Using the mini as I don’t trust nano’s much.
Greetings again.
I’ve installed the T3U mini, but I have a recurring problem. The WiFi does not start on reboot.
I need to connect LAN cable to find Volumio on the network. Under Network Status, only wired network is visible.
If I then click Save for Wireless network settings to manually restart the Wifi, then WiFi starts and I can disconnect LAN.
I’ve tried factory reset.
TP T3U is connected to a USB 3 port (tried USB 2 - no change).
Hotspot fallback is not working on boot either. In fact, the LED on the T3U doesn’t blink at all, like it is not powered on.
Hardware is standard HP 620 thin client.
Volumio-3.396-2022-12-04-x86_amd64
Router AP is Fritz!Box 7530, Wifi SSID is not hidden, using channel 1.
Many thanks for any help, I’m a bit stumped.
As to the log and cli info in this post, please note it was collected after I manually restarted the WiFi and it begins to work.
Log output is here.
sudo lshw output:
    description: Desktop Computer
    product: HP t620 Dual Core TC (F5A53AA#ABG)
    vendor: Hewlett-Packard
    version: To Be Filled By O.E.M.
    serial: 8CN61200YS
    width: 64 bits
    capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
    configuration: boot=normal chassis=desktop family=103C_53302C G=D sku=F5A53AA#ABG uuid=027A5ADD-12DC-58ED-EA28-9CF80AEFD150
  *-core
       description: Motherboard
       product: 2187
       physical id: 0
       version: A01
     *-firmware
          description: BIOS
          vendor: AMI
          physical id: 0
          version: L40 v02.10
          date: 07/03/2015
          capacity: 1MiB
          capabilities: pci pnp upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification netboot uefi
     *-memory
          description: System Memory
          physical id: 26
          slot: System board or motherboard
        *-bank:0
             description: SODIMM DDR3 [empty]
             product: A1_PartNum0
             vendor: A1_Manufacturer0
             physical id: 0
             serial: A1_SerialNum0
             slot: DIMM 0
             width: 64 bits
        *-bank:1
             description: SODIMM DDR3 Synchronous Unbuffered (Unregistered) 1600 MHz (0.6 ns)
             product: M471B5173EB0-YK0
             vendor: Samsung
             physical id: 1
             serial: 41611B92
             slot: DIMM 1
             width: 64 bits
             clock: 1600MHz (0.6ns)
     *-cache:0
          description: L1 cache
          physical id: 2c
          slot: L1 CACHE
          capacity: 128KiB
          clock: 1GHz (1.0ns)
          capabilities: pipeline-burst internal write-back unified
          configuration: level=1
     *-cache:1
          description: L2 cache
          physical id: 2d
          slot: L2 CACHE
          capacity: 1MiB
          clock: 1GHz (1.0ns)
          configuration: level=2
     *-cpu
          description: CPU
          product: AMD GX-217GA SOC with Radeon(tm) HD Graphics
          vendor: Advanced Micro Devices [AMD]
          physical id: 2e
          bus info: cpu@0
          version: AMD GX-217GA SOC with Radeon(tm) HD Graphics
          slot: P0
          capacity: 1650MHz
          width: 64 bits
          clock: 100MHz
          capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt topoext perfctr_nb bpext perfctr_llc hw_pstate proc_feedback ssbd vmmcall bmi1 xsaveopt arat npt lbrv svm_lock nrip_save tsc_scale flushbyasid decodeassists pausefilter pfthreshold overflow_recov cpufreq
          configuration: cores=2 enabledcores=2 threads=2
     *-pci:0
          description: Host bridge
          product: Family 16h Processor Root Complex
          vendor: Advanced Micro Devices, Inc. [AMD]
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 00
          width: 32 bits
          clock: 33MHz
        *-display
             description: VGA compatible controller
             product: Kabini [Radeon HD 8280E]
             vendor: Advanced Micro Devices, Inc. [AMD/ATI]
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 00
             width: 64 bits
             clock: 33MHz
             capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
             configuration: driver=radeon latency=0
             resources: irq:35 memory:c0000000-cfffffff memory:d0000000-d07fffff ioport:f000(size=256) memory:feb00000-feb3ffff memory:c0000-dffff
        *-multimedia:0
             description: Audio device
             product: Kabini HDMI/DP Audio
             physical id: 1.1
             bus info: pci@0000:00:01.1
             version: 00
             width: 64 bits
