Second state, WiFi and DAC connected cold and not working:
letto
description: Mini Tower Computer
product: FUTRO S900 (S26361-Kxxx-Vyyy)
vendor: FUJITSU
serial: YLDE033443
width: 64 bits
capabilities: smbios-2.7 dmi-2.7 vsyscall32
configuration: administrator_password=disabled boot=normal chassis=mini-tower power-on_password=disabled sku=S26361-Kxxx-Vyyy uuid=75FDA04A-D1BA-11E1-A7AE-001999DE201E
*-core
description: Motherboard
product: D3003-A1
vendor: FUJITSU
physical id: 0
version: S26361-D3003-A1
serial: 39481275
*-firmware
description: BIOS
vendor: FUJITSU // American Megatrends Inc.
physical id: 0
version: V4.6.4.1 R1.14.0 for D3003-A1x
date: 01/27/2012
capacity: 4MiB
capabilities: pci upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
*-cpu
description: CPU
product: AMD G-T44R Processor
vendor: Advanced Micro Devices [AMD]
physical id: 4
bus info: cpu@0
version: AMD G-T44R Processor
serial: To Be Filled By O.E.M.
slot: CPU
capacity: 1200MHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni monitor ssse3 cx16 popcnt lahf_lm svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch ibs skinit wdt hw_pstate vmmcall arat npt lbrv svm_lock nrip_save pausefilter cpufreq
configuration: cores=1 enabledcores=1
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 64KiB
capabilities: internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 512KiB
capabilities: internal varies data
configuration: level=2
*-memory
description: System Memory
physical id: 24
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1333 MHz (0.8 ns)
product: M471B5773DH0-CH9
vendor: Samsung
physical id: 0
serial: 116F2A96
slot: SO-DIMM-1
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
product: RMT1970ED48E8F1333
vendor: Undefined
physical id: 1
serial: 04F39C01
slot: SO-DIMM-2
width: 64 bits
*-pci:0
description: Host bridge
product: Family 14h Processor Root Complex
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 66MHz
configuration: latency=32
*-display
description: VGA compatible controller
product: Wrestler [Radeon HD 6250]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 1
bus info: pci@0000:00:01.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:27 memory:e8000000-efffffff ioport:f000(size=256) memory:feb00000-feb3ffff memory:c0000-dffff
*-multimedia:0
description: Audio device
product: Wrestler HDMI Audio
physical id: 1.1
bus info: pci@0000:00:01.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:26 memory:feb44000-feb47fff
*-pci:0
description: PCI bridge
product: Family 14h Processor Root Port
physical id: 4
bus info: pci@0000:00:04.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:24 ioport:e000(size=4096) memory:f0100000-f02fffff ioport:f0000000(size=1048576)
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth0
version: 06
serial: 00:19:99:de:20:1e
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.10.188-volumio duplex=full firmware=rtl_nic/rtl8168e-2.fw ip=192.168.1.222 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:16 ioport:e000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
*-sata
description: SATA controller
product: SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
physical id: 11
bus info: pci@0000:00:11.0
logical name: scsi0
version: 40
width: 32 bits
clock: 66MHz
capabilities: sata ahci_1.0 bus_master cap_list emulated
configuration: driver=ahci latency=32
resources: irq:19 ioport:f140(size=8) ioport:f130(size=4) ioport:f120(size=8) ioport:f110(size=4) ioport:f100(size=16) memory:feb4f000-feb4f3ff
*-disk
description: ATA Disk
product: Crucial_CT525MX3
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: R060
serial: 174819E39ED3
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=2a86335b-f017-41f7-985c-9ee1f36c30fe logicalsectorsize=512 sectorsize=512
*-volume:0
description: Windows FAT volume
vendor: SYSLINUX
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /boot
version: FAT32
serial: e723-ba6e
capacity: 170MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat label=boot mount.fstype=vfat mount.options=rw,nosuid,nodev,noexec,relatime,fmask=0111,dmask=0000,allow_utime=0022,codepage=437,iocharset=utf8,shortname=mixed,utf8,errors=remount-ro name=primary state=mounted
