[GUIDE] Identifying Your Raspberry Pi Board on Volumio: A Comprehensive Guide to Revision Codes
Introduction
Proper board identification is critical for troubleshooting your Volumio system. When posting for help, please include the raw outputs from your system so that others can accurately diagnose your issue. In particular, please share the revision code details (from /proc/cpuinfo) and the device tree information (from /proc/device-tree/compatible). This post provides a comprehensive reference table for new‑style Raspberry Pi revision codes along with the necessary commands to retrieve your board’s details.
Table of Raspberry Pi Revision Codes
Below is the complete reference table. Each row represents a unique revision code with detailed information including the model, board revision, RAM, CPU (SoC & clock), network connectivity, revision code, manufacturer, device tree string, and device tree CPU.
Model Board Revision RAM CPU (SoC & Clock) Network Connectivity Revision Code Manufacturer Device Tree Device Tree CPU
1 A 2.0 256MB BCM2835, ~700 MHz None 000007 Egoman model-a bcm2835
1 A 2.0 256MB BCM2835, ~700 MHz None 000008 Sony UK model-a bcm2835
1 A 2.0 256MB BCM2835, ~700 MHz None 000009 Qisda model-a bcm2835
1 B 1.0 256MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 000002 Egoman model-b bcm2835
1 B 1.0 256MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 000003 Egoman model-b bcm2835
1 B 2.0 256MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 000004 Sony UK model-b bcm2835
1 B 2.0 256MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 000005 Qisda model-b bcm2835
1 B 2.0 256MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 000006 Egoman model-b bcm2835
1 B 2.0 512MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 00000d Egoman model-b bcm2835
1 B 2.0 512MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 00000e Sony UK model-b bcm2835
1 B 2.0 512MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 00000f Egoman model-b bcm2835
A+ 1.1 256MB BCM2835, ~700 MHz None 000012 Sony UK model-a-plus bcm2835
A+ 1.1 256/512MB BCM2835, ~700 MHz None 000015 Embest model-a-plus bcm2835
A+ 1.1 512MB BCM2835, ~700 MHz None 900021 Sony UK model-a-plus bcm2835
B+ 1.2 512MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 000010 Sony UK model-b-plus bcm2835
B+ 1.2 512MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 000013 Embest model-b-plus bcm2835
B+ 1.2 512MB BCM2835, ~700 MHz 10/100 Mbps Ethernet 900032 Sony UK model-b-plus bcm2835
2B 1.0 1GB BCM2836, quad-core Cortex-A7, ~900 MHz 10/100 Mbps Ethernet a01040 Sony UK 2-model-b bcm2836
2B 1.1 1GB BCM2836, quad-core Cortex-A7, ~900 MHz 10/100 Mbps Ethernet a01041 Sony UK 2-model-b bcm2836
2B 1.1 1GB BCM2836, quad-core Cortex-A7, ~900 MHz 10/100 Mbps Ethernet a21041 Embest 2-model-b bcm2836
2B 1.2 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz 10/100 Mbps Ethernet a02042 Sony UK 2-model-b bcm2837
2B 1.2 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz 10/100 Mbps Ethernet a22042 Embest 2-model-b bcm2837
CM1 1.0 512MB BCM2835, ~700 MHz Depends on carrier board 000011 Sony UK compute-module bcm2835
CM1 1.0 512MB BCM2835, ~700 MHz Depends on carrier board 000014 Embest compute-module bcm2835
CM1 1.1 512MB BCM2835, ~700 MHz Depends on carrier board 900061 Sony UK compute-module bcm2835
CM2 1.0 1GB BCM2836, quad-core Cortex-A7, ~900 MHz Depends on carrier board a01160 Sony UK 2-compute-module bcm2836
3B 1.2 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz 10/100 Mbps Ethernet; 802.11n WiFi; Bluetooth 4.1 a02082 Sony UK 3-model-b bcm2837
3B 1.2 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz 10/100 Mbps Ethernet; 802.11n WiFi; Bluetooth 4.1 a22082 Embest 3-model-b bcm2837
3B 1.2 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz 10/100 Mbps Ethernet; 802.11n WiFi; Bluetooth 4.1 a32082 Sony Japan 3-model-b bcm2837
