Do you have a wired connection as well as wifi? Presumably yes if you get to the ‘First Run Wizard’. Does it work ok without wifi (just click ‘next’ on the wifi network selection part of the wizard) … the reason I ask is that there are a number of posts about wifi problems with RPi3 & Digione (have a search in Google for ‘Allo “Digione” site:volumio.org’).
Edit: ahh, I vaguely remember now back in 2017 that the Allo Digione and Hifiberry Digi+ Pro had a specific version of Volumio, because they are transports to an external DAC. Now, I’d since thought that those changes would have been incorporated into Volumio proper, but perhaps not. Here’s the last version of that http://updates.volumio.org/pi/volumionext/2.207/volumionext-2.207-2017-06-28-pi.img.zip which is probably what you had already? I’ll see what I can find out about later versions/incorporation.
Hi- I couldn’t reply yesterday. Apparently, I’m limited to the number of posts (20?) in a 24 hour period. Yes, the pi is wired to the internet. I couldn’t load the http file in your last post. I wouldn’t mind trying the 3.xx beta if I could locate.
Aluminum BUSTER 3.067 booted right up, no ip issues, only HDMI & Headphones are available for Hardware. So, no sound, no recognition of the Allo Digione Hat (plug-in?), don’t see Tital (plug-in?)
No, I understand your direction. Not working. It did work in 2.853.
Everything else is working fine. I’ll dig up another usb, and add some tracks. Thank you.
