So, I need drivers for 5.10.92, right?
Will ask them.
Folks, thank you for a moment!
I would not expect a driver that was built for another kernel version to work. I doubt that the display would even show the boot sequence.
Yes.
Well just to try, itâs 5 minutes vs 2 months shipping back to chinaâŠ
Yes, not much to lose apart from time (5 minutes? Maybe if one knows what to do).
Maybe a idea there is a bulleye test release i donât know if itâs up2date.
Nope itâs not up2date
And in the worst case, since those china wholesalers arenât keen on returns, Install Raspbian and a aquarium screensaver
Contacted to Waveshare if they can make 5.10.92 drivers or even planning. Will see.
@gvolt you are right no even boot sequence. CrapâŠ
@Wheaten this one will try to sell on eBay and on the meantime get another one HDMI
Make sure that you pay close attention to where the HDMI and USB connector resides. As you need additional space in your enclosure.
And wait for Waveshares feedback and if they donât provide the driver, ask if they will swap the display.
Yes⊠It is tight and this is the reason why I choose current one with DSI tape instead HDMI/USB sockets on top⊠EhhhâŠ
Waveshare got holidays to 7th of October.
Folks, thanks for advice and will contact you soon.
yeah they have a public holiday for a week.
What an amazing streamer, that front panel is gorgeous. My question is related to the touch detection, how does it work through suck a thick glass? Thanks
Hi itâs a beautiful streamer.
Allegedly, this is a good combination :
ALLO DIGIONE SIGNATURE + ALLO REVOLUTION USB DAC.
What do you think?
But it is very ugly. Is it possible to make a project with âyour designâ?
Txs
Hi; i bought a display 8.8â on aliexpress, i try to run it with pi4, but i didnt do it. What is my wrong?
Note: pi4 works with AOC 24â monitor without problem and Display works on pc without problem
TRY 701.94 30ïŒ Off | 8.8 INCH 1920x480 IPS STRETCHED BAR DISPLAY RASPBERRY PI AIDA64 AUTOMOTIVE LCD DISPLAY 60Hz DRIVER BOARD LONG STRIP DISPLAY
your width and height are the same in your userconfig.txt
in the last 2 lines. max buffer height should be 480
ı downloaded userconfig txt on 2sn post and it is already like this. Do i need to changelast line with 480?
yes your height is max 480 and not 1920
1920 is the width of your screen
and donât see any settings in the seconde post here.
i would advice you to contact the seller for the settings.
thanks i wiil change it and i will let you know.
it is not work.
i think you hdmi timings is still off
@gvolt do you know anything about this screen ?
could not find any info about this one.
you could try this :
hdmi_cvt=480 1920 60
hdmi_drive=1
hdmi_mode=87
hdmi_group=2
display_rotate=1
hdmi_force_mode=1
#dtoverlay=vc4-fkms-v3d
if you have the last line in your userconfig mark it with a # so it will not run.
and do that for the hdmi_timings to instead use the hdmi_cvt line.
