Sorry, I have no time for such things.
My goal is to support you with Volumio and x86 issues, not to teach you how to use ssh and the shell to create a partition table, ext4 partition and to format it.
I asked you to submit a log, so I can see what is happening with your disk.
If you don’t want to create one, then that descision is yours.
This can be a bit tricky at first.
Just reconnect with eth. Then switch of the hotspot and create the wireless connection.
Make sure to wait for the toast messages, especially after connecting to the network. Wait until networking has restarted AND the network settings page has been redrawn with the eth and wifi ip details.
When you don’t and reboot before that, the data may not have been saved properly.
This is not x86 platform related so I can’t comment on that.
Best to enter this in the general “Feature request” section.
Your choice, you don’t want to know why the disk is not accepted then, fair enough.
Found this:
volumio-wyse1-wifi kernel: mwifiex_sdio mmc0:0001:1 wlan0: renamed from mlan0
You’re lucky, a while ago someone had a Marvell Wifi card and the driver apparently used “mlan0” instead of “wlan0”, which we do not support.
It was fixed by adding a rule to rename a loaded mlan0 device to wlan0.
Otherwise the AW-CM389MA, which also has a Marvell chip, would not have worked with the Dell Wyse either.
That’s amazing. I tried to search for this issue, and couldn’t find it… do you know how to point me to the resolution? I wouldn’t know how to create such a rule.
You do not need the rule for Volumio anymore, it is now a standard build rule in the x86 Volumio images.
But when you insist and need to use it for something else, then I would need to look it up in my notes.
This was my patch, adding a network link.
log "Some wireless network drivers (e.g. for Marvell chipsets) create device 'mlan0'"
log "Rename these to 'wlan0' using a systemd link"
cat <<-EOF > "${ROOTFSMNT}/etc/systemd/network/10-rename-mlan0.link"
[Match]
Type=wlan
Driver=mwifiex_sdio
OriginalName=mlan0
[Link]
Name=wlan0
EOF
Yes, the label needs to be one of
"issd", "ihdd", "Internal SSD" or "Internal HDD"
anything else will be skipped, just to make sure that other internal disk devices are not scanned, which can be unneccesary, time-consuming and even unwanted (think of an internal windows disk with its huge list of short beep and whistle sound files becoming part of the music library).
Sorry - I had misread your previous note. I thought you meant I had to create a manual rule myself, not that I was lucky that you’d already done so! My bad. Appreciate you looking it up. But all is well.
If I had a request, it’d be to increase the verbosity and longevity of messaging on the UI during network configuration to avoid this stupid “it seems like it’s working, let me restart and see if it really is” loop I got stuck in. Because it seems that it has been working - it just takes several minutes after reboot to successfully config. And when I had hotspot on, for whatever reason that Wyse device was failing to find the WiFi network immediately some percentage of the time. So I’m better off leaving hotspot totally off post config. Anyways, all is well, and it seems like it’s working stably for 12 hours. I’ll see how it works the next time that my network goes down or I have to power cycle the device. But right now it’s working great!
Cheers, many thanks for the support and what a cool product!
I’m afraid that is a core Volumio issue, unrelated to the x86 build. I can’t help with that.
Glad you’ve got it all running well.
I have installed the latest Volumio on a intel nuc.
Add some nas folders etc all without any problem.
Now i connect the Spdif from the nuc to my Denon avr.
Unfortunally there is now sound when choosing the right input on the Denon.
Output Volumio is on spdif?
Anybody can help me out with this?
Many thanks in advance
@Wil please provide a system log
Hello Community
I cannot get my toslink (optical out) on my soundcard working.
It is a “Asus Xonar SE” PciE soundcard. It uses an USB 3.1 controller and attaches the sound chip via that USB controller (01:00.0 USB controller: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller).
I can select the “Xonar SoundCard” in Volumio, but i cannot select the toslink of it. Only the normal analog out works. The optical out is visible in alsa as “iec958”:
iec958:CARD=SoundCard,DEV=0
Xonar SoundCard, USB Audio
IEC958 (S/PDIF) Digital Audio Output
So i think in general it should be accessible also by volumio. Maybe the device filtering needs to be adjusted.
Also when i check the card in ubuntu, i can select the optical out without issues and the light turns on. So i think this is not a driver issue.
Can someone help please?
Thanks a lot in advance.
In case of any additional information is required, please tell me what to provide.
Card details:
Audio Processor Cmedia 6620A
D-A Converter Realtek S1220A
A-D Converter Realtek S1220A
Technical outputs:
Edit: See log report.
