DIY Streamer with HiFiBerry DAC2 HD and 11.9" Display
Hello!
This is my DIY streamer with 11.9" display
Raspberry Pi 4 (4GB) with USB-C Power Support
DAC: HiFiBerry DAC2 HD
Case: HiFi 2000 Galaxy GX388 with reinforced base plate
Display: Waveshare 11.9" with HDMI
OS: Volumio 3 with Now-Playing plugin, Peppymeter and FusionDSP (for Room-Correction)
This is incredibly nice. I wouldn’t mind making something similar that can sit on the top of my Cambridge Audio ‘One’ receiver system that I use with my Pi4 and Volumio.
Very cool! Can you dim the backlight of the display?
There is a switch on the display board that can be used to adjust the brightness.
But it is not accessible with the housing closed
Looks almost professional. Well done
I love it, well done!
Beautiful setup… Question… Is there enough power out of the usb output to sufficiently
power a 2.5 ssd without any issues?
With the original power supply and the entry max_usb_current=1 in the config.txt should not be a problem.
But I didn’t test it!
@mchief:
Nice job on this!
In process on my own streamer: can you tell me where you ordered the female-to-female RCA adapters that you mounted in the rear of the case?
Hello!
I ordered here
is that a custom face plate you made for the chassis?
Yes, it‘s a custom face plate
I designed and ordered it here
yes, used the same company for my front plates.
Amazing Work !!!
Where do you find the screen config (to write in config.txt) ?
Do you received it from Waveshare ?
Greetings from Belgium
Fabian
its in their wiki. Waveshare has good documentation available. And put it in the userconfig.txt.
Thanks a lot, it’s all i need
oh no. I should have never seen this
Why?
all the possibilities to spend money on
