[b]I2S is definitely the way to go if you have a Raspberry Pi. No more stuttering, better sound quality (in theory) and free up a USB port!
There’s a growing collection of I2S DACs for the Raspberry Pi, here are ones I’ve found. If you know of one that I haven’t posted, just post the details on this thread
[/b]
Attention! Listed DAC´s are (mostly) only compatible with the Raspberry Model B (not B+)
HifiBerry DAC - €35-45 including shipping:
HifiBerry Digi - €35-45 including shipping:
Not a DAC itself, but provides SPDIF/Toslink outputs for an external DAC
http://www.hifiberry.com/hbdigi
IQaudIO Pi-DAC - $41 including shipping:
iqaudio.com/
WOLFSON AUDIO CARD £27 including delivery (in UK)
http://cpc.farnell.com/wolfson-microelectronics/wolfson-audio-card/audio-card-for-use-with-raspberry/dp/SC13232
BerryNOS mini - $70 including shipping:
shop.g2labs.org/index.php?id_pro … er=product
BerryNOS 1543 - $105 including shipping
RASPYPLAY3 - $44 plus shipping (In Serbian!)
saperel.com/RaspyPlay3%20HiF … berry%20Pi
Geekroo DAC Hi-Fi Picobber $40 including shipping
http://www.geekroo.com/1034
DAC PCM5102 I2S P5 32bit/384Khz Raspberry PI €40 incl shipping
http://www.audiophonics.fr/en/kits-modules-diy-dac/dac-pcm5102-i2s-p5-32bit384khz-raspberry-pi-p-8884.html
Case here: http://www.audiophonics.fr/fr/boitiers-diy-boitiers-divers/audiophonics-boitier-diy-pour-raspberry-pi-et-dac-pcm5102–p-8928.html
Thanks IRoN!
TekDevice DACBERRY2 PCM5102 384K 32 BIT I2S DAC $50 including shipping
http://tekdevice.com/chapter2/index.php?route=product/product&product_id=110
http://www.ebay.com/itm/TekDevice-dacBerry2-PCM5102-384K-32-Bit-I2S-DAC-Module-For-Raspberry-Pi-Rev-B-/390798816509
Here are some DAC boards that don’t fit on the Pi itself but are easily connected via patch cables:
HIFIMEDIY ES9023 I2S DAC ~ £15 including oscillator and shipping:
Available with and without oscillator (included one enables max 96kHz sample freq)
hifimediy.com/index.php?route=pr … uct_id=127
DIYINHK 24Bit/192KHz ES9023 DAC $24 including shipping (Needs a CRYSTEK957/7050/5032/3225 oscillator soldered to the board)
http://www.diyinhk.com/shop/audio-kits/26-24bit192khz-es9023-dac-i2s-input-ultra-low-noise-regulator.html
DIYINHK 384kHz/32Bit PCM5102A DAC $34 including shipping
http://www.diyinhk.com/shop/audio-kits/31-384khz32bit-pcm5102a-dac-i2s-input-ultra-low-noise-regulator.html
Audiophonics DAC Sabre ES9023 €21 including shipping
http://www.audiophonics.fr/audiophonics-dac-sabre-es9023-i2s-vers-analogique-24bit192khz-p-8396.html
AKOUO Reference Stereo DAC (SABRE ES 9018 DAC) €450 plus shipping
http://www.akouo.at/dac-112.html