3B 1.2 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz 10/100 Mbps Ethernet; 802.11n WiFi; Bluetooth 4.1 a52082 Stadium 3-model-b bcm2837
3B 1.3 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz 10/100 Mbps Ethernet; 802.11n WiFi; Bluetooth 4.1 a22083 Embest 3-model-b bcm2837
Zero 1.2 512MB BCM2835, single-core ~1 GHz None 900092 Sony UK model-zero bcm2835
Zero 1.2 512MB BCM2835, single-core ~1 GHz None 920092 Embest model-zero bcm2835
Zero 1.3 512MB BCM2835, single-core ~1 GHz None 900093 Sony UK model-zero bcm2835
Zero 1.3 512MB BCM2835, single-core ~1 GHz None 920093 Embest model-zero bcm2835
Zero W 1.1 512MB BCM2835, single-core ~1 GHz 802.11n WiFi; Bluetooth 9000c1 Sony UK model-zero-w bcm2835
Zero 2 W 1.0 512MB BCM2710A1, quad-core Cortex-A53, ~1 GHz 802.11n WiFi; Bluetooth 902120 Sony UK model-zero-2-w bcm2837
CM3 1.0 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz Depends on carrier board a020a0 Sony UK 3-compute-module bcm2837
CM3 1.0 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz Depends on carrier board a220a0 Embest 3-compute-module bcm2837
CM3E 1.0 512MB RP3A0-AU (BCM2710A1), quad-core Cortex-A53, ~1 GHz Depends on carrier board 922160 Embest 3e-compute-module bcm2837
3B+ 1.3 1GB BCM2837, quad-core Cortex-A53, ~1.4 GHz Gigabit Ethernet (USB2-limited); dual-band 802.11ac WiFi; Bluetooth 4.2 a020d3 Sony UK 3-model-b-plus bcm2837
3B+ 1.4 1GB BCM2837, quad-core Cortex-A53, ~1.4 GHz Gigabit Ethernet (USB2-limited); dual-band 802.11ac WiFi; Bluetooth 4.2 a020d4 Sony UK 3-model-b-plus bcm2837
3A+ 1.0 512MB BCM2837, quad-core Cortex-A53, ~1.4 GHz 802.11ac WiFi (no Ethernet) 9020e0 Sony UK 3-model-a-plus bcm2837
3A+ 1.1 512MB BCM2837, quad-core Cortex-A53, ~1.4 GHz 802.11ac WiFi (no Ethernet) 9020e1 Sony UK 3-model-a-plus bcm2837
CM3+ 1.0 1GB BCM2837, quad-core Cortex-A53, ~1.2 GHz Depends on carrier board a02100 Sony UK 3-plus-compute-module bcm2837
4B 1.1 1GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 a03111 Sony UK 4-model-b bcm2711
4B 1.1 2GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 b03111 Sony UK 4-model-b bcm2711
4B 1.1 4GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 c03111 Sony UK 4-model-b bcm2711
4B 1.2 2GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 b03112 Sony UK 4-model-b bcm2711
4B 1.2 4GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 c03112 Sony UK 4-model-b bcm2711
4B 1.4 1GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 a03114 Sony UK 4-model-b bcm2711
4B 1.4 2GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 b03114 Sony UK 4-model-b bcm2711
4B 1.4 4GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 c03114 Sony UK 4-model-b bcm2711
4B 1.4 8GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 d03114 Sony UK 4-model-b bcm2711
4B 1.5 1GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 a03115 Sony UK 4-model-b bcm2711
4B 1.5 2GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 b03115 Sony UK 4-model-b bcm2711
4B 1.5 3GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 TBD (not yet allocated) Sony UK 4-model-b bcm2711
4B 1.5 4GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 c03115 Sony UK 4-model-b bcm2711
4B 1.5 8GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 d03115 Sony UK 4-model-b bcm2711
400 1.0 4GB BCM2711, quad-core Cortex-A72, ~1.8 GHz (factory-overclocked) Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 c03130 Sony UK 400 bcm2711
CM4 1.0 1GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board a03140 Sony UK 4-compute-module bcm2711
CM4 1.0 2GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board b03140 Sony UK 4-compute-module bcm2711
CM4 1.0 4GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board c03140 Sony UK 4-compute-module bcm2711
