Click on the “burger” sign displayed in the left upper corner of Volumio’s UI then choose “System”. On the system settings page look for “System Version”.
I just re-did the installation and below are the results.
Not sure if this is relevent but this is the only errors I see.
grep: /etc/lightdm/lightdm.conf: No such file or directory
/usr/bin/raspi-config: 2049: [: Illegal number: W1
/usr/bin/raspi-config: 2052: [: Illegal number: W1
/usr/bin/raspi-config: 2059: [: Illegal number: W1
/usr/bin/raspi-config: 2067: return: Illegal number: W1
On the screen I see multiple processes that have been started successfully, and then I am given a prompt to login.
I have raspian install. The pi is only called Domoticz because that is what I was playing with before getting the screen as a present.
I can reimage and restart, if this is necessary.
I would not recommend to run the script from goodtft’s GitHub repository. Instead try the following:
Start with a fresh Volumio system.
Install the Touch Display plugin from Volumio’s plugin store: Click on the “burger” sign displayed in the left upper corner of Volumio’s UI then choose “Plugins”. On the tab “Search Plugins” choose “User Interface”. From there install the Touch Display plugin.
