[Beginner's Guide]: Adding Storage Disk to Volumio (HDD, SSD, NVMe, SD CARD)
What this guide covers
Volumio can automatically detect and mount additional storage disks for your music library. This works on any Volumio installation - Raspberry Pi, x86, official hardware, community ports - across Volumio 3 and Volumio 4.
Step 1: Identify your boot disk
Volumio boots from one disk. That disk already contains three partitions (boot, volumio, volumio_data). Do not format, relabel, or repartition the boot disk.
If you are unsure which disk is the boot disk, SSH into Volumio and run:
sudo lsblk -f
The boot disk has partitions labeled “boot”, “volumio”, and “volumio_data”. Common boot disks:
  • mmcblk0 - SD card (Raspberry Pi default)
  • sda - USB stick, USB SSD, or SATA drive (x64 default, or Pi booting from USB)
  • nvme0n1 - NVMe SSD (Pi5 after “Install to Disk”, or x64 with NVMe)
Step 2: Understand the label system
Volumio recognizes four filesystem labels (case-sensitive):
  • issd
  • ihdd
  • Internal SSD
  • Internal HDD
Any non-boot disk carrying one of these labels will be automatically mounted as internal storage and appear in the Music Library.
Multiple internal disks are supported. Each disk with a recognized label will be mounted.
Note: USB-connected drives are detected automatically regardless of label. The label system described here is for non-USB attached storage such as NVMe, SATA, or secondary SD cards.
Step 3: Prepare the disk
The disk needs a supported filesystem with one of the recognized labels. Supported filesystems: ext4, FAT32, exFAT, NTFS.
The preferred method is to create a partition table with a single partition spanning the full capacity. Whole-disk filesystems (no partition table) are also handled, but test your particular case to confirm reliable operation.
Choose the method that matches your situation.
All methods below erase the target disk. Back up any data first. Make sure you are working on the correct disk - not the boot disk identified in Step 1.
From a Windows PC:
  1. Connect the disk to your Windows PC
  2. Open Disk Management (right-click Start button, select “Disk Management”)
  3. Delete any existing partitions on the target disk
  4. Right-click unallocated space, select “New Simple Volume”
  5. Use the full disk size
  6. Format as FAT32 (32GB or smaller) or exFAT (larger than 32GB)
  7. Set the Volume Label to: issd
  8. Complete the wizard and safely eject
Windows cannot create ext4 partitions without third-party tools. FAT32 or exFAT work fine.
From a Mac:
  1. Connect the disk
  2. Open Disk Utility (Applications → Utilities → Disk Utility)
  3. Select the physical disk (not a partition)
  4. Click “Erase”
  5. Name: issd
  6. Format: MS-DOS (FAT) for 32GB or smaller, ExFAT for larger
  7. Scheme: Master Boot Record
  8. Click “Erase” and safely eject
From a Linux desktop using GParted:
  1. Open GParted, select the correct disk from the dropdown
  2. Device → Create Partition Table → msdos (MBR) → Apply
  3. Create a new partition using the full disk
  4. Format as ext4
  5. Right-click the partition → Label File System → enter: issd
  6. Apply all operations and safely eject
If using GNOME Disks: use “Format Disk” first to create a partition table, then create a partition, then format. Formatting a whole disk directly in GNOME Disks creates a filesystem without a partition table.
From Volumio via SSH:
  1. Enable SSH at http://volumio.local/dev
  2. Connect: ssh volumio@volumio.local (password: volumio)
  3. Identify the target disk: sudo lsblk -f
  4. Create partition table, partition, and filesystem:
    For NVMe (example: /dev/nvme0n1):
    sudo parted /dev/nvme0n1 --script mklabel msdos
    sudo parted /dev/nvme0n1 --script mkpart primary ext4 0% 100%
    sudo mkfs.ext4 -L issd /dev/nvme0n1p1
    For SATA/USB (example: /dev/sda):
    sudo parted /dev/sda --script mklabel msdos
    sudo parted /dev/sda --script mkpart primary ext4 0% 100%
    sudo mkfs.ext4 -L issd /dev/sda1
    Adjust the device name to match your disk.
