There seems to be a weird resampling when playing webradio.
You can see the bit rate of the stream coming from the radio station (128k, 192k, 320k).
The SPDIF or HDMI sync is varying from 44.1kHz to 48kHz.
At 192k and 320k stream quality the SPDIF / HDMI sync is always at 44.1k.
At 128k stream quality webradios the SPDIF / HDMI sync is sometimes 44.1 sometimes 48k sync.
The attached NAD C510 amplifier is capable (and working) to sync up to 192k on SPDIF and HDMI.
Volumio āAuto resamplingā is configured to be off.
Can you please explain why and what kind of resampling is active in the box?
Known from an Intel Atom configuration with the bytcr-rt5640 codec: sound ānon-chipmunkā only with setting resampling to 16bit.
Doing further investigating to make this work out-of-the-box (may not work for all rt5640 devices).
If the promise is rejected in the āonStartā function of a plugin the red dot in āPlugins Managementā shows the plugin āinactiveā while the switch is set to āOnā position.
After reloading the āInstalled Pluginsā page the dot is green and status shown as āactiveā. Accordingly in /data/configuration/plugins.json the value for āenabledā is ātrueā and the value for āstatusā is āSTARTEDā.
I think this is the same on Volumio 2 but shouldnāt the plugin remain disabled (switch position āOffā) and its status be āinactiveā if it fails to start?
You are able to use the new background but the preview icon is not generated.
I am able to upload a background file āpicture.jpgā and a 300x200 px āthumbnail-picture.jpgā via the UI - then it looks fine. Itās the generation process after the initiial upload, thatās not working.
May be this snippet out of the logfile can help⦠Is it because thumbnails are generated by a plugin and the plugin system is not included in this beta yet?
Mar 13 16:28:01 smx volumio[735]: Uploading: Klingenberg004.jpg
Mar 13 16:28:01 smx volumio[735]: Background Successfully Uploaded
Mar 13 16:28:01 smx volumio[735]: info: CoreCommandRouter::executeOnPlugin: appearance , generateThumbnails
Mar 13 16:28:01 smx volumio[735]: info: CoreCommandRouter::executeOnPlugin: appearance , getBackgrounds
Mar 13 16:28:01 smx volumio[735]: error: Failed to generate thumbnails: ReferenceError: f is not defined
Cheers,
Robert
edit 2021-05-11 :
This issue is solved in 2021-05-07-x86_amd64-volumiobuster-3.073
in version Volumiobuster-3.055-2021-03-12-x86_amd64.img
there is some i18n / l10n information missing.
When navigating to a certain artist in TIDAL the chapter headlines are not available. Instead of the translated text the variable names are displayed:
Not sure if this is a Buster specific problem, but it is here in both Arm & x86 that I have noticed that on the hotspot running on first boot with the āfirst config wizardā, the chosen wifi network password field is not visible on my Android mobile (but occasionally is, just to be awkward ). I can see it ok on a connected laptop, but even here the field is very far to the right (outlying the green border lines).
Tidal playback stops after playing one song (6 seconds before the end if this song) in a list of songs (i.e. an album) http://logs.volumio.org/volumiobuster/8PzDE2t.html
Version: Volumio beta 3.055 (Volumiobuster-3.055-2021-03-12-x86_amd64.zip)
now I see the āTidal problemā again. Every time I start a sequence of songs (i.e. an album) playback of Tidal stops after he first or the second song in the list. After that playback is not possible until I wait a few minutes and start a single song or I change the Playback Potions to another output device.
Since I didnāt see such things over the last couple of months Iām now tending to the opinoin that this issue has its cause in the beta program.
2021-04-13: (Volumiobuster-3.055-2021-03-12-x86_amd64)
Tidal is stopping again - 6s before the end of the track playback mutes, then no further playback is possibleā¦
Hello
i just started installing Volumiobuster-3.073-2021-05-07-x86_amd64on my Volumio 2 Systems.
On an Intel X86 System ( Asus P5G41T/M_LX3 MB, Core 2 duo, 6GB) most of the time everything works fine ( except known issues) , but sometimes the Media Servers ( Synology 920 NAS) ist not shown - even when i play music from that NAS ( because the link is still stored from the last session) at the same time or from Internet Radio - so Networking is o.k. !.
I had that just once after app 10 restarts. I run Volumio Buster form SSD - the system has no USB 3 and boots very slow from USB 2 so i copied the system on a small SSD.
(Thats a very good option to do that from Volumio itself)
Waiting for some minutes did not help.
This post is a āVolumio 3 beta for x86ā issue, not a general one.
Please post this again and stick to the rules outlined in the first post of the āVolumio 3 for x86ā thread.
We need hardware info and logs, without it we are not able to offer support.
The user interface had numerous display issues when running the setup wizard. Controls, especially drop-down menus would disappear when I clicked on them, then reappear, only to disappear again after attempting again to access them.
I noticed the browser attempting to connect to external web sites. It was failing, of course, because my only network interface was attached directly to the device operating as an access point. My browser had no outside access. I eventually succeeded by attaching a second WiFi controller, a USB device, I had available, to maintain the separate WiFi connections. Plainly this option is not always available.
Generally, a device controlled through a web interface should be able to serve the entire interface internally. Expecting either the device or the client to have internet access at all times when attempting to control the device presents to me as a bad design choice.
I may be misunderstanding the design based on a few small observation available to me, but I certainly stand by the recommendation to maintain a design free from internet dependencies.
I would recommend you to read the very first post of the beta test instead of complaining. In case you have difficulties with the quality of the beta, you should not have joined the beta program.