             clock: 33MHz
             capabilities: pm pciexpress msi bus_master cap_list
             configuration: driver=snd_hda_intel latency=0
             resources: irq:33 memory:feb64000-feb67fff
        *-pci
             description: PCI bridge
             product: Family 16h Processor Functions 5:1
             physical id: 2.3
             bus info: pci@0000:00:02.3
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:25 ioport:e000(size=4096) memory:fea00000-feafffff ioport:d0800000(size=1048576)
           *-network
                description: Ethernet interface
                product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:01:00.0
                logical name: eth0
                version: 0c
                serial: 7c:d3:0a:1e:48:03
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.10.139-volumio firmware=rtl8168g-2_0.0.1 02/06/13 latency=0 link=no multicast=yes port=twisted pair
                resources: irq:30 ioport:e000(size=256) memory:fea00000-fea00fff memory:d0800000-d0803fff
        *-usb:0
             description: USB controller
             product: FCH USB XHCI Controller
             physical id: 10
             bus info: pci@0000:00:10.0
             version: 01
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi msix pciexpress xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:18 memory:feb68000-feb69fff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 5.10.139-volumio xhci-hcd
                physical id: 0
                bus info: usb@5
                logical name: usb5
                version: 5.10
                capabilities: usb-2.00
                configuration: driver=hub slots=2 speed=480Mbit/s
              *-usb
                   description: Generic USB device
                   product: 802.11ac NIC
                   vendor: Realtek
                   physical id: 1
                   bus info: usb@5:1
                   version: 2.10
                   serial: 123456
                   capabilities: usb-2.10
                   configuration: driver=rtl88x2bu maxpower=500mA speed=480Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@6
                logical name: usb6
                version: 5.10
                capabilities: usb-3.00
                configuration: driver=hub slots=2 speed=5000Mbit/s
        *-sata
             description: SATA controller
             product: FCH SATA Controller [AHCI mode]
             physical id: 11
             bus info: pci@0000:00:11.0
             logical name: scsi1
             version: 40
             width: 32 bits
             clock: 66MHz
             capabilities: sata pm msi ahci_1.0 bus_master cap_list emulated
             configuration: driver=ahci latency=32
             resources: irq:29 ioport:f140(size=8) ioport:f130(size=4) ioport:f120(size=8) ioport:f110(size=4) ioport:f100(size=16) memory:feb6e000-feb6e3ff
           *-disk
                description: ATA Disk
                product: SanDisk SDSA6MM-
                physical id: 0.0.0
                bus info: scsi@1:0.0.0
                logical name: /dev/sda
                version: 006
                serial: 160817406334
                capabilities: gpt-1.00 partitioned partitioned:gpt
                configuration: ansiversion=5 guid=2bc7fd2b-4c38-4046-a38a-e08927d044bb logicalsectorsize=512 sectorsize=512
              *-volume:0
                   description: Windows FAT volume
                   vendor: SYSLINUX
                   physical id: 1
                   bus info: scsi@1:0.0.0,1
                   logical name: /dev/sda1
                   logical name: /boot
                   version: FAT32
                   serial: 41e1-e59d
                   capacity: 170MiB
                   capabilities: boot fat initialized
                   configuration: FATs=2 filesystem=fat label=boot mount.fstype=vfat mount.options=rw,nosuid,nodev,noexec,relatime,fmask=0111,dmask=0000,allow_utime=0022,codepage=437,iocharset=utf8,shortname=mixed,utf8,errors=remount-ro name=primary state=mounted
              *-volume:1
                   description: EXT4 volume
                   vendor: Linux
                   physical id: 2
                   bus info: scsi@1:0.0.0,2
                   logical name: /dev/sda2
                   logical name: /imgpart
                   version: 1.0
                   serial: c9596fa0-7863-4a53-b9f7-9fe7d6223ee4
                   capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                   configuration: created=2023-01-13 04:54:54 filesystem=ext4 label=volumio lastmountpoint=/mnt/imgpart modified=2023-01-18 00:44:12 mount.fstype=ext4 mount.options=rw,relatime mounted=2023-01-18 00:44:12 name=primary state=mounted
