpp 16
[ 39.862] (==) FBTURBO(0): RGB weight 565
[ 39.862] (==) FBTURBO(0): Default visual is TrueColor
[ 39.862] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 39.862] (II) FBTURBO(0): hardware: fb_ili9486 (video memory: 300kB)
[ 39.862] () FBTURBO(0): Option “fbdev” “/dev/fb1”
[ 39.862] () FBTURBO(0): Option “SwapbuffersWait” “true”
[ 39.863] (II) FBTURBO(0): processor: Unknown
[ 39.863] (II) FBTURBO(0): checking modes against framebuffer device…
[ 39.863] (II) FBTURBO(0): checking modes against monitor…
[ 39.863] (–) FBTURBO(0): Virtual size is 480x320 (pitch 480)
[ 39.863] () FBTURBO(0): Built-in mode “current”
[ 39.863] (==) FBTURBO(0): DPI set to (96, 96)
[ 39.863] (II) Loading sub module “fb”
[ 39.863] (II) LoadModule: “fb”
[ 39.864] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 39.868] (II) Module fb: vendor=“X.Org Foundation”
[ 39.868] compiled for 1.18.4, module version = 1.0.0
[ 39.868] ABI class: X.Org ANSI C Emulation, version 0.4
[ 39.868] (II) FBTURBO(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 39.879] (II) FBTURBO(0): using backing store heuristics
[ 39.885] (II) FBTURBO(0): can’t load ‘g2d_23’ kernel module
[ 39.885] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[ 39.885] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[ 39.885] (II) FBTURBO(0): G2D hardware acceleration can’t be enabled
[ 39.885] (II) FBTURBO(0): enabled VFP/NEON optimizations
[ 39.885] (==) FBTURBO(0): Backing store enabled
[ 39.890] (==) FBTURBO(0): DPMS enabled
[ 39.890] (II) FBTURBO(0): failed to enable hardware cursor
[ 39.890] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[ 39.890] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[ 39.891] (==) RandR enabled
[ 39.907] (II) SELinux: Disabled on system
[ 39.912] (II) AIGLX: Screen 0 is not DRI2 capable
[ 39.912] (EE) AIGLX: reverting to software rendering
[ 40.724] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 40.726] (II) AIGLX: Loaded and initialized swrast
[ 40.726] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 40.884] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event0)
[ 40.884] () ADS7846 Touchscreen: Applying InputClass “evdev touchscreen catchall”
[ 40.884] () ADS7846 Touchscreen: Applying InputClass “Touch rotation”
[ 40.884] () ADS7846 Touchscreen: Applying InputClass “calibration”
[ 40.884] (II) LoadModule: “evdev”
[ 40.884] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 40.894] (II) Module evdev: vendor=“X.Org Foundation”
[ 40.894] compiled for 1.18.4, module version = 2.10.3
[ 40.894] Module class: X.Org XInput Driver
[ 40.894] ABI class: X.Org XInput driver, version 22.1
[ 40.894] (II) Using input driver ‘evdev’ for ‘ADS7846 Touchscreen’
[ 40.895] () ADS7846 Touchscreen: always reports core events
[ 40.895] () evdev: ADS7846 Touchscreen: Device: “/dev/input/event0”
[ 40.895] (–) evdev: ADS7846 Touchscreen: Vendor 0 Product 0
[ 40.895] (–) evdev: ADS7846 Touchscreen: Found absolute axes
[ 40.895] (–) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 40.895] (–) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 40.895] () Option “SwapAxes” “1”
[ 40.895] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 40.895] () Option “EmulateThirdButton” “1”
[ 40.895] () Option “EmulateThirdButtonTimeout” “1000”
[ 40.895] () Option “EmulateThirdButtonMoveThreshold” “300”
[ 40.895] () evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 40.895] () evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 40.895] () Option “config_info” “udev:/sys/devices/platform/soc/fe204000.spi/spi_master/spi0/spi0.1/input/input0/event0”
[ 40.895] (II) XINPUT: Adding extended input device “ADS7846 Touchscreen” (type: TOUCHSCREEN, id 6)
[ 40.895] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 40.895] () ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 40.895] () ADS7846 Touchscreen: (accel) acceleration profile 0
