Ok, will try that now
Thanks ![]()
Hi @rob6736
Log analysis
Oct 17 17:15:07 volumio kernel: DMI: Sony Corporation VPCL12M1E/VAIO, BIOS R1060T5 11/19/2009
So it is internally another model, but thatâs ok.
It appears you device does have the same touchscreen controller as the VPC-L14S1E.
The VPC-L14S1E was released in 2010, your device a year earlier.
It is a âNextWindow Touchscreenâ:
Oct 17 17:15:07 volumio kernel: usb 3-2: new full-speed USB device number 2 using uhci_hcd
Oct 17 17:15:07 volumio kernel: usb 3-2: New USB device found, idVendor=1926, idProduct=0065, bcdDevice= 0.01
Oct 17 17:15:07 volumio kernel: usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 17 17:15:07 volumio kernel: usb 3-2: Product: Touchscreen
Oct 17 17:15:07 volumio kernel: usb 3-2: Manufacturer: NextWindow
Oct 17 17:15:07 volumio kernel: hid-generic 0003:1926:0065.0003: hiddev0,hidraw0: USB HID v1.11 Device [NextWindow Touchscreen] on usb-0000:00:1a.2-2/input1
The problem
Though detected, no driver was loaded.
Going back to the âlinux-hardware.orgâ probe for the NextWindow, there is a note:
We have not found a driver for the device in any Linux kernel versions up to 6.12 according to the LKDDb.
This note is correct, there is no âin-treeâ kernel driver to select to add to our customized kernel version 6.12.y
Alternative Drivers
However, there is the following out-of-tree driver for the device to make it work properly:
better and newer instructions
Someone with the right skills could do this, butâŚ
Out-of-tree drivers are not without risk and in principle unsupported.
They have to be compiled against the exact kernel version. So every time a new Volumio version is released with a newer kernel version, the driver has to be re-compiled.
Therefore, compiling out-of-tree drivers is not recommended.
Conclusion
The above mentioned driver is 12 years old, there is no guarantee the git contents are still valid.
On top of that is a more serious âcaveatâ.
Until now we did not cater for out-of-tree kernel driver additions in our build system for the Volumio x86 platform version.
This means further proceedings would:
- include modification of the Volumio x86 platform build process.
- include testing the driver, with the extra overhead of instructing you how to do so, as we do not have such hardware.
- carry the risk that after a lot of work, it still does not work
Unfortunately this would be an effort we most likely cannot afford.
Therefore I canât support it and will not recommend it to be added to the backlog.
Ok, well I appreciate your time, I assume then Linux driver wonât be found, the windows driver has a date of 2017, which I assume has come from Microsoft, but I understand that Linux probably wonât be supporting a driver for this computer being itâs too old.
I really do appreciate your help.
You put to be continued, so does that mean there maybe a driver some time in the future
Again
Rob
see above, sorry
Ok, I appreciate your help.
Thank you
Rob
Prerequisites
Volumio Information
Volumio Version: 3.866
Hardware: ThinkCentre M75n
DAC: EF400
Debug Log
http://logs.volumio.org/volumio/B6SHvfc.html
Steps to Reproduce
- Update Volumio to 3.866.
- Reboot Volumio.
- Try to open Music library or to play Web radio.
Additional Information
After Volumio update to 3.866 my device canât open Music library or play any Web radio station, live log is full of messages:
error: [ytcr] Error connecting MPD:
(Error) connect ECONNREFUSED /run/mpd/socket
Error: connect ECONNREFUSED /run/mpd/socket
at PipeConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)
Retrying in 5 secondsâŚ
Cantata from external PC with Windows is able to connect to mpd and take library data or play media.
Hey @Thriller,
You have Mpd http & Icecast output plugin installed, however it is not configured:
Oct 23 15:09 : exception: Failed to open "My Ice stream" (shout); problem opening connection to shout server ice.example.com:8015: Couldn't connect
This is your first mpd blocking point that you will need to resolve before anything else.
Hey @nerd,
- Plugin âMpd http & Icecast outputâ was configured and successfully worked after all Volumio OS updates in 2024-2025.
- It doesnât matter because after âMpd http & Icecast outputâ was switched off and Volumio was rebooted nothing was changed with mpd: Volumio still canât open Music library or play Web radio, live log is full of messages
- (Error) connect ECONNREFUSED /run/mpd/socket*
- Error: connect ECONNREFUSED /run/mpd/socket*
at PipeConnectWrap.afterConnect [as oncomplete] (net.js:1159:16)* - Retrying in 5 secondsâŚ*
New log was sent.
Iâve just found out that 3.866 was removed from Volumio OS download page. Itâs nice solution but what should do Volumio users who have already updated their streamers to 3.866?
Iâm not sure what happened, but the 3.866 version is still here Volumio-3.866-2025-10-21-x86_amd64
Volumio OS page not updated (yet)?
3.866 has not being promoted as stable yet, thatâs why itâs not available on the Volumio OS page
it is currently under internal QA test
V4.066, OTA update from 4.062
- no audio on headphone jack (was OK on 4.062)
- internal speakers are working
I checked your log, the soundcard âHDA Intelâ has been supported from the very first x86 versions and never led to discussions.
From the soundcard init messages I conclude that all is well: card recognized, Master mixer was enabled and set with 75% volume.
No idea what causes headphone to fail.
You are sure output âAnalogâ was selected in âPlayback Optionsâ?
Thank you for checking. Yes, Analog is selected.
fwiw, Iâve booted from a MX Linux Live iso and no problems with sound. Broken Hardware setup (cables e.g., broken jack) is ruled out.
Next I will boot Volumio 4.067 from iso and check sound.
@codevoid Could you give me the output from
amixer -c 0
$ amixer -c 0
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 65 [75%] [-16.50dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Simple mixer control 'Mic Boost',0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 31
Front Left: Capture 19 [61%] [12.00dB] [on]
Front Right: Capture 19 [61%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'SoftMaster',0
Limits: 0 - 99
Front Left: 40 [40%]
Front Right: 40 [40%]
Do the internal speakers switch off when you plug in your headphones?
@gkkpch Yes.
Jumped to 4.067 btw, and now even the internal speakers are silent (regardless of pluginstate)
