you right, my previous post was this on: Waveshare DSI LCD displays - #166 by danidemo.
Here updated info:
What screen are you using? Waveshare 11.9 DSI display
Volumio version: 3.611
No additional driver installed. (Using only overlay drivers)
cat /boot/userconfig.txt
dtoverlay=vc4-kms-v3d-pi5
dtoverlay=vc4-kms-dsi-waveshare-panel,11_9_inch,dsi0,rotation=90
cat /boot/config.txt
### DO NOT EDIT THIS FILE ###
initramfs volumio.initrd
include volumioconfig.txt
include userconfig.txt
cat /boot/cmdline.txt
splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=serial0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
systemctl status -l volumio-kiosk
● volumio-kiosk.service - Volumio Kiosk
Loaded: loaded (/lib/systemd/system/volumio-kiosk.service; disabled; vendor preset: enabled)
Active: active (running) since Sat 2024-02-03 16:56:17 CET; 11min ago
Main PID: 1187 (startx)
Tasks: 86 (limit: 4915)
CGroup: /system.slice/volumio-kiosk.service
├─1187 /bin/sh /usr/bin/startx /etc/X11/Xsession /opt/volumiokiosk.sh -- -nocursor
├─1210 xinit /etc/X11/Xsession /opt/volumiokiosk.sh -- /usr/bin/X :0 -nocursor -auth /tmp/serverauth.6O5H0JNP ├─1211 /usr/lib/xorg/Xorg :0 -nocursor -auth /tmp/serverauth.6O5H0JNPuG
├─1249 /bin/bash /opt/volumiokiosk.sh
├─1275 /usr/bin/ssh-agent /opt/volumiokiosk.sh
├─1282 /usr/bin/openbox --startup /usr/lib/arm-linux-gnueabihf/openbox-autostart OPENBOX
├─1283 /usr/lib/chromium-browser/chromium-browser-v7 --enable-pinch --simulate-outdated-no-au=Tue, 31 Dec 209 ├─1317 /usr/lib/chromium-browser/crashpad_handler --monitor-self --monitor-self-annotation=ptype=crashpad-han ├─1319 /usr/lib/chromium-browser/crashpad_handler --no-periodic-tasks --monitor-self-annotation=ptype=crashpa ├─1323 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --no-zygote-sandbox --force-device-scale-f ├─1324 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --force-device-scale-factor=1 --enable-cra ├─1326 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --force-device-scale-factor=1 --enable-cra ├─1356 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility --utility-sub-type=network.mojom.NetworkS ├─1371 /usr/lib/chromium-browser/chromium-browser-v7 --type=gpu-process --field-trial-handle=1822519767111058 ├─1373 /usr/lib/chromium-browser/chromium-browser-v7 --type=broker
├─1382 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility --utility-sub-type=storage.mojom.StorageS ├─1399 /usr/lib/chromium-browser/chromium-browser-v7 --type=renderer --disable-breakpad --force-device-scale- └─1400 /usr/lib/chromium-browser/chromium-browser-v7 --type=renderer --disable-breakpad --force-device-scale-
Feb 03 16:56:17 volumio startx[1187]: (++) from command line, (!!) notice, (II) informational,
Feb 03 16:56:17 volumio startx[1187]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Feb 03 16:56:17 volumio startx[1187]: (==) Log file: "/var/log/Xorg.0.log", Time: Sat Feb 3 16:56:17 2024
Feb 03 16:56:17 volumio startx[1187]: (==) Using config directory: "/etc/X11/xorg.conf.d"
lines 1-29...skipping...