              *-volume:2
                   vendor: Linux
                   physical id: 3
                   bus info: scsi@1:0.0.0,3
                   logical name: /dev/sda3
                   version: 1.0
                   serial: 5a172840-f010-4fe7-8721-9806146cf433
                   configuration: created=2023-01-18 00:26:30 filesystem=ext4 label=volumio_data lastmountpoint=/mnt/ext/union modified=2023-01-18 00:38:20 mounted=2023-01-18 00:38:20 name=primary state=clean
        *-usb:1
             product: FCH USB OHCI Controller
             physical id: 12
             bus info: pci@0000:00:12.0
             version: 39
             width: 32 bits
             clock: 66MHz
             capabilities: ohci bus_master
             configuration: driver=ohci-pci latency=32
             resources: irq:18 memory:feb6d000-feb6dfff
           *-usbhost
                product: OHCI PCI host controller
                vendor: Linux 5.10.139-volumio ohci_hcd
                physical id: 1
                bus info: usb@3
                logical name: usb3
                version: 5.10
                capabilities: usb-1.10
                configuration: driver=hub slots=4 speed=12Mbit/s
              *-usb
                   product: USB Audio CODEC
                   vendor: Burr-Brown from TI
                   physical id: 1
                   bus info: usb@3:1
                   version: 1.00
                   capabilities: usb-1.10 audio-control
                   configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
        *-usb:2
             product: FCH USB EHCI Controller
             physical id: 12.2
             bus info: pci@0000:00:12.2
             version: 39
             width: 32 bits
             clock: 66MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci-pci latency=32
             resources: irq:17 memory:feb6c000-feb6c0ff
           *-usbhost
                product: EHCI Host Controller
                vendor: Linux 5.10.139-volumio ehci_hcd
                physical id: 1
                bus info: usb@1
                logical name: usb1
                version: 5.10
                configuration: driver=hub slots=4 speed=480Mbit/s
              *-usb
                   description: Mass storage device
                   product: Silicon-Power16G
                   vendor: UFD 2.0
                   physical id: 4
                   bus info: usb@1:4
                   logical name: scsi2
                   version: 1.00
                   serial: P1601370070B65D2B1B4CE84
                   capabilities: usb-2.00 scsi emulated
                   configuration: driver=usb-storage maxpower=200mA speed=480Mbit/s
                 *-disk
                      description: SCSI Disk
                      vendor: UFD 2.0
                      physical id: 0.0.0
                      bus info: scsi@2:0.0.0
                      logical name: /dev/sdb
                      version: PMAP
                      serial: P6156D021B31
                      capabilities: removable
                      configuration: ansiversion=6 logicalsectorsize=512 sectorsize=512
                    *-medium
                         physical id: 0
                         capabilities: partitioned partitioned:dos
                         configuration: signature=dab74ad7
                       *-volume
                            description: Windows NTFS volume
                            physical id: 1
                            logical name: /dev/sdb1
                            logical name: /media/PINK
                            version: 3.1
                            serial: a0a2-5df0
                            capacity: 14GiB
                            capabilities: primary ntfs initialized
                            configuration: clustersize=4096 created=2022-10-11 00:08:45 filesystem=ntfs label=PINK mount.fstype=fuseblk mount.options=rw,noatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 state=mounted
        *-usb:3
             physical id: 13
             bus info: pci@0000:00:13.0
             version: 39
             width: 32 bits
             clock: 66MHz
             resources: irq:18 memory:feb6b000-feb6bfff
           *-usbhost
                physical id: 1
                bus info: usb@4
                logical name: usb4
                version: 5.10
        *-usb:4
             physical id: 13.2
             bus info: pci@0000:00:13.2
