could you tell me exactly in what order I need to add which rules and if I should try another version of volumio to make it work?
I can do a clean install again if you want
If â40-libinput.confâ should be the issue I would just rename the file â/usr/share/X11/xorg.conf.d/40-libinput.confâ to â/usr/share/X11/xorg.conf.d/40-libinput.conf.bakâ:
rename the libinput to evdev as driver in that config but i gonna rename it again for you.
# Match on all types of devices but joysticks
# If you want to configure your devices, do not copy this file.
# Instead, use a config snippet that contains something like this:
# Section "InputClass"
# Identifier "something or other"
# MatchDriver "libinput"
# MatchIsTouchpad "on"
# ... other Match directives ...
# Option "someoption" "value"
# EndSection
# This applies the option any libinput device also matched by the other
# directives. See the xorg.conf(5) man page for more info on
# matching devices.
Identifier "libinput pointer catchall"
MatchIsPointer "on"
MatchDevicePath "/dev/input/event*"
Driver "evdev"
EndSection
Identifier "libinput keyboard catchall"
MatchIsKeyboard "on"
Driver "evdev"
EndSection
Identifier "libinput touchpad catchall"
Driver "evdev"
EndSection
Identifier "libinput touchscreen catchall"
MatchIsTouchscreen "on"
Driver "evdev"
EndSection
Identifier "libinput tablet catchall"
MatchIsTablet "on"
Driver "evdev"
EndSection
Iâm doing the reinstallation, I will do all my steps like I mentioned, and then this?
=> sudo mv /usr/share/X11/xorg.conf.d/40-libinput.conf /usr/share/X11/xorg.conf.d/40-libinput.conf.bak
sudo nano /usr/share/X11/xorg.conf.d/40-libinput.conf
=> change liginput to evdev
First try without this last step and check, if renaming â40-libinput.confâ suffices. If it should not work copy â40-libinput.conf.bakâ to â/etc/X11/xorg.conf.d/40-libinput.confâ. Then change the content of â/etc/X11/xorg.conf.d/40-libinput.confâ as proposed by @dvo.