  5. Reboot: sudo reboot
Relabeling an existing disk (without erasing data)
If the disk already has a formatted partition and you only need to change the label:
Format Command
ext4: sudo e2label /dev/sdX1 issd
FAT32: sudo fatlabel /dev/sdX1 issd
exFAT: sudo exfatlabel /dev/sdX1 issd
NTFS: sudo ntfslabel /dev/sdX1 issd
Replace /dev/sdX1 with your actual partition device. Then reboot Volumio.
Step 4: Connect and rescan
  1. Connect the labeled disk to your Volumio device (or reboot if already connected)
  2. Wait for Volumio to fully boot (1-3 minutes)
  3. Go to Settings → My Music → Rescan
  4. Music appears under Internal Storage in the Music Library
To copy music from a network computer:
  • Windows: open \\volumio.local\Internal Storage in File Explorer
  • macOS: Finder → Go → Connect to Server → smb://volumio.local
  • Linux: file manager address bar → smb://volumio.local
Verification
If the disk does not appear, SSH into Volumio and run:
sudo lsblk -f
sudo blkid
Check that the disk shows a supported filesystem type, the correct label, and a mount point.
Things to avoid
  • Do not edit /etc/fstab manually. This can cause boot failures and breaks OTA updates.
  • Do not create manual symlinks to /var/lib/mpd/music/. Volumio manages this automatically.
  • Do not edit /boot/config.txt or /boot/volumioconfig.txt for disk mounting purposes.
  • Do not use labels that match Volumio system partitions: boot, volumio, volumio_data.
  • Do not format or relabel any partition on the boot disk.
Troubleshooting
Disk not visible in Music Library:
Verify label and filesystem type using lsblk -f and blkid.
Permission denied when copying via network share:
From SSH: sudo chown -R volumio:volumio /data/INTERNAL
Boot failure after adding disk:
Usually caused by manual /etc/fstab entries. Remove the fstab entry and use the label method.
Disk was previously a Volumio boot disk:
Wipe the disk and create a single partition with a recognized label. Volumio ignores partitions named boot, volumio, or volumio_data.
That’s a handy guide with everything in once place, thanks!
It’s easy to forget the windows explorer network address to access connected storage. I must have locked down my network at some point, asking to enter credentials (password) to connect. Does uPnP have to be turned on in the router settings?
Hey @G-rig,
Thanks for the kind words.
On the credentials prompt - this is a Windows-side change, not your router. Windows 10 (from build 1709 onward) and Windows 11 disabled anonymous/guest SMB access by default as a security measure. Volumio shares are configured for guest access, so the two conflict.
When Windows prompts for credentials, enter:
Username: volumio
Password: volumio
This should get you in without any changes to your system.
If you prefer not to be prompted at all, you can re-enable guest access in Windows:
  1. Open Group Policy Editor (press Win+R, type gpedit.msc, press Enter)
  2. Navigate to: Computer Configuration → Administrative Templates → Network → Lanman Workstation
  3. Find “Enable insecure guest logons”, set it to Enabled
  4. Restart the computer
Note: gpedit.msc is not available on Windows Home editions. The registry equivalent is:
 HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\LanmanWorkstation
 DWORD: AllowInsecureGuestAuth = 1
On the UPnP question - router UPnP is not related to accessing Volumio’s storage. UPnP on the router handles automatic port forwarding for internet-facing services. Samba file sharing operates entirely within your local network and does not need it.
If Volumio does not appear under “Network” in File Explorer, you can always reach it directly by typing one of these in the File Explorer address bar:
\\volumio.local
\\<your_volumio_IP_address>
This bypasses network discovery entirely.
Volumio makes adding extra storage easy: just format the new disk with a supported filesystem (ext4, FAT32, exFAT, NTFS) and label it with a recognized name like issd or ihdd. Volumio will auto-mount it as internal storage—no manual fstab edits needed. Then rescan your library, and your music will appear under Internal Storage. Always avoid touching the boot disk and back up data before formatting.
In my case, the volumio user doesn’t work for accessing the shared resource. If I don’t change the Windows group policies, I can’t access it at all.
To avoid modifying that setting in Windows, I came up with another solution. Seeing that the owner of the music files is “nobody,” I added that user to Samba with:
smbpasswd -a nobody
and logged in with that user. That way, everything I upload will be under the correct user account.
Would this work, or could it cause any problems?