             version: 39
             width: 32 bits
             clock: 66MHz
             resources: irq:17 memory:feb6a000-feb6a0ff
           *-usbhost
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 5.10
        *-serial
             description: SMBus
             product: FCH SMBus Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 3a
             width: 32 bits
             clock: 66MHz
             configuration: driver=piix4_smbus latency=0
             resources: irq:0
        *-multimedia:1
             product: FCH Azalia Controller
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 02
             width: 64 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=snd_hda_intel latency=32
             resources: irq:16 memory:feb60000-feb63fff
        *-isa
             description: ISA bridge
             product: FCH LPC Bridge
             physical id: 14.3
             bus info: pci@0000:00:14.3
             version: 11
             width: 32 bits
             clock: 66MHz
             capabilities: isa bus_master
             configuration: latency=0
     *-pci:1
          product: Family 16h Processor Function 0
          physical id: 101
          bus info: pci@0000:00:02.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:2
          physical id: 102
          bus info: pci@0000:00:18.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:3
          product: Family 16h Processor Function 1
          physical id: 103
          bus info: pci@0000:00:18.1
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:4
          product: Family 16h Processor Function 2
          physical id: 104
          bus info: pci@0000:00:18.2
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:5
          product: Family 16h Processor Function 3
          physical id: 105
          bus info: pci@0000:00:18.3
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:6
          product: Family 16h Processor Function 4
          physical id: 106
          bus info: pci@0000:00:18.4
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:7
          product: Family 16h Processor Function 5
          physical id: 107
          bus info: pci@0000:00:18.5
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pnp00:00
          product: PnP device PNP0c01
          physical id: 1
          capabilities: pnp
          configuration: driver=system
     *-pnp00:01
          product: PnP device PNP0c02
          physical id: 2
          capabilities: pnp
     *-pnp00:02
          physical id: 3
          capabilities: pnp
     *-pnp00:03
          physical id: 4
          capabilities: pnp
     *-pnp00:04
          product: PnP device PNP0b00
          physical id: 5
          capabilities: pnp
          configuration: driver=rtc_cmos
     *-pnp00:05
          physical id: 6
          capabilities: pnp
     *-pnp00:06
          product: PnP device PNP0303
          physical id: 7
          capabilities: pnp
          configuration: driver=i8042 kbd
     *-pnp00:07
          product: PnP device PNP0f03
          physical id: 8
          capabilities: pnp
          configuration: driver=i8042 aux
     *-pnp00:08
          product: PnP device PNP0501
          physical id: 9
          capabilities: pnp
          configuration: driver=serial
     *-pnp00:09
          product: PnP device IFX0102
          physical id: a
          capabilities: pnp
          configuration: driver=tpm_tis
     *-pnp00:0a
          physical id: b
          capabilities: pnp
  *-power UNCLAIMED
       product: Standard Efficiency
       physical id: 1
       capacity: 32768mWh
  *-network
       description: Wireless interface
       physical id: 2
       bus info: usb@5:1
       logical name: wlan0
       serial: b0:a7:b9:0b:88:25
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl88x2bu driverversion=5.10.139-volumio ip=10.1.1.143 multicast=yes wireless=IEEE 802.11AC
inxi -Fxxxz output:
System:
  Host: volumio Kernel: 5.10.139-volumio x86_64 bits: 64 compiler: N/A
  Console: tty 0 dm: N/A Distro: Debian GNU/Linux 10 (buster)
Machine:
  Type: Desktop System: Hewlett-Packard product: HP t620 Dual Core TC v: N/A
  serial: <filter>
  Mobo: Hewlett-Packard model: 2187 v: A01 serial: <filter> UEFI: AMI
  v: L40 v02.10 date: 07/03/2015
CPU:
  Topology: Dual Core model: AMD GX-217GA SOC with Radeon HD Graphics
  bits: 64 type: MCP arch: Jaguar rev: 1 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 6587
  Speed: 1249 MHz min/max: 800/1650 MHz Core speeds (MHz): 1: 1334 2: 1487
Graphics:
  Device-1: AMD Kabini [Radeon HD 8280E] vendor: Hewlett-Packard
  driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9837
  Display: tty server: X.org 1.20.4 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa tty: 80x61
  Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
  Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:9840
  Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus ID: 00:14.2 chip ID: 1022:780d
  Device-3: Texas Instruments PCM2902 Audio Codec type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1:2 chip ID: 08bb:2902
  Sound Server: ALSA v: k5.10.139-volumio
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus ID: 01:00.0
  chip ID: 10ec:8168
  IF: eth0 state: down mac: <filter>
  Device-2: TP-Link type: USB driver: rtl88x2bu bus ID: 5-1:2
  chip ID: 2357:012d serial: <filter>
  IF: wlan0 state: up mac: <filter>
Drives:
  Local Storage: total: 29.36 GiB used: 2.28 GiB (7.8%)
  ID-1: /dev/sda vendor: SanDisk model: SDSA6MM-016G-1006 size: 14.91 GiB
  speed: 6.0 Gb/s serial: <filter> rev: 006 scheme: GPT
  ID-2: /dev/sdb type: USB model: UFD 2.0 Silicon-Power16G size: 14.45 GiB
  serial: <filter> rev: PMAP scheme: MBR
Partition:
  ID-1: / size: 11.09 GiB used: 51.3 MiB (0.5%) fs: overlay source: ERR-102
  ID-2: /boot size: 168.4 MiB used: 61.2 MiB (36.3%) fs: vfat dev: /dev/sda1
Sensors:
  Missing: Required tool sensors not installed. Check --recommends
Info:
  Processes: 129 Uptime: 29m Memory: 3.29 GiB used: 491.9 MiB (14.6%)
  Init: systemd v: 241 runlevel: 5 default: 2 Compilers: gcc: N/A
  Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
Some additional info collected right after boot, when WiFi is not working but LAN is.
/var/log/boot.log output:
[e[0;32m  OK  e[0m] Started e[0;1;39mShow Plymouth Boot Screene[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mLocal Encrypted Volumese[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mPathse[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mForward Password Requests to Plymouth Directory Watche[0m.
[e[0;32m  OK  e[0m] Found device e[0;1;39mSanDisk_SDSA6MM-016G-1006 boote[0m.
         Starting e[0;1;39mFile System Check on /dev/disk/by-uuid/41E1-E59De[0m...
[e[0;32m  OK  e[0m] Listening on e[0;1;39mLoad/Save RF Kill Switch Status /dev/rfkill Watche[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mFile System Check Daemon to report statuse[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mFile System Check on /dev/disk/by-uuid/41E1-E59De[0m.
         Mounting e[0;1;39m/boote[0m...
[e[0;32m  OK  e[0m] Mounted e[0;1;39m/boote[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mLocal File Systemse[0m.
         Starting e[0;1;39mTell Plymouth To Write Out Runtime Datae[0m...
         Starting e[0;1;39mCreate Volatile Files and Directoriese[0m...
         Starting e[0;1;39mPreprocess NFS configuratione[0m...
[e[0;32m  OK  e[0m] Found device e[0;1;39mRTL8111/8168/8411 PCI Express Gigabit Ethernet Controllere[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mTell Plymouth To Write Out Runtime Datae[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mPreprocess NFS configuratione[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mNFS client servicese[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mifup for eth0e[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mCreate Volatile Files and Directoriese[0m.
         Starting e[0;1;39mRPC bind portmap servicee[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mEntropy daemon using the HAVEGE algorithme[0m.
         Starting e[0;1;39mUpdate UTMP about System Boot/Shutdowne[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mUpdate UTMP about System Boot/Shutdowne[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSystem Initializatione[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mD-Bus System Message Bus Sockete[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mmpd.sockete[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mtriggerhappy.sockete[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily man-db regeneratione[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily apt download activitiese[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily apt upgrade and clean activitiese[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily Cleanup of Temporary Directoriese[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mTimerse[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mAvahi mDNS/DNS-SD Stack Activation Sockete[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSocketse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mBasic Systeme[0m.