├─1210 xinit /etc/X11/Xsession /opt/volumiokiosk.sh -- /usr/bin/X :0 -nocursor -auth /tmp/serverauth.6O5H0JNPuG
├─1283 /usr/lib/chromium-browser/chromium-browser-v7 --enable-pinch --simulate-outdated-no-au=Tue, 31 Dec 2099 23:59:59 GMT --force-device-scale-factor=1 --disable-pinch --kiosk --no-first-run --noerrdialogs --disable-3d-apis --disable-breakpad --disable-crash-reporter --disable-infobars --disable-session-crashed-bubble --disable-translate --user-data-dir=/data/vol ├─1317 /usr/lib/chromium-browser/crashpad_handler --monitor-self --monitor-self-annotation=ptype=crashpad-handler --database=/home/volumio/.config/chromium/Crash Reports --metrics-dir=/data/volumiokiosk --annotation=channel=Built on Raspbian , running on Raspbian 10 --annotation=lsb-release=Raspbian GNU/Linux 10 (buster) --annotation=plat=Linux --annotation=prod=Ch ├─1319 /usr/lib/chromium-browser/crashpad_handler --no-periodic-tasks --monitor-self-annotation=ptype=crashpad-handler --database=/home/volumio/.config/chromium/Crash Reports --annotation=channel=Built on Raspbian , running on Raspbian 10 --annotation=lsb-release=Raspbian GNU/Linux 10 (buster) --annotation=plat=Linux --annotation=prod=Chrome_Linux --annotation=ver= ├─1323 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --no-zygote-sandbox --force-device-scale-factor=1 --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data-dir=/data/volumiokiosk --enable-crashpad
├─1324 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --force-device-scale-factor=1 --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data-dir=/data/volumiokiosk --enable-crashpad
├─1326 /usr/lib/chromium-browser/chromium-browser-v7 --type=zygote --force-device-scale-factor=1 --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data-dir=/data/volumiokiosk --enable-crashpad
├─1356 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility --utility-sub-type=network.mojom.NetworkService --field-trial-handle=18225197671110586988,13934916106031750273,131072 --lang=en-US --service-sandbox-type=none --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data-di ├─1371 /usr/lib/chromium-browser/chromium-browser-v7 --type=gpu-process --field-trial-handle=18225197671110586988,13934916106031750273,131072 --disable-breakpad --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data-dir=/data/volumiokiosk --gpu-preferences=UAAAAAAAAAAgAAAQAAAAAAAAAAA ├─1373 /usr/lib/chromium-browser/chromium-browser-v7 --type=broker
├─1382 /usr/lib/chromium-browser/chromium-browser-v7 --type=utility --utility-sub-type=storage.mojom.StorageService --field-trial-handle=18225197671110586988,13934916106031750273,131072 --lang=en-US --service-sandbox-type=utility --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data ├─1399 /usr/lib/chromium-browser/chromium-browser-v7 --type=renderer --disable-breakpad --force-device-scale-factor=1 --field-trial-handle=18225197671110586988,13934916106031750273,131072 --disable-gpu-compositing --lang=en-US --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data-di └─1400 /usr/lib/chromium-browser/chromium-browser-v7 --type=renderer --disable-breakpad --force-device-scale-factor=1 --field-trial-handle=18225197671110586988,13934916106031750273,131072 --disable-gpu-compositing --lang=en-US --enable-crashpad --crashpad-handler-pid=0 --enable-crash-reporter=,Built on Raspbian , running on Raspbian 10 --noerrdialogs --user-data-di
Feb 03 16:56:17 volumio startx[1187]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Feb 03 16:56:17 volumio startx[1187]: MESA-LOADER: failed to open drm-rp1-dsi (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
Feb 03 16:56:17 volumio startx[1187]: failed to load driver: drm-rp1-dsi
Feb 03 16:56:18 volumio startx[1187]: V3D 7.1 not supported by this version of Mesa.
Feb 03 16:56:18 volumio startx[1187]: (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
Feb 03 16:56:18 volumio startx[1187]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
cat /var/log/Xorg.0.log
[ 28.044]
X.Org X Server 1.20.4
[ 28.045] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 28.045] Current Operating System: Linux volumio 6.1.69-v8+ #1710 SMP PREEMPT Thu Dec 21 13:21:40 GMT 2023 aarch64
[ 28.045] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 clk_ignore_unused smsc95xx.macaddr=D8:3A:DD:E5:C1:81 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA10,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 28.045] Build Date: 04 April 2023 07:50:56AM
[ 28.045] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 28.045] Current version of pixman: 0.36.0
[ 28.045] Before reporting problems, check http://wiki.x.org
[ 28.045] Markers: (--) probed, (**) from config file, (==) default setting,
[ 28.046] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Feb 3 16:56:17 2024
[ 28.054] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 28.054] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 28.058] (==) No Layout section. Using the first Screen section.
