Log shows :Write error - write (28: No space left on device)
Reading package lists…
@balbuze: good one, I only looked at the DAC issue,
@wiesieks
Aug 26 12:28:53 volumio kernel: EXT4-fs error (device sdb3): ext4_mb_generate_buddy:805: group 7, block bitmap and bg descriptor inconsistent: 7757 vs 7498 free clusters
Aug 26 12:28:53 volumio kernel: EXT4-fs error (device sdb3): ext4_mb_generate_buddy:805: group 5, block bitmap and bg descriptor inconsistent: 7757 vs 7498 free clusters
Aug 26 12:28:53 volumio kernel: EXT4-fs error (device sdb3): ext4_mb_generate_buddy:805: group 3, block bitmap and bg descriptor inconsistent: 7757 vs 7498 free clusters
Aug 26 12:28:53 volumio kernel: EXT4-fs error (device sdb3): ext4_mb_generate_buddy:805: group 0, block bitmap and bg descriptor inconsistent: 3759 vs 3175 free clusters
Aug 26 12:28:53 volumio kernel: EXT4-fs error (device sdb3): ext4_mb_generate_buddy:805: group 1, block bitmap and bg descriptor inconsistent: 7757 vs 7498 free clusters
Aug 26 12:28:53 volumio kernel: EXT4-fs error (device sdb3): ext4_mb_generate_buddy:805: group 23, block bitmap and bg descriptor inconsistent: 1679 vs 8112 free clusters
does not look healthy. As this is not the first boot from a fresh image, I cannot see what went wrong with resizing partition 3 at first start.
Can you also tell us which Wyse Z Model you have? I’d like to check the insides
There are “millions” of different PC configurations out in the field and the team has always warned that Volumio will not run perfectly on all of them. The aim was to support as many as possible using standard kernels (ones used by Ubuntu and Debian) and corresponding firmware.
There is also no guarantee, that PCs designed as Thin Clients will always work, though the Wyse ones usually do.
Reason why the minidlna plugin does not install:
Resize failed, see I/O errors above, we don’t know yet why it failed…
volumio@volumio:~$ lsusb -t
/: Bus 09.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 2: Dev 2, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 2, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 2, If 2, Class=Application Specific Interface, Driver=, 480M
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/4p, 12M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/2p, 12M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/5p, 12M
|__ Port 2: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/5p, 12M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/4p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/5p, 480M
|__ Port 3: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/5p, 480M
cat /proc/asound/card5/stream0
Topping E30 at usb-0000:05:00.0-2, high speed : USB Audio
Playback:
Status: Running
Interface = 1
Altset = 1
Packet Size = 72
Momentary freq = 44099 Hz (0x5.8328)
Feedback Format = 16.16
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 768000
Data packet interval: 125 us
Bits: 32
Channel map: FL FR
Interface 1
Altset 2
Format: S32_LE
Channels: 2
Bits: 24
Channel map: FL FR
Interface 1
Altset 3
Format: SPECIAL DSD_U32_BE
Channels: 2
Bits: 32
DSD raw: DOP=0, bitrev=0
Channel map: FL FR
I’m sorry that I didn’t speak but they blocked me - too many answers, you have strange habits on this forum, you can’t even talk, never mind, it’s not the fault of the Computer, as I wrote, I tried on three computers, the effect is the same. the logs that I will send now are from the MSI GL 65 LEOPARD i7 laptop 32GB RAM 2 TB disk. No memory for writing ?? people - how much does Volumio need to work ??. The system has 3.5 GB, the DLNA plug 630 kb, the disk with Volumio installed on my WYSE is 64 GB, how much space must there be for the 630 kb plug to fit ???
the mentioned logs from other computers
http://logs.volumio.org/volumio/rTfzeRn.html
http://logs.volumio.org/volumio/ZUDhE8O.html
Device Unique Identification Code
b7ad5f127eef34f3bf3f89bff31ec882
System Information
OS info
Version of Volumio: 3.324
Hostname: volumio
Kernel: 5.10.112-volumio
Governor: performance
Uptime: 0 days, 0 Hrs, 8 Minutes, 23 Seconds
Audio info
Hw audio configured: HDMI
Mixer type: Hardware
Number of channels: 8
Board info
Manufacturer: Micro-Star International Co., Ltd.
