Dnlna won't install x86
Volumio 3 Issues?
I wanted to install Volumio3 and unfortunately it won’t work properly. I will not install the DLNA plugin because an error pops up, I tried the same on three computers. The DAC Topping E30 only detects at 176kHz, while it can process 768,000, it doesn’t send DSD files - no (2.8 / 5.6.11.2) nothing - how could you use something like this ?? it is useless
This must be the most helpful information statement we have all been waiting for. Talking about useless…
Don’t expect anyone to help until you come up with something more substantial than that :wink:
Like which PC? Which usb port (1.0/2.0/3.0) you connected the Topping to?
Logs?
If something is useless, you cannot use it.
but you still used it otherwise you wouldn’t come up with this question :laughing:
no !, I do not use it, I had it installed on my computer for 8 hours and it did not work properly, this topic is rather information about errors, so you know what is not working, Topping connected to the USB 3.0 port, - logs? I am not an IT specialist - I have no idea where and how to get it - for me it is a program - either it works and I use it, I am able to pay for it (because someone worked on it) or I throw it away because it is not good and it does not work, like this one (volumio).
In some time with the next version of the update (maybe you will improve something) I will try and evaluate it again.
Thank you for trying to help, but that’s not what I mean, I don’t know much about programming and I have no idea what to do to make it work, it’s supposed to work, if not, then you don’t use it.
For me, Daphile just works after installing - it works fine, so I will continue to use it
https://volumio.github.io/docs/User_Manual/Sending_logs_for_troubleshooting.html
this is the log after trying to install the minidl
http://logs.volumio.org/volumio/gP1nYj7.html
Device Unique Identification Code
0f73002b9f66a8ba901a2517bb070a78
sytem
OS info
Version of Volumio: 3.324
Hostname: volumio
Kernel: 5.10.112-volumio
Governor: performance
Uptime: 0 days, 0 Hrs, 15 Minutes, 26 Seconds
Audio info
Hw audio configured: E30
Mixer type: Hardware
Number of channels: 2
Board info
Manufacturer: WYSE
Model: Z CLASS
Version: Rev 1
Firmware Version: -
CPU info
Brand: G-T56N Processor
Speed: 1.6Ghz
Number of cores: 2
Physical cores: 2
Average load: 26%
Temperature: 67°C
Memory info
Memory: 7745740 Ko
Free: 6342328 Ko
Used: 1403412 Ko
Storage info
INTERNAL storage - Size: 176Mo
Used: 144Mo
Available for storage: 19Mo (11%)
Looks like a hash mismatch…. When pulling a download file.
Ordering a hamburger and getting some beer instead lol.
well, it’s probably errors on the volumio servers
Unfortunately the picture does not show the installation from the beginning. But if I had to guess I would say there has probably been an error downloading the miniDLNA package during the installation of the plugin. This can happen when e.g. the repo server is down. DNS issues could also be the reason.
Aug 26 12:31:40 volumio volumio[625]: info: Install script return the error Error: Command failed: echo volumio | sudo -S sh /data/plugins/music_service/minidlna/install.sh > /tmp/installog
Aug 26 12:31:40 volumio volumio[625]: [sudo] password for volumio: E: Failed to fetch http://deb.debian.org/debian/dists/buster/main/binary-i386/by-hash/SHA256/5741d87b085f40cfa1ed57f13cba4bf0150680b2bb5d6d4abdb43016459a921f  Hash Sum mismatch
Aug 26 12:31:40 volumio volumio[625]:    Hashes of expected file:
Aug 26 12:31:40 volumio volumio[625]:     - Filesize:10691812 [weak]
Aug 26 12:31:40 volumio volumio[625]:     - SHA256:5741d87b085f40cfa1ed57f13cba4bf0150680b2bb5d6d4abdb43016459a921f
Aug 26 12:31:40 volumio volumio[625]:     - MD5Sum:63166913b329b0bb38a0804123b909da [weak]
Aug 26 12:31:40 volumio volumio[625]:    Hashes of received file:
Aug 26 12:31:40 volumio volumio[625]:     - SHA256:50cc1f80077b4162d978e087c54401c86fe1c9e48a081370271d615229bf1ed5
Aug 26 12:31:40 volumio volumio[625]:     - MD5Sum:ab42f35d8bdffee65ed6950ce37a4413 [weak]
Aug 26 12:31:40 volumio volumio[625]:    Last modification reported: Sat, 26 Mar 2022 11:05:07 +0000
Aug 26 12:31:40 volumio volumio[625]:    Release file created at: Sat, 26 Mar 2022 11:35:38 +0000
Aug 26 12:31:40 volumio volumio[625]: E: Some index files failed to download. They have been ignored, or old ones used instead.