http://logs.volumio.org/volumio/Wr3QqbU.html
-bash-5.0# aplay -l
card 0: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC671 Analog [ALC671 Analog]
Subdevices: 1/1
card 5: SoundCard [Xonar SoundCard], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 5: SoundCard [Xonar SoundCard], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
card 5: SoundCard [Xonar SoundCard], device 2: USB Audio [USB Audio #2]
Subdevices: 1/1
card 5: SoundCard [Xonar SoundCard], device 3: USB Audio [USB Audio #3]
Subdevices: 1/1
-bash-5.0# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
pulse
PulseAudio Sound Server
default
volumio
volumioOutput
volumioHw
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, HDMI 0
HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
HDA ATI HDMI, HDMI 1
HDMI Audio Output
dmix:CARD=HDMI,DEV=3
Direct sample mixing device
dmix:CARD=HDMI,DEV=7
dsnoop:CARD=HDMI,DEV=3
Direct sample snooping device
dsnoop:CARD=HDMI,DEV=7
hw:CARD=HDMI,DEV=3
Direct hardware device without any conversions
hw:CARD=HDMI,DEV=7
plughw:CARD=HDMI,DEV=3
Hardware device with all software conversions
plughw:CARD=HDMI,DEV=7
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
sysdefault:CARD=Generic
HD-Audio Generic, ALC671 Analog
Default Audio Device
front:CARD=Generic,DEV=0
Front speakers
surround21:CARD=Generic,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=Generic,DEV=0
dsnoop:CARD=Generic,DEV=0
hw:CARD=Generic,DEV=0
plughw:CARD=Generic,DEV=0
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
sysdefault:CARD=SoundCard
front:CARD=SoundCard,DEV=0
Front speakers
surround21:CARD=SoundCard,DEV=0
surround40:CARD=SoundCard,DEV=0
surround41:CARD=SoundCard,DEV=0
surround50:CARD=SoundCard,DEV=0
surround51:CARD=SoundCard,DEV=0
surround71:CARD=SoundCard,DEV=0
dmix:CARD=SoundCard,DEV=0
dmix:CARD=SoundCard,DEV=1
Xonar SoundCard, USB Audio #1
dmix:CARD=SoundCard,DEV=2
Xonar SoundCard, USB Audio #2
dmix:CARD=SoundCard,DEV=3
Xonar SoundCard, USB Audio #3
dsnoop:CARD=SoundCard,DEV=0
dsnoop:CARD=SoundCard,DEV=1
dsnoop:CARD=SoundCard,DEV=2
dsnoop:CARD=SoundCard,DEV=3
hw:CARD=SoundCard,DEV=0
hw:CARD=SoundCard,DEV=1
hw:CARD=SoundCard,DEV=2
hw:CARD=SoundCard,DEV=3
plughw:CARD=SoundCard,DEV=0
plughw:CARD=SoundCard,DEV=1
plughw:CARD=SoundCard,DEV=2
plughw:CARD=SoundCard,DEV=3
usbstream:CARD=SoundCard
Xonar SoundCard
USB Stream Output
-bash-5.0# lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 002: ID 0b05:189d ASUSTek Computer, Inc.
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
-bash-5.0# lsusb -t
/: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 3, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 4, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 5, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 2, If 6, Class=Human Interface Device, Driver=usbhid, 480M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/4p, 12M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/4p, 12M
|__ Port 4: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/4p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/4p, 480M
This is because so far we never enumerated sub devices on USB Audio devices.
With the info you supplied I gather that you know your way around the system.
To check a potential patch, could you replace /volumio/app/plugins/audio-interface/alsa-controller/cards.json with the one I uploaded here?
cards.json (2.9 KB)
Note: this card profile was reduced for testing on x86 only, do not use anywhere else.
Thanks for your reply. I have applied the config and did a reboot of volumio to be sure that the new settings are active. In the volumio device drop down i see 3 options available.
- HDMI 0
- HDMI 1
- Xonar SoundCard
None of the output device selections leads to “light on”.
However, i tested it on os via “aplay” command to see which device selection turns the light on.
KO ---- aplay -D plughw:SoundCard,0 PinkPanther60.wav ----
KO ---- aplay -D plughw:SoundCard,1 PinkPanther60.wav ----
OK ---- aplay -D plughw:SoundCard,2 PinkPanther60.wav ----
OK ---- aplay -D plughw:SoundCard,3 PinkPanther60.wav ----
So maybe the json needs some more customizing… i will try to figure out if i find some way to modify it myself to make it work, but the config format is a bit unclear to me. So if you have any new advice it would be appreciated.
Markus
Perhaps I made a wrong assumption regarding the internal soundcard name.
Could you edit the second line in cards.json and replace “Xonar Soundcard” by just “Soundcard”?
You should get 4 usb devices in the dropdown list, we can name them differently when you can tell me which one is which?
Btw. did you not get the analog output in the dropdown list?
I think I found the problem! It should be “Xonar SoundCard”, not “Xonar Soundcard”
When checking the card names with “aplay -l” (lowercase “l”) i see this.
aplay -l | grep card
So the first device is only named “USB Audio” instead of “USB Audio #0” from the template.
There also was a typo mistake in the custom config - so i changed “USB AUdio” to “USB Audio”
I now changed the line as below as did a reboot, but still only one entry in the drop down.
{“name”: “Soundcard”, “multidevice”: true, “devices”:[{“number”:0, “prettyname”: “USB Audio”, “defaultmixer”: “”},{“number”:1, “prettyname”: “USB Audio #1”, “defaultmixer”: “”},{“number”:2, “prettyname”: “USB Audio #2”, “defaultmixer”: “”},{“number”:3, “prettyname”: “USB Audio #3”, “defaultmixer”: “”}],“type”:“integrated”},
Is a reboot needed each time or does the json get applied directly by just reloading the settings in the browser?
See my previous post.
You need to reboot, or do killall node