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /imgpart
version: 1.0
serial: fa8b0db3-60cd-4a1e-9126-7af8663fe93c
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2023-10-13 16:21:06 filesystem=ext4 label=volumio lastmountpoint=/mnt/imgpart modified=2023-10-16 15:08:43 mount.fstype=ext4 mount.options=rw,relatime mounted=2023-10-16 15:08:43 name=primary state=mounted
*-volume:2
vendor: Linux
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
version: 1.0
serial: e34e44f0-6143-43f3-bcfa-e09ef323c6e0
configuration: created=2023-10-13 16:21:07 filesystem=ext4 label=volumio_data lastmountpoint=/mnt/ext/union modified=2023-10-16 14:55:44 mounted=2023-10-16 14:55:44 name=primary state=clean
*-usb:0
description: USB controller
product: SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
physical id: 12
bus info: pci@0000:00:12.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: ohci bus_master
configuration: driver=ohci-pci latency=32
resources: irq:18 memory:feb4e000-feb4efff
*-usbhost
product: OHCI PCI host controller
vendor: Linux 5.10.188-volumio ohci_hcd
physical id: 1
bus info: usb@4
logical name: usb4
version: 5.10
capabilities: usb-1.10
configuration: driver=hub slots=5 speed=12Mbit/s
*-usb
product: Hi-Res Audio
vendor: Synaptics
physical id: 5
bus info: usb@4:5
version: 0.10
serial: 000000000000000000000000
capabilities: usb-2.00 audio-control
configuration: driver=usbhid maxpower=30mA speed=12Mbit/s
*-usb:1
product: SB7x0/SB8x0/SB9x0 USB EHCI Controller
physical id: 12.2
bus info: pci@0000:00:12.2
version: 00
width: 32 bits
clock: 66MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci-pci latency=32
resources: irq:17 memory:feb4d000-feb4d0ff
*-usbhost
product: EHCI Host Controller
vendor: Linux 5.10.188-volumio ehci_hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 5.10
configuration: driver=hub slots=5 speed=480Mbit/s
*-usb
description: Generic USB device
product: 802.11ac WLAN Adapter
vendor: Realtek
physical id: 1
bus info: usb@1:1
version: 2.00
serial: 00e04c000001
capabilities: usb-2.10
configuration: driver=rtl88XXau maxpower=500mA speed=480Mbit/s
*-usb:2
physical id: 13
bus info: pci@0000:00:13.0
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:feb4c000-feb4cfff
*-usbhost
physical id: 1
bus info: usb@5
logical name: usb5
version: 5.10
*-usb:3
physical id: 13.2
bus info: pci@0000:00:13.2
version: 00
width: 32 bits
clock: 66MHz
resources: irq:17 memory:feb4b000-feb4b0ff
*-usbhost
physical id: 1
bus info: usb@2
logical name: usb2
version: 5.10
*-serial
description: SMBus
product: SBx00 SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 42
width: 32 bits
clock: 66MHz
configuration: driver=piix4_smbus latency=0
resources: irq:0
*-multimedia:1
product: SBx00 Azalia (Intel HDA)
physical id: 14.2
bus info: pci@0000:00:14.2
version: 40
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=snd_hda_intel latency=32
resources: irq:16 memory:feb40000-feb43fff
*-isa
description: ISA bridge
product: SB7x0/SB8x0/SB9x0 LPC host controller
physical id: 14.3
bus info: pci@0000:00:14.3
version: 40
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
configuration: latency=0
*-pci:1
product: SBx00 PCI to PCI Bridge
physical id: 14.4
bus info: pci@0000:00:14.4
version: 40
width: 32 bits
clock: 66MHz
capabilities: pci subtractive_decode bus_master vga_palette
*-usb:4
product: SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
physical id: 14.5
bus info: pci@0000:00:14.5
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:feb4a000-feb4afff
*-usbhost
physical id: 1
bus info: usb@6
logical name: usb6
version: 5.10
configuration: driver=hub slots=2 speed=12Mbit/s
*-usb:5
physical id: 16
bus info: pci@0000:00:16.0
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:feb49000-feb49fff
*-usbhost
physical id: 1
bus info: usb@7
logical name: usb7
version: 5.10
configuration: driver=hub slots=4 speed=12Mbit/s
*-usb:6
physical id: 16.2
bus info: pci@0000:00:16.2
version: 00
width: 32 bits
clock: 66MHz
resources: irq:17 memory:feb48000-feb480ff
*-usbhost
physical id: 1
bus info: usb@3
logical name: usb3
version: 5.10
configuration: driver=hub slots=4 speed=480Mbit/s
*-pci:1
product: Family 12h/14h Processor Function 0