[ 40.895] () ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 40.896] () ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 40.896] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse0)
[ 40.896] () ADS7846 Touchscreen: Applying InputClass “calibration”
[ 40.896] (II) Using input driver ‘evdev’ for ‘ADS7846 Touchscreen’
[ 40.896] () ADS7846 Touchscreen: always reports core events
[ 40.896] () evdev: ADS7846 Touchscreen: Device: “/dev/input/mouse0”
[ 40.896] (EE) evdev: ADS7846 Touchscreen: Unable to query fd: Inappropriate ioctl for device
[ 40.980] (EE) PreInit returned 2 for “ADS7846 Touchscreen”
[ 40.980] (II) UnloadModule: “evdev”
[ 41.031] (II) evdev: ADS7846 Touchscreen: Close
[ 41.031] (II) UnloadModule: “evdev”
[ 41.042] (II) FBTURBO(0): using backing store heuristics
[ 41.047] (II) FBTURBO(0): can’t load ‘g2d_23’ kernel module
[ 41.047] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[ 41.047] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[ 41.047] (II) FBTURBO(0): G2D hardware acceleration can’t be enabled
[ 41.047] (II) FBTURBO(0): enabled VFP/NEON optimizations
[ 41.048] (==) FBTURBO(0): DPMS enabled
[ 41.048] (II) FBTURBO(0): failed to enable hardware cursor
[ 41.048] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[ 41.048] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[ 41.048] (==) RandR enabled
[ 41.061] (II) SELinux: Disabled on system
[ 41.063] (II) AIGLX: Screen 0 is not DRI2 capable
[ 41.063] (EE) AIGLX: reverting to software rendering
[ 41.068] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 41.069] (II) AIGLX: Loaded and initialized swrast
[ 41.069] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 41.172] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event0)
[ 41.172] () ADS7846 Touchscreen: Applying InputClass “evdev touchscreen catchall”
[ 41.172] () ADS7846 Touchscreen: Applying InputClass “Touch rotation”
[ 41.172] () ADS7846 Touchscreen: Applying InputClass “calibration”
[ 41.172] (II) Using input driver ‘evdev’ for ‘ADS7846 Touchscreen’
[ 41.172] () ADS7846 Touchscreen: always reports core events
[ 41.172] () evdev: ADS7846 Touchscreen: Device: “/dev/input/event0”
[ 41.172] (–) evdev: ADS7846 Touchscreen: Vendor 0 Product 0
[ 41.172] (–) evdev: ADS7846 Touchscreen: Found absolute axes
[ 41.172] (–) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 41.172] (–) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 41.172] () Option “SwapAxes” “1”
[ 41.172] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 41.172] () Option “EmulateThirdButton” “1”
[ 41.172] () Option “EmulateThirdButtonTimeout” “1000”
[ 41.172] () Option “EmulateThirdButtonMoveThreshold” “300”
[ 41.172] () evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 41.172] () evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 41.172] () Option “config_info” “udev:/sys/devices/platform/soc/fe204000.spi/spi_master/spi0/spi0.1/input/input0/event0”
[ 41.172] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 41.172] () ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 41.172] () ADS7846 Touchscreen: (accel) acceleration profile 0
[ 41.173] () ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 41.173] () ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 41.173] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse0)
[ 41.173] () ADS7846 Touchscreen: Applying InputClass “calibration”
[ 41.173] (II) Using input driver ‘evdev’ for ‘ADS7846 Touchscreen’
[ 41.173] () ADS7846 Touchscreen: always reports core events
[ 41.173] (**) evdev: ADS7846 Touchscreen: Device: “/dev/input/mouse0”
[ 41.173] (EE) evdev: ADS7846 Touchscreen: Unable to query fd: Inappropriate ioctl for device
[ 41.290] (EE) PreInit returned 2 for “ADS7846 Touchscreen”
[ 41.290] (II) UnloadModule: “evdev”
I am not sure you are using the correct overlay file. Could you post pictures of the display’s PCB (front and back)?