I connected to the system through SSH and created a partition formatted in ext4 format using the above steps. I was able to see the capacity smoothly and accessed the IP address through a right slash on the WINDOWS platform to see the disk. However, when copying files, it prompted me that I do not have permission. What should I do
Awesome. Thanks @nerd
Hello, the volumio date partition still has 50G of free space. How can I quickly copy music to the volumio date partition? Thanks!
Hey @Fire,
Volumio already exposes the data partition’s Internal Storage area as a Samba share. No SSH, no manual mounting, no fstab editing required.
From your computer on the same network:
  • Windows: open \\volumio.local in File Explorer (or \<volumio_IP>)
  • Linux: smb://volumio.local in your file manager
You will see a share called “Internal Storage”. Drop your music files in there.
If asked for credentials:
Username: volumio Password: volumio
Once the copy is finished, go to Settings → My Music and rescan the library. Your files will appear under Music Library → Internal Storage.
For best transfer speed use wired ethernet on both ends. Wifi will work but will be considerably slower for a large copy.
Thanks,it’s usefull for me.
Hello - my NVME is named issd but Volumio doesn’t see the drive - if I run the Pi OS on the same Pi 5 the NVME can be seen, accessed etc - why doesnt Volumio see it?
@Cedric
Please read the opening post follow the steps and share the results if failing.
(also check if the flat ribbon cable is correctly mounted. Side for the Pi is not equal to the side of the board, direction matters)
It turns out that the cable was faulty, a replacement has fixed the issue.
Thanks for this guide, it helped me understand how Volumio handles external storage.
However, I am running into a permissions issue with an external USB drive and I am wondering if this is expected behaviour.
My setup:
  • Volumio 4 on Raspberry Pi
  • External 500 GB USB drive formatted as exFAT
  • Drive is automatically mounted by Volumio at /media/external
  • SMB and SFTP access both work
The problem is that the drive is mounted as root:root with the following options:
/dev/sda1 on /media/external type exfat (rw,noatime,fmask=0022,dmask=0022,...)
As a result, the volumio user cannot write to the drive:
touch /media/external/test.txt
Permission denied
while:
sudo touch /media/external/test.txt
works fine.
I also noticed that SMB shares appear read-only from macOS Finder and uploads via SFTP fail for the same reason.
If I manually remount the drive using:
sudo mount -t exfat -o uid=1000,gid=1000,umask=000,fmask=000,dmask=000 /dev/sda1 /media/external
everything works correctly and I can upload files via SMB and SFTP.
After a reboot, Volumio mounts the drive again with the original options and the problem returns.
Is this the expected behaviour for exFAT USB drives in Volumio 4?
Is there a supported way to make an external exFAT USB drive writable for the volumio user without reformatting the drive or manually remounting it after every reboot?
The drive contains important data, so I would prefer not to reformat it.
I’ve reported this behavior to Volumio a few weeks ago.
You’ll also will notice that data from plugins, like FusionDSP, is written to the USN disk.
As workaround, I didn’t rely on the labels issd, ihdd, Internal SSD, Internal HDD but labelled the disk as FLAC.
It;s then not mounted on /data/INTERNAL but on /media/FLAC. Still owned by root but with chmod 777
volumio@rivo-e50-l50:~$ ls -als /media/FLAC
total 80
8 drwxrwxrwx 1 root root 8192 Jun 26 20:17
My drive is already mounted under /media/external and not under /data/INTERNAL, but permissions are 755 (drwxr-xr-x) rather than 777.
Did you manually run chmod 777 after mounting, or does Volumio automatically set these permissions for your drive?
Sorry for providing incomplete data.
I’ve been messing around a lot to get the USB drive properly working. So missed a step.
Turned out I even stepped away from exFAT and formatted the drive as NTFS.
The latter make the process working ok.
-sda2 ntfs FLAC 4CC432CEC432B9D2 343.4G 82% /media/FLAC
Thanks for the clarification.
So if I understand correctly, the actual fix was not the label but changing the filesystem from exFAT to NTFS.
In my case I would like to keep the existing exFAT filesystem because the drive contains important data and I would prefer not to reformat it.
Has anyone successfully used an exFAT USB drive with Volumio 4 and obtained write access via SMB/SFTP?
I found that manually remounting with:
solves the problem immediately, so it seems to be related to the mount options Volumio uses for exFAT.
Is this a known issue with exFAT in Volumio 4?
It’s a bug. See:
Tested with x86, rPi5, Rivo, PrimoV2