[ 28.058] (==) No screen section available. Using defaults.
[ 28.058] (**) |-->Screen "Default Screen Section" (0)
[ 28.058] (**) | |-->Monitor "<default monitor>"
[ 28.062] (==) No monitor specified for screen "Default Screen Section".
[ 28.062] (==) Automatically adding devices
[ 28.062] (==) Automatically enabling devices
[ 28.062] (==) Automatically adding GPU devices
[ 28.065] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 28.066] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 28.066] Entry deleted from font path.
[ 28.067] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 28.067] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 28.067] (II) The server relies on udev to provide the list of input devices.
[ 28.067] (II) Loader magic: 0x1fdf80
[ 28.067] (II) Module ABI versions:
[ 28.067] X.Org ANSI C Emulation: 0.4
[ 28.067] X.Org Video Driver: 24.0
[ 28.068] X.Org XInput driver : 24.1
[ 28.068] X.Org Server Extension : 10.0
[ 28.068] (--) using VT number 2
[ 28.068] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 28.070] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 28.087] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 28.087] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 28.088] (II) no primary bus or device found
[ 28.088] falling back to /sys/devices/platform/axi/1000120000.pcie/1f00118000.dsi/drm/card1
[ 28.088] (II) LoadModule: "glx"
[ 28.089] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 28.104] (II) Module glx: vendor="X.Org Foundation"
[ 28.104] compiled for 1.20.4, module version = 1.0.0
[ 28.104] ABI class: X.Org Server Extension, version 10.0
[ 28.104] (==) Matched modesetting as autoconfigured driver 0
[ 28.104] (==) Matched fbdev as autoconfigured driver 1
[ 28.104] (==) Assigned the driver to the xf86ConfigLayout
[ 28.104] (II) LoadModule: "modesetting"
[ 28.104] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 28.106] (II) Module modesetting: vendor="X.Org Foundation"
[ 28.106] compiled for 1.20.4, module version = 1.20.4
[ 28.106] Module class: X.Org Video Driver
[ 28.106] ABI class: X.Org Video Driver, version 24.0
[ 28.106] (II) LoadModule: "fbdev"
[ 28.106] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 28.107] (II) Module fbdev: vendor="X.Org Foundation"
[ 28.107] compiled for 1.20.3, module version = 0.5.0
[ 28.107] Module class: X.Org Video Driver
[ 28.107] ABI class: X.Org Video Driver, version 24.0
[ 28.107] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 28.107] (II) FBDEV: driver for framebuffer: fbdev
[ 28.142] (II) modeset(0): using drv /dev/dri/card1
[ 28.142] (WW) Falling back to old probe method for fbdev
[ 28.142] (II) Loading sub module "fbdevhw"
[ 28.143] (II) LoadModule: "fbdevhw"
[ 28.143] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 28.144] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 28.144] compiled for 1.20.4, module version = 0.0.2
[ 28.144] ABI class: X.Org Video Driver, version 24.0
[ 28.144] (II) modeset(G0): using drv /dev/dri/card2
[ 28.144] (II) modeset(0): Creating default Display subsection in Screen section
[ 28.144] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 28.144] (==) modeset(0): RGB weight 888
[ 28.144] (==) modeset(0): Default visual is TrueColor
[ 28.144] (II) Loading sub module "glamoregl"
[ 28.144] (II) LoadModule: "glamoregl"
[ 28.144] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 28.164] (II) Module glamoregl: vendor="X.Org Foundation"
[ 28.164] compiled for 1.20.4, module version = 1.0.1
[ 28.164] ABI class: X.Org ANSI C Emulation, version 0.4