Model: GL65 Leopard 10SDR
Version: REV:1.0
Firmware Version: -
CPU info
Brand: Core™ i7-10750H
Speed: 2.6Ghz
Number of cores: 8
Physical cores: 8
Average load: 4%
Temperature: 49°C
Memory info
Memory: 32576056 Ko
Free: 30858512 Ko
Used: 1717544 Ko
Storage info
INTERNAL storage - Size: 176Mo
Used: 145Mo
Available for storage: 18Mo (10%)
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/minidlna/volumio/buster/amd64
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatestStable/minidlna/volumio/buster/amd64
Tworzenie miejsca instalacji
Wypakowywanie wtyczki
Wyszukiwanie zduplikowanych wtyczek
Kopiowanie wtyczki do miejsca instalacji
Instalowanie niezbędnych narzędzi
Completing “UIConfig.json”
Installing MiniDLNA
Get:1 Index of /debian buster InRelease [122 kB]
Hit:2 Index of /node_14.x/ buster InRelease
Get:3 Index of /debian buster/main amd64 Packages [7911 kB]
Get:4 Index of /debian buster/main i386 Packages [7868 kB]
Get:5 Index of /debian buster/main Translation-en [5969 kB]
Get:6 Index of /debian buster/contrib amd64 Packages [50.1 kB]
Get:7 Index of /debian buster/contrib i386 Packages [46.0 kB]
Get:8 Index of /debian buster/contrib Translation-en [44.2 kB]
Get:9 Index of /debian buster/non-free amd64 Packages [87.7 kB]
Get:10 Index of /debian buster/non-free i386 Packages [76.2 kB]
Get:11 Index of /debian buster/non-free Translation-en [88.8 kB]
Ign:3 Index of /debian buster/main amd64 Packages
Get:3 Index of /debian buster/main amd64 Packages [10.7 MB]
Ign:4 Index of /debian buster/main i386 Packages
Get:4 Index of /debian buster/main i386 Packages [10.7 MB]
Ign:5 Index of /debian buster/main Translation-en
Err:5 Index of /debian buster/main Translation-en
Building dependency tree…
Reading state information…
Installation of minidlna failed
Plugin failed to install!
Cleaning up…
Removing dependencies
Deleting /data/minidlna.conf
Deleting systemd unit /etc/systemd/system/minidlna.service
Done
Removing plugin directory /data/plugins/music_service/minidlna
Wystąpił błąd podczas instalowania wtyczki Error
The amount of free space doesn’t matter if the partitions aren’t being created correctly. With a write/not enough space error a few things can be the problem:
- the partition the plugin wants to install on hasn’t been created correctly by Volumio
- there is a corrupt sector in this partition.
- the plugin hasn’t been downloaded correctly/is corrupt
- there’s a hardware issue
You say that you’ve tried to install Volumio on different computers, so that would rule out option 2.
You also say that you’ve downloaded the plugin multiple times and that the result was always the same, so that would rule out option 3.
That leaves option 1 and 4.
Volumio isn’t perfect and the creators have made that very clear. It’s a freeware program that’s being created and maintained by volunteers, so basically “it is what it is.”
If option 4 is the issue, then that would explain option 1: the partition isn’t being created correctly during setup due to a hardware conflict. Now that isn’t as unlikely as it seems: I run Volumio on a Raspberry Pi3 and it simply will not install on multiple brands of micro SD cards. Why? Who knows, not all manufacturers adhere strictly to the rules. That in your case this seems to happen with multiple computers is just rotten luck on your side.
I tried volumio2 once and everything worked, can you still download old versions to check?
three different computers so it can’t be hardware fault, I’ll change the USB stick and we’ll see
well, I did not expect that, it turned out that RUFUS was writing the USB badly, I saved the Volumio renewal to USB using balenaEtcher and after starting it installed the DLNA plug without any problems. But not all is well. The dlna server sometimes “disappears” from the network - my Pioneer and tv cannot see the dlna server, I have to turn the plug off and on and then it shows up again.
The second thing - it does not show DSD files (dlna server), even though Volumio has them in the database and reproduces them without any problems, does not show all tracks …
these are logs from a nearly working Volumio
http://logs.volumio.org/volumio/0sQG1ha.html
Device Unique Identification Code: 0f73002b9f66a8ba901a2517bb070a78
volumio@volumio:~$ cat /proc/asound/card5/stream0
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Bits: 32
Channel map: FL FR
Interface 1
Altset 2
Format: S32_LE
Channels: 2
Bits: 24
Channel map: FL FR
Interface 1
Altset 3
Channels: 2
Bits: 32
Channel map: FL FR
System Information
OS info
Hostname: volumio
Uptime: 0 days, 0 Hrs, 37 Minutes, 41 Seconds
Audio info
Hw audio configured: E30
Number of channels: 2
Board info
Manufacturer: WYSE
Model: Z CLASS
Version: Rev 1
Firmware Version: -
CPU info
Brand: G-T56N Processor
Speed: 1.6Ghz
Number of cores: 2
Physical cores: 2
Average load: 21%
Temperature: 63°C
Memory info
Memory: 7745740 Ko
Free: 1352332 Ko
Used: 6393408 Ko
Storage info
INTERNAL storage - Size: 56276Mo
Used: 328Mo
Available for storage: 53060Mo (94%)
well now it has smashed me completely, I’m back to Daphile, everything works fine there and for free, even though it doesn’t look so nice. Thank you to everyone for your willingness to help, I appreciate your commitment, I consider the topic closed, we will see one day - maybe - when it will handle DSD in all options. You do not need to start a computer or an application on the phone, as devices such as receivers support network servers and you simply select songs directly from its menu, but it turns out that not all servers, not all files! Thank you again for all your activities.
nothing wrong with your Topping E30, stream0 shows the capabilities as reported by the driver, bitrate up to 768Khz, including DSD raw. So something else is wrong, don’t know where you got the system info from, but it is inaccurate for the audio part.
I respect you chosing an other solution, pity as we could have solved the DSD issue.