Thanks, according to this the MHS-3.5 is a clone of the Waveshare 3.5inch RPi LCD (C).
Maybe try out the Waveshare overlay (on your own risk
wget https://github.com/waveshare/LCD-show/raw/master/waveshare35c-overlay.dtb
sudo cp waveshare35c-overlay.dtb /boot/overlays/waveshare35c-overlay.dtbo
In /boot/userconfig.txt change
dtoverlay=mhs35:rotate=90
to
dtoverlay=waveshare35c:rotate=90
Edit: Corrected download address for Waveshare overlay.
It could be, it was a cheap aliexpress screen I once bought. I will test it!
waveshare35c-overlay.dtb isn’t on the page of LCD-show/usr at master · goodtft/LCD-show · GitHub
but I found it!
Sorry, my bad… I have corrected the download address.
Now it doesn’t detect the screen :-/
41.233] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 41.234] (II) no primary bus or device found
[ 41.235] (II) LoadModule: “glx”
[ 41.236] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 41.274] (II) Module glx: vendor=“X.Org Foundation”
[ 41.274] compiled for 1.18.4, module version = 1.0.0
[ 41.274] ABI class: X.Org Server Extension, version 9.0
[ 41.274] (==) AIGLX enabled
[ 41.274] (II) LoadModule: “fbturbo”
[ 41.275] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 41.278] (II) Module fbturbo: vendor=“X.Org Foundation”
[ 41.278] compiled for 1.18.4, module version = 0.5.1
[ 41.278] Module class: X.Org Video Driver
[ 41.278] ABI class: X.Org Video Driver, version 20.0
[ 41.278] (II) FBTURBO: driver for framebuffer: fbturbo
[ 41.279] (WW) Falling back to old probe method for fbturbo
[ 41.279] (II) Loading sub module “fbdevhw”
[ 41.279] (II) LoadModule: “fbdevhw”
[ 41.279] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 41.281] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 41.281] compiled for 1.18.4, module version = 0.0.2
[ 41.281] ABI class: X.Org Video Driver, version 20.0
[ 41.281] (EE) open /dev/fb1: No such file or directory
[ 41.281] (EE) No devices detected.
[ 41.281] (EE)
Fatal server error:
[ 41.281] (EE) no screens found(EE)
[ 41.282] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 41.282] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 41.282] (EE)
Do you have the chance to test if touch works with e.g. Raspberry Pi OS?
Before doing that maybe try removing the options "EmulateThirdButton… from “/etc/X11/xorg.conf.d/99-calibration.conf”.
I’m testing it now, but it worked in the past, I guess yesterday I did a test to make sure it works.
it doesn’t work with a new Raspberry Pi OS, going to test an old one.
It says something about the evdev
Scanning dependencies of target fbcp
[ 50%] Building C object CMakeFiles/fbcp.dir/main.c.o
[100%] Linking C executable fbcp
[100%] Built target fbcp
2021
need to update touch configuration
Voorheen niet geselecteerd pakket xserver-xorg-input-evdev wordt geselecteerd.
(Database wordt ingelezen … 101407 bestanden en mappen momenteel geïnstalleerd.)
Uitpakken van …/xserver-xorg-input-evdev_1%3a2.10.6-1+b1_armhf.deb wordt voorbereid…
Bezig met uitpakken van xserver-xorg-input-evdev (1:2.10.6-1+b1) …
Instellen van xserver-xorg-input-evdev (1:2.10.6-1+b1) …
Bezig met afhandelen van triggers voor man-db (2.8.5-2) …
reboot now
Connection to raspberrypi closed by remote host.
Connection to raspberrypi closed.
-_- The Touchfunction doesn’t work anymore, even with the provided OS
on MHS-3.5inch RPi Display - LCD wiki
2 days lost…
What a bummer!
I have just purchased this touchscreen and I have tried everything, when I cat /dev/input/event0 and touch the screen, I get a load of garbage on the screen. So it seems that the touchscreen is working but not calibrated.
how can I fix this issue.
Also how do I install the touchscreen drivers.
Lawrence