physical id: 101
bus info: pci@0000:00:18.0
version: 43
width: 32 bits
clock: 33MHz
*-pci:2
product: Family 12h/14h Processor Function 1
physical id: 102
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
product: Family 12h/14h Processor Function 2
physical id: 103
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
product: Family 12h/14h Processor Function 3
physical id: 104
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
*-pci:5
product: Family 12h/14h Processor Function 4
physical id: 105
bus info: pci@0000:00:18.4
version: 00
width: 32 bits
clock: 33MHz
*-pci:6
product: Family 12h/14h Processor Function 6
physical id: 106
bus info: pci@0000:00:18.5
version: 00
width: 32 bits
clock: 33MHz
*-pci:7
product: Family 12h/14h Processor Function 5
physical id: 107
bus info: pci@0000:00:18.6
version: 00
width: 32 bits
clock: 33MHz
*-pci:8
product: Family 12h/14h Processor Function 7
physical id: 108
bus info: pci@0000:00:18.7
version: 00
width: 32 bits
clock: 33MHz
*-pnp00:00
product: PnP device PNP0c01
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: PnP device PNP0c02
physical id: 2
capabilities: pnp
*-pnp00:02
physical id: 3
capabilities: pnp
*-pnp00:03
product: PnP device PNP0b00
physical id: 5
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:04
physical id: 6
capabilities: pnp
*-pnp00:05
physical id: 7
capabilities: pnp
*-pnp00:06
product: PnP device PNP0303
physical id: 8
capabilities: pnp
configuration: driver=i8042 kbd
*-pnp00:07
product: PnP device PNP0f03
physical id: 9
capabilities: pnp
configuration: driver=i8042 aux
*-pnp00:08
physical id: a
capabilities: pnp
*-network
description: Wireless interface
physical id: 1
bus info: usb@1:1
logical name: wlan0
serial: 78:8c:b5:b8:be:0c
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl88XXau driverversion=5.10.188-volumio ip=169.254.195.212 multicast=yes wireless=unassociated
volumio@letto:~$
System:
Host: letto Kernel: 5.10.188-volumio x86_64 bits: 64 compiler: N/A
Console: tty 1 dm: N/A Distro: Debian GNU/Linux 10 (buster)
Machine:
Type: Desktop System: FUJITSU product: FUTRO S900 v: N/A serial: <filter>
Chassis: type: 6 serial: <filter>
Mobo: FUJITSU model: D3003-A1 v: S26361-D3003-A1 serial: <filter>
BIOS: FUJITSU // American Megatrends v: 4.6.4.1 R1.14.0 for D3003-A1x
date: 01/27/2012
CPU:
Topology: Single Core model: AMD G-T44R bits: 64 type: UP arch: Bobcat
L2 cache: 512 KiB
flags: lm nx pae sse sse2 sse3 sse4a ssse3 svm bogomips: 2394
Speed: 972 MHz min/max: 800/1200 MHz Core speed (MHz): 1: 972
Graphics:
Device-1: AMD Wrestler [Radeon HD 6250] vendor: Fujitsu Solutions
driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9805
Display: tty server: X.org 1.20.4 driver: ati,radeon
unloaded: fbdev,modesetting,vesa tty: 80x24
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
Device-1: AMD Wrestler HDMI Audio vendor: Fujitsu Solutions
driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:1314
Device-2: AMD SBx00 Azalia vendor: Fujitsu Solutions driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1002:4383
Device-3: Conexant Systems (Rockwell) type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 4-5:2 chip ID: 0572:1b08
serial: <filter>
Sound Server: ALSA v: k5.10.188-volumio
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Fujitsu Solutions driver: r8169 v: kernel port: e000
bus ID: 01:00.0 chip ID: 10ec:8168
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: TP-Link type: USB driver: rtl88XXau bus ID: 1-1:2
chip ID: 2357:011e serial: <filter>
IF: wlan0 state: up mac: <filter>
Drives:
Local Storage: total: 489.05 GiB used: 128.24 GiB (26.2%)
ID-1: /dev/sda vendor: Crucial model: CT525MX300SSD1 size: 489.05 GiB
speed: 6.0 Gb/s serial: <filter> rev: R060 scheme: GPT
Partition:
ID-1: / size: 476.82 GiB used: 127.35 GiB (26.7%) fs: overlay
source: ERR-102
ID-2: /boot size: 168.4 MiB used: 61.2 MiB (36.4%) fs: vfat dev: /dev/sda1
Sensors:
Missing: Required tool sensors not installed. Check --recommends
Info:
Processes: 128 Uptime: 24m Memory: 3.69 GiB used: 455.0 MiB (12.0%)
Init: systemd v: 241 runlevel: 5 default: 2 Compilers: gcc: N/A
Shell: bash v: 5.0.3 running in: tty 1 (SSH) inxi: 3.0.32
volumio@letto:~$
