What hardware do you use?
Is your system connceted to network by LAN or WLAN?
Does powering off via Volumio’s UI work?
Did you possibly modify “lircrc” or “lircd.conf” from the plugin’s “JustBoom IR Remote” configuration?
- using a RPI 3b+, which I am using for a longer period of time including IR
- I am using LAN
- yes, via Volumio UI it stops
- I did not change anything. Only installing the IR remote plugin.
Everything else is working via the remote Justboom.
Thanks for the quick reply.
Please check if the problem persists when the system is disconnected from LAN (but eventually connected to WLAN).
Also, does executing
systemctl poweroff
from Volumio’s command line work or does the system reboot, too?
I didn’t had the time yesterday to reply you.
Without LAN it’s rebooting, using WLAN also rebooting.
systemctl poweroff : also rebooting. That’s weird I should say.
Well, at least the behavior is consistent…
Do you have any other hardware connected that may be preventing the shutdown?
I use Ian Canada’s stationpi pro and other stuff but I did also before using 3.569 and it worked perfectly.
Maybe I will try an older version of Volumio if that hardware is interfering the shutdown.
Using the Volumio UI it shuts down. why not via executing the systemctl?
I suggest to try executing
sync
systemctl poweroff
If that should not help disconnect all other hardware from the Pi and test systemctl poweroff again.
Good question ![]()
Using the UI does also restarts it, it took only much longer… sorry for that
Somehow the poweroff command is now restarting in instead going done.
That is one more reason to test with all other hardware disconnected from the Pi.
