Have Volumio transferred to internal HD USB not seen in program
A fresh 1 TB SSD, loaded Volumio via Belena E to usb , ran a copule times off of USB then finally transferred to internal SSD. Great, Boots right in to Volumio. Now, I formated a 256GB Flash Drive with Exfat and transferred all my music to it under File called Music.220 GB approx… Volumio does not see the flash drive???:frowning: any help here. THanks !!!
BJ
See step 2:
I’m glad you mentioned SSH, once in Volumio, how do I access SSH or the terminal?? Or during boot do I hit some key to get me to the terminal window? I’m a windows user coming over to Linux:)
You don’t need SSH, just label your Flash drive correct.
If you insist on getting SSH access, google is your friend
Not adding any plug ins for just want it to play through my USB DAC… I’ve done the install various ways, Ex Fac, NT …bottom line when all is running and I plug in my UBS stick of music files does not see it . Not seeing my USB with a folder saying Music, full of albums of wave file… Before i move onto another os like Delphile…any input ? Thanks
