i used this sensor for it and it works with odroid remote, so the used lirc file in the infrared plugin is good.
Thanks both for your speedy help. Iāll order the sensor and give that a go.
I am using the same one and itās working with 3 different remotes.
- NAD AMP3
- Pro-ject - Control it
- And some vage Chinese remote.
I almost ordered that sensor last week when I ordered the module from Tinytronics, would have saved me time and postage!
As we say in Dutch:
Achteraf is een koe in haar kont kijken
(Which translate very wrong to English
hahaha ja dat ziet er niet uit in het engels ![]()
Koe hoeft niet meer in haar kont te kijken. Sensor arrived (Tinytronics are FAST!) and all is well. Just have to avoid the red power off button.
Thanks for your advice yesterday.
Huh your IR-Receiver came with a power off button, or hold you me in front of a cloth?
No cloths! I have vol+/- , mute, power off (unfortunately), skip forward/back, pause, next/previous track. Only the home, back arrow and burger buttons are inactive. Pretty impressive.
Seems all buttons have been implemented:
Home = clear
back arrow = repeat
Menu = random
Great. Busy making a neater (soldered) job of the sensor, Iāll try that later. I might try disabling the power button though.
just remove or comment out:
begin
prog = irexec
button = Power
config = /usr/bin/sudo systemctl poweroff
end
Brilliant! And yes the other buttons work, except I think, home/clear. Is that supposed to clear the playlist?
Yes it does. these are the default available commands:
[[PLAYBACK STATUS]]
status Gives Playback status information
volume Gives Current Volume Information
volume <desired volume> Sets Volume at desired level 0-100
volume mute Mutes
volume unmute Unmutes
volume toggle Mutes/Unmutes
volume plus Increases Volume of one step
volume minus Decreases Volume of one step
seek plus Forwards 10 seconds in the song
seek minus Backwards 10 seconds in the song
seek <seconds> Plays song from selected time
repeat Toggles repetition of queue
random Toggles randomization of queue
[[PLAYBACK CONTROL]]
play
pause
toggle Toggles between play/pause
next
previous
stop
clear
I would have been happy with vol +/- and mute!
I edited /etc/lirc/lircrc , commenting out
begin
prog = irexec
button = Power
end
However it restores the uncommented version of the file after restart/reboot. Am I editing the wrong file?
I assume you use the plugin, then yes wrong file?
then you need to edit in /data/plugins/system_hardware/ir_controller/configurations
Perfect! Thanks.
And thanks @gvolt for another fantastic plugin.
@SimonE Thank you.
Be aware that your changes to configurations in ā/data/plugins/system_hardware/ir_controller/configurationsā will be overwritten on each update of the plugin. I recommend to create your own configuration in ā/data/INTERNAL/ir_controller/configurationsā as I have described here.
Maybe not for this thread but after upgrading to 3.569 and using the Justboom remote to shut down the Raspi, now it is restarting instead of shutting down.
Before 3.569, never had this problem.
Anybody knowing what I could check to solve this?
Thanks.
Regards,
Ad.
