Cant connect to my volumio.local
Hey, i installed the OS for raspberry pi from the website and followed they guide, when i finished setting up the volumio after connecting it to the wifi i wanna use it didnt work with the volumio.local no matter what device i use, didnt work with the apps aswell, i dont know what to do , please help.(im using raspberry pi4)
You didn’t change volumio name? E.g. volumio kitchen?
nope, did it with the classic volumio, also after i tried with different names but i also tried with leaving it as volumio
the same network?
yeah, I chose the wifi i use when setting up the volumio from the browser
you can use the IP address instead of volumio.local.
i tried using the ip that is written and it does not work
rasperry is not connected to the network.
can you try cable?
it will be kind of difficult using cable, im at work and i will have to go to the network room and do stuff from there
Take it step by step again
Of course without installing peppymeter (if you don’t want to)
well, i think i followed this guide step by step and got the same result
i think the raspberry pi does not connect to my wifi
is there a way to connect my raspberry to the internet via wifi and not cable ?
of course, it must connect via wifi if it is not damaged
how do you know the ip address if the raspberry is not connected?
when i plugg the raspberryto a screen it says i can access to volumio from the volumio.local page or using the IP and it says the ip, the problem is that none of them gets to my volumio page
needs to connect, wait a bit and try refreshing the page
it wont work even after 15 mins past finishing the setup
Reboot ?
make sure that you are using a browser that allows http not one that insists on https
what is the IP of the Volumio device and what is the IP of the device you are trying to connect from ( just want to rule out a subnet mismatch )
very wise advice
my ip is 10.35.211.62, the ip it says i should access the web ui with is 10.112.138.248
i use chrome and also tried microsoft edge
