When trying to update: The error message states: User files present. Reset to factory settings. Once I reset, the OTA SW updater repeats that user files are present. I have no user-altered files, other than the options/preferences available in 2.853. I have tried a new install, latest version 2.873 on flashed USB drive, and 64g micro sd card. Neither will boot.
Hi- I see the latest update, now. So, if I do a factory reset, and I select no plugins, that would be a starting point. I have no plugins other than what came with 2.853. Which was installed on the pi, from Allo.
just re-install with fresh one if it’s not updating start fresh.
please take note of your settings… other wise you will have the same way you installed.
if it’s a few i should say give it a try and for other plugins like youtube2,soundclould,mixcloud or youtube cast reciever i can help you give more options. or seek how to… there you have all you need …
most ip porblems are dhcp i like a hard coded ip so i always can reach it.
maybe you have to remove some file that contains the settings stored…
you always connect with your own network. so static ip is best.
if have that your having 2 options to connect … http://volumio.local or ip given by volumio.
and with volumio.local/dev you can enable ssh an you can install every plugin if you follow the instructions given.