CM4 1.0 8GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board d03140 Sony UK 4-compute-module bcm2711
CM4 1.1 1GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board a03141 Sony UK 4-compute-module bcm2711
CM4 1.1 2GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board b03141 Sony UK 4-compute-module bcm2711
CM4 1.1 4GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board c03141 Sony UK 4-compute-module bcm2711
CM4 1.1 8GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board d03141 Sony UK 4-compute-module bcm2711
CM4S 1.0 1GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board a03150 Sony UK 4s-compute-module bcm2711
CM4S 1.0 2GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board b03150 Sony UK 4s-compute-module bcm2711
CM4S 1.0 4GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board c03150 Sony UK 4s-compute-module bcm2711
CM4S 1.0 8GB BCM2711, quad-core Cortex-A72, ~1.5 GHz Depends on carrier board d03150 Sony UK 4s-compute-module bcm2711
5 1.0 2GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 b04170 Sony UK 5-model-b bcm2712
5 1.0 4GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 c04170 Sony UK 5-model-b bcm2712
5 1.0 8GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 d04170 Sony UK 5-model-b bcm2712
5 1.1 1GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 a04171 Sony UK 5-model-b bcm2712
5 1.1 2GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 b04171 Sony UK 5-model-b bcm2712
5 1.1 4GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 c04171 Sony UK 5-model-b bcm2712
5 1.1 8GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 d04171 Sony UK 5-model-b bcm2712
5 1.1 16GB Quad-core Cortex-A76, ~2.0 GHz Enhanced Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 e04171 Sony UK 5-model-b bcm2712
CM5 1.0 2GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board b04180 Sony UK 5-compute-module bcm2712
CM5 1.0 4GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board c04180 Sony UK 5-compute-module bcm2712
CM5 1.0 8GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board d04180 Sony UK 5-compute-module bcm2712
CM5 1.0 16GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board e04180 Sony UK 5-compute-module bcm2712
CM5 Lite 1.0 2GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board b041a0 Sony UK cm5-lite bcm2712
CM5 Lite 1.0 4GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board c041a0 Sony UK cm5-lite bcm2712
CM5 Lite 1.0 8GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board d041a0 Sony UK cm5-lite bcm2712
CM5 Lite 1.0 16GB Quad-core Cortex-A76, ~2.0 GHz Depends on carrier board e041a0 Sony UK cm5-lite bcm2712
500 1.0 8GB Quad-core Cortex-A76, ~2.0 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0 d04190 Sony UK 500 bcm2712
500+ 1.0 16GB Quad-core Cortex-A76, ~2.0 GHz Gigabit Ethernet; dual-band 802.11ac WiFi; Bluetooth 5.0, NVMe 256GB, mech KB. e04190 Sony UK 500 bcm2712
Instructions
To retrieve your board’s revision and model information, run these commands in your terminal:
cat /proc/cpuinfo | grep -i revision
cat /proc/cpuinfo | grep -i model
You can also view the complete device tree information using:
cat /proc/device-tree/compatible | tr '\0' '\n'
SSH Access on Volumio:
Please note that SSH is enabled or disabled only via the Volumio developer URL. Open your browser and go to:
http://volumio.local/dev (or use your device’s IP address)
Then use the on‑screen toggle to enable or disable SSH access.
Additional Steps
When posting for support, please include:
  • The full output of the above commands.
  • The revision code line from /proc/cpuinfo.
  • The device tree output.
  • The corresponding row from the reference table above.
Including these details ensures that your board is properly identified, allowing the community to accurately diagnose and help resolve your issue.