         Starting e[0;1;39mWireless Servicese[0m...
         Starting e[0;1;39mtriggerhappy global hotkey daemone[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mManage Sound Card State (restore and store)e[0m.
         Starting e[0;1;39mSave/Restore Sound Card Statee[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mD-Bus System Message Buse[0m.
         Starting e[0;1;39mDHCP Client Daemone[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mVolumio Iptables Modulee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mvolumio-remote-updater.servicee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mUPnP Renderer front-end to MPDe[0m.
         Starting e[0;1;39mWPA supplicante[0m...
         Starting e[0;1;39mLogin Servicee[0m...
         Starting e[0;1;39mAvahi mDNS/DNS-SD Stacke[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mLogin Servicee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mtriggerhappy global hotkey daemone[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mRPC bind portmap servicee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDHCP Client Daemone[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mAvahi mDNS/DNS-SD Stacke[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mRemote File Systems (Pre)e[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mRemote File Systemse[0m.
         Starting e[0;1;39mLSB: Load kernel modules needed to enable cpufreq scalinge[0m...
[e[0;32m  OK  e[0m] Reached target e[0;1;39mRPC Port Mappere[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mWPA supplicante[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mLSB: Load kernel modules needed to enable cpufreq scalinge[0m.
         Starting e[0;1;39mLSB: set CPUFreq kernel parameterse[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mSave/Restore Sound Card Statee[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSound Carde[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mLSB: set CPUFreq kernel parameterse[0m.
[e[0;1;31mFAILEDe[0m] Failed to start e[0;1;39mWireless Servicese[0m.
See 'systemctl status wireless.service' for details.
[e[0;32m  OK  e[0m] Started e[0;1;39mVolumio Backend Modulee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mVolumio Streaming Daemone[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mIntel SST and HDA soundcard init servicee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mStart Volumio Kioske[0m.
[e[0;32m  OK  e[0m] Stopped e[0;1;39mVolumio Streaming Daemone[0m.
[e[0;1;31mFAILEDe[0m] Failed to start e[0;1;39mVolumio Streaming Daemone[0m.
See 'systemctl status volumio-streaming-daemon.service' for details.
         Starting e[0;1;39mLoad/Save RF Kill Switch Statuse[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mLoad/Save RF Kill Switch Statuse[0m.
[e[0;32m  OK  e[0m] Found device e[0;1;39m802.11ac_NICe[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mifup for wlan0e[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mHelper to synchronize boot up for ifupdowne[0m.
         Starting e[0;1;39mRaise network interfacese[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mRaise network interfacese[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mNetworke[0m.
         Starting e[0;1;39mMusic Player Daemone[0m...
         Starting e[0;1;39mOpenBSD Secure Shell servere[0m...
         Starting e[0;1;39mNetwork Time Servicee[0m...
         Starting e[0;1;39mPermit User Sessionse[0m...
[e[0;32m  OK  e[0m] Reached target e[0;1;39mNetwork is Onlinee[0m.
         Starting e[0;1;39mSamba NMB Daemone[0m...
         Starting e[0;1;39mLSB: Brings up/down network automaticallye[0m...
         Starting e[0;1;39m/etc/rc.local Compatibilitye[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mShairport Sync - AirPlay Audio Receivere[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mPermit User Sessionse[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39m/etc/rc.local Compatibilitye[0m.
         Starting e[0;1;39mHold until boot process finishes upe[0m...
         Starting e[0;1;39mTerminate Plymouth Boot Screene[0m...
systemctl status wireless.service output:
volumio@volumio:/var/log$ systemctl status wireless.service
 wireless.service - Wireless Services
   Loaded: loaded (/lib/systemd/system/wireless.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2023-01-18 02:46:22 UTC; 4min 8s ago
  Process: 424 ExecStart=/volumio/app/plugins/system_controller/network/wireless.js start (code=exited, status=1/FAILURE)
Jan 18 02:46:18 volumio systemd[1]: Starting Wireless Services...