[ 28.594] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 28.595] (EE) modeset(0): glamor initialization failed
[ 28.595] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 28.595] (II) modeset(0): Output DSI-1 has no monitor section
[ 28.595] (II) modeset(0): EDID for output DSI-1
[ 28.595] (II) modeset(0): Printing probed modes for output DSI-1
[ 28.595] (II) modeset(0): Modeline "320x1480"x53.8 50.00 320 380 440 560 1480 1540 1600 1660 (89.3 kHz eP)
[ 28.595] (II) modeset(0): Output DSI-1 connected
[ 28.595] (II) modeset(0): Using exact sizes for initial modes
[ 28.595] (II) modeset(0): Output DSI-1 using initial mode 320x1480 +0+0
[ 28.595] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 28.595] (==) modeset(0): DPI set to (96, 96)
[ 28.595] (II) Loading sub module "fb"
[ 28.595] (II) LoadModule: "fb"
[ 28.596] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 28.598] (II) Module fb: vendor="X.Org Foundation"
[ 28.598] compiled for 1.20.4, module version = 1.0.0
[ 28.598] ABI class: X.Org ANSI C Emulation, version 0.4
[ 28.598] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 28.598] (==) modeset(G0): RGB weight 888
[ 28.598] (==) modeset(G0): Default visual is TrueColor
[ 28.598] (II) Loading sub module "glamoregl"
[ 28.598] (II) LoadModule: "glamoregl"
[ 28.598] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 28.598] (II) Module glamoregl: vendor="X.Org Foundation"
[ 28.598] compiled for 1.20.4, module version = 1.0.1
[ 28.954] (II) modeset(G0): Refusing to try glamor on llvmpipe
[ 28.955] (EE) modeset(G0): glamor initialization failed
[ 28.955] (II) modeset(G0): ShadowFB: preferred NO, enabled NO
[ 28.957] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 28.959] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[ 28.962] (II) modeset(G0): EDID for output HDMI-1-1
[ 28.964] (II) modeset(G0): EDID for output HDMI-1-2
[ 28.964] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 28.964] (==) modeset(G0): DPI set to (96, 96)
[ 28.964] (II) Loading sub module "fb"
[ 28.964] (II) LoadModule: "fb"
[ 28.964] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 28.964] (II) Module fb: vendor="X.Org Foundation"
[ 28.964] compiled for 1.20.4, module version = 1.0.0
[ 28.964] ABI class: X.Org ANSI C Emulation, version 0.4
[ 28.964] (II) UnloadModule: "fbdev"
[ 28.964] (II) Unloading fbdev
[ 28.964] (II) UnloadSubModule: "fbdevhw"
[ 28.964] (II) Unloading fbdevhw
[ 28.971] (==) modeset(G0): Backing store enabled
[ 28.971] (==) modeset(G0): Silken mouse enabled
[ 28.974] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 28.974] (==) modeset(G0): DPMS enabled
[ 28.975] (==) modeset(0): Backing store enabled
[ 28.975] (==) modeset(0): Silken mouse enabled
[ 28.979] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 28.979] (==) modeset(0): DPMS enabled
[ 28.979] (II) Initializing extension Generic Event Extension
[ 28.980] (II) Initializing extension SHAPE
[ 28.980] (II) Initializing extension MIT-SHM
[ 28.980] (II) Initializing extension XInputExtension
[ 28.982] (II) Initializing extension XTEST
[ 28.982] (II) Initializing extension BIG-REQUESTS
[ 28.982] (II) Initializing extension SYNC
[ 28.983] (II) Initializing extension XKEYBOARD
[ 28.983] (II) Initializing extension XC-MISC
[ 28.983] (II) Initializing extension SECURITY
[ 28.984] (II) Initializing extension XFIXES
[ 28.984] (II) Initializing extension RENDER
[ 28.984] (II) Initializing extension RANDR
[ 28.985] (II) Initializing extension COMPOSITE
[ 28.985] (II) Initializing extension DAMAGE