Aug 26 12:31:40 volumio volumio[625]: E: Unable to locate package minidlna
Aug 26 12:31:40 volumio volumio[625]: rm: cannot remove '/data/minidlna.conf': No such file or directory
Aug 26 12:31:40 volumio volumio[625]: rm: cannot remove '/etc/systemd/system/minidlna.service': No such
I don’t know any of this, it just doesn’t work for me
previously I installed volumio 3 weeks ago, these logs are from today’s installation - all over again, the servers are down for so long ??, it is very bad for the systems. Nobody noticed this?
99,79% uptime for the repo server in the latest month, so where probably just unlucky to download at the time there were a small glitch…
You can always check your self at https://status.volumio.com/
I checked by the link you provided, they work, tried to install the plug again now and bad again, not working, not installing, same error
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/minidlna/volumio/buster/amd64
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/minidlna/volumio/buster/amd64
Tworzenie miejsca instalacji
Wypakowywanie wtyczki
Wyszukiwanie zduplikowanych wtyczek
Kopiowanie wtyczki do miejsca instalacji
Instalowanie niezbędnych narzędzi
Completing “UIConfig.json”
Installing MiniDLNA
Get:1 Index of /debian buster InRelease [122 kB]
Hit:2 Index of /node_14.x/ buster InRelease
Get:3 Index of /debian buster/main amd64 Packages [7911 kB]
Get:4 Index of /debian buster/main i386 Packages [7868 kB]
Get:5 Index of /debian buster/main Translation-en [5969 kB]
Get:6 Index of /debian buster/contrib amd64 Packages [50.1 kB]
Get:7 Index of /debian buster/contrib i386 Packages [46.0 kB]
Get:8 Index of /debian buster/contrib Translation-en [44.2 kB]
Get:9 Index of /debian buster/non-free i386 Packages [76.2 kB]
Get:10 Index of /debian buster/non-free amd64 Packages [87.7 kB]
Get:11 Index of /debian buster/non-free Translation-en [88.8 kB]
Ign:3 Index of /debian buster/main amd64 Packages
Get:3 Index of /debian buster/main amd64 Packages [10.7 MB]
Ign:4 Index of /debian buster/main i386 Packages
Get:4 Index of /debian buster/main i386 Packages [10.7 MB]
Ign:5 Index of /debian buster/main Translation-en
Err:5 Index of /debian buster/main Translation-en
Write error - write (28: No space left on device)
Reading package lists…
Building dependency tree…
Reading state information…
Installation of minidlna failed
Plugin failed to install!
Cleaning up…
Removing dependencies
Deleting /data/minidlna.conf
Deleting systemd unit /etc/systemd/system/minidlna.service
Done
Removing plugin directory /data/plugins/music_service/minidlna
Wystąpił błąd podczas instalowania wtyczki Error
I tried to determine why the Topping E30 won’t work with your Wyse PC.
So far I did not see anything abnormal in the logs.
E30 is an Thesycon supported DAC, so should normally work with DSD.
Others use it with the current Volumio version without issues.
Strange that it also reports incorrect bitrate support.
Could you report the results of
lsusb -t
and
cat /proc/asound/card5/stream0
i’ll do it right now, above you have the ifo system
how to log in to ssh? root? and the password?
volumio, password volumio