Jan 18 02:46:22 volumio wireless.js[424]: WIRELESS: No wireless interface, exiting
Jan 18 02:46:22 volumio systemd[1]: wireless.service: Control process exited, code=exited, status=1/FAILURE
Jan 18 02:46:22 volumio systemd[1]: wireless.service: Failed with result 'exit-code'.
Jan 18 02:46:22 volumio systemd[1]: Failed to start Wireless Services.
With my google fu I came to the following work-around for this. But if anyone knows the root cause I’d love to hear it.
Work-around, via ssh:
Make a script in the home folder called start.sh
nano start.sh
Contents of start.sh:
#!/bin/bash
systemctl restart wireless
Make start.sh executable:
sudo chmod +x start.sh
Install cron:
sudo apt-get update
sudo apt-get install cron
add a crontab entry with root rights:
sudo crontab -e
contents of crontab:
@reboot sleep 30 && /home/volumio/start.sh
Disconnect LAN, and reboot. Patiently. :smiley:
Me as well, I have not seen this behaviour on my DELL Wyse 3040.
And it has not been reported by other T3U users either.
Looks like the settings are not stored properly.
Did you do a proper shutdown/restart?
Unfortunately I can’t test on the rest of the test equipment here as they all have internal wireless.
Stumped nr3 here.
Have tested this one on 3 different x86 without any issues.
  • Dell Wyse 3040
  • HP Elitedesk
  • Toshiba Click mini
Thanks for looking into it. Yes, proper shutdown/restart. Could you expand a little on “the settings are not stored properly” ? Which settings in particular? To me it looks like the T3U never gets an initial start from the OS.
Yes, same T3U here. Thanks for the report. At least for now, the work-around startup script seems solid.
boot.log does not say much, we need a proper volumio log --or-- a complete dmesg
Log output is here
starting without my script systemctl restart wireless solution…
dmesg full output is here
dmesg less output is here
…if you still have patience to look into this.
I don’t see the wifi dongle, at any point, being probed.
What do you see with a simple lsusb? Nothing I suppose.
Did you enable usb in the BIOS? Sometimes this is disabled with thin clients.
@gkkpch
Hi Gé,
Seems something is broken in the x86 image related to the discovery of DNLA/uPnP servers.
While the V3.396 on the rPi shows them,
x86 V3.224 and up won’t show them:
Fyi, the beta builds also shows them.
There is hardly an x86 dependency here, the x86 build does pull a few platform-specific pre-compiled packages, but these have not been updated since the beginning of Volumio 3. The main part is standard, platform independent Volumio stuff.
If there is a difference between versions, then it must be in the Volumio part. Does the same apply to a PI build?
For the rPi i’ve tested and they all show the LMS server:
volumio-2.917-2021-10-06-pi.img
Volumio-3.175-2021-12-13-pi.img
Volumio-3.179-2021-12-20-pi.img
Volumio-3.198-2022-01-24-pi.img
Volumio-3.301-2022-06-09-pi.img
Volumio-3.324-2022-07-11-pi.img
No idea, what about a log? Does it show any error on DLNA/uPnP communication?
Unless there is something with the myVolumio part, did you try the latest x86 test build? It is closest to the beta build…
V3.396
http://logs.volumio.org/volumio/JPtEZzu.html
V3.422 (also not showing the LMS server)
http://logs.volumio.org/volumio/OurA9JS.html
Strange, this is 3.396 on my Dell Wyse:
And on an Asus Notebook with 3.422 it shows nothing.
Shoot me but leakage. (schiet mij maar lek)
Seems the issue is only with the HP’s :frowning_face:
Tested again with the
Dell Wyse 3040 (V3.396)
Toshiba click mini (V3.422):
Both HP Elitedesk (V3.396):
Dell Inspiron 3180 (V3.396):
Odroid N2+ with 3.426 not showing anything either (I snap there also no ball from)
Yep, same for Odroid N2+ V3.417. No DNLA/uPnp