[ 28.985] (II) Initializing extension MIT-SCREEN-SAVER
[ 28.986] (II) Initializing extension DOUBLE-BUFFER
[ 28.986] (II) Initializing extension RECORD
[ 28.986] (II) Initializing extension DPMS
[ 28.987] (II) Initializing extension Present
[ 28.987] (II) Initializing extension DRI3
[ 28.987] (II) Initializing extension X-Resource
[ 28.987] (II) Initializing extension XVideo
[ 28.988] (II) Initializing extension XVideo-MotionCompensation
[ 28.988] (II) Initializing extension SELinux
[ 28.988] (II) SELinux: Disabled on system
[ 28.988] (II) Initializing extension GLX
[ 28.988] (II) AIGLX: Screen 0 is not DRI2 capable
[ 29.034] (II) IGLX: Loaded and initialized swrast
[ 29.034] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 29.034] (II) Initializing extension XFree86-VidModeExtension
[ 29.034] (II) Initializing extension XFree86-DGA
[ 29.034] (II) Initializing extension XFree86-DRI
[ 29.036] (II) Initializing extension DRI2
[ 29.036] (II) modeset(G0): Damage tracking initialized
[ 29.037] (II) modeset(0): Damage tracking initialized
[ 29.037] (II) modeset(0): Setting screen physical size to 84 x 391
[ 29.110] (II) config/udev: Adding input device 6-0014 Goodix Capacitive TouchScreen (/dev/input/event1)
[ 29.110] (**) 6-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput keyboard catchall"
[ 29.110] (**) 6-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput touchscreen catchall"
[ 29.110] (**) 6-0014 Goodix Capacitive TouchScreen: Applying InputClass "Touch rotation"
[ 29.110] (II) LoadModule: "libinput"
[ 29.110] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 29.119] (II) Module libinput: vendor="X.Org Foundation"
[ 29.119] compiled for 1.20.3, module version = 0.28.2
[ 29.119] Module class: X.Org XInput Driver
[ 29.119] ABI class: X.Org XInput driver, version 24.1
[ 29.119] (II) Using input driver 'libinput' for '6-0014 Goodix Capacitive TouchScreen'
[ 29.119] (**) 6-0014 Goodix Capacitive TouchScreen: always reports core events
[ 29.119] (**) Option "Device" "/dev/input/event1"
[ 29.119] (**) Option "_source" "server/udev"
[ 29.127] (II) event1 - 6-0014 Goodix Capacitive TouchScreen: is tagged by udev as: Keyboard Touchscreen
[ 29.128] (II) event1 - 6-0014 Goodix Capacitive TouchScreen: device is a keyboard
[ 29.128] (II) event1 - 6-0014 Goodix Capacitive TouchScreen: device is a touch device
[ 29.128] (II) event1 - 6-0014 Goodix Capacitive TouchScreen: device removed
[ 29.148] (II) libinput: 6-0014 Goodix Capacitive TouchScreen: needs a virtual subdevice
[ 29.148] (**) Option "config_info" "udev:/sys/devices/platform/axi/1000120000.pcie/1f00088000.i2c/i2c-6/6-0014/input/input1/event1"
[ 29.148] (II) XINPUT: Adding extended input device "6-0014 Goodix Capacitive TouchScreen" (type: TOUCHSCREEN, id 6)
[ 29.148] (**) Option "AccelerationScheme" "none"
[ 29.148] (**) 6-0014 Goodix Capacitive TouchScreen: (accel) selected scheme none/0
[ 29.148] (**) 6-0014 Goodix Capacitive TouchScreen: (accel) acceleration factor: 2.000
[ 29.148] (**) 6-0014 Goodix Capacitive TouchScreen: (accel) acceleration threshold: 4
[ 29.150] (II) event1 - 6-0014 Goodix Capacitive TouchScreen: is tagged by udev as: Keyboard Touchscreen
[ 29.150] (II) event1 - 6-0014 Goodix Capacitive TouchScreen: device is a keyboard
[ 29.150] (II) event1 - 6-0014 Goodix Capacitive TouchScreen: device is a touch device
[ 29.151] (II) config/udev: Adding input device 6-0014 Goodix Capacitive TouchScreen (/dev/input/mouse0)
[ 29.151] (II) No input driver specified, ignoring this device.
[ 29.151] (II) This device may have been added with another device file.
[ 29.153] (II) config/udev: Adding input device pwr_button (/dev/input/event0)
[ 29.153] (**) pwr_button: Applying InputClass "libinput keyboard catchall"
[ 29.153] (II) Using input driver 'libinput' for 'pwr_button'
[ 29.153] (**) pwr_button: always reports core events
[ 29.153] (**) Option "Device" "/dev/input/event0"
[ 29.153] (**) Option "_source" "server/udev"
[ 29.153] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 29.153] (II) event0 - pwr_button: device is a keyboard
[ 29.153] (II) event0 - pwr_button: device removed
[ 29.176] (**) Option "config_info" "udev:/sys/devices/platform/pwr_button/input/input0/event0"
[ 29.176] (II) XINPUT: Adding extended input device "pwr_button" (type: KEYBOARD, id 7)
[ 29.176] (**) Option "xkb_model" "pc105"
[ 29.176] (**) Option "xkb_layout" "us"
[ 29.177] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 29.177] (II) event0 - pwr_button: device is a keyboard
[ 29.177] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event2)
[ 29.177] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 29.177] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 29.177] (**) vc4-hdmi-0: always reports core events
[ 29.177] (**) Option "Device" "/dev/input/event2"
[ 29.177] (**) Option "_source" "server/udev"
[ 29.179] (II) event2 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 29.179] (II) event2 - vc4-hdmi-0: device is a pointer
[ 29.179] (II) event2 - vc4-hdmi-0: device is a keyboard
[ 29.179] (II) event2 - vc4-hdmi-0: device removed
[ 29.192] (II) libinput: vc4-hdmi-0: needs a virtual subdevice
[ 29.192] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input3/event2"
[ 29.192] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: MOUSE, id 8)
[ 29.192] (**) Option "AccelerationScheme" "none"
[ 29.192] (**) vc4-hdmi-0: (accel) selected scheme none/0
[ 29.192] (**) vc4-hdmi-0: (accel) acceleration factor: 2.000
[ 29.192] (**) vc4-hdmi-0: (accel) acceleration threshold: 4
[ 29.193] (II) event2 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 29.193] (II) event2 - vc4-hdmi-0: device is a pointer
[ 29.193] (II) event2 - vc4-hdmi-0: device is a keyboard
[ 29.194] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event3)
[ 29.194] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 29.194] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 29.194] (**) vc4-hdmi-1: always reports core events
[ 29.194] (**) Option "Device" "/dev/input/event3"
[ 29.194] (**) Option "_source" "server/udev"
[ 29.196] (II) event3 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 29.196] (II) event3 - vc4-hdmi-1: device is a pointer
[ 29.196] (II) event3 - vc4-hdmi-1: device is a keyboard
[ 29.197] (II) event3 - vc4-hdmi-1: device removed
[ 29.220] (II) libinput: vc4-hdmi-1: needs a virtual subdevice
[ 29.220] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input4/event3"
[ 29.220] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: MOUSE, id 9)
[ 29.220] (**) Option "AccelerationScheme" "none"
[ 29.220] (**) vc4-hdmi-1: (accel) selected scheme none/0
[ 29.220] (**) vc4-hdmi-1: (accel) acceleration factor: 2.000
[ 29.220] (**) vc4-hdmi-1: (accel) acceleration threshold: 4
[ 29.221] (II) event3 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 29.222] (II) event3 - vc4-hdmi-1: device is a pointer
[ 29.222] (II) event3 - vc4-hdmi-1: device is a keyboard
[ 29.240] (**) 6-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput keyboard catchall"
[ 29.240] (**) 6-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput touchscreen catchall"
[ 29.240] (**) 6-0014 Goodix Capacitive TouchScreen: Applying InputClass "Touch rotation"
[ 29.240] (II) Using input driver 'libinput' for '6-0014 Goodix Capacitive TouchScreen'
[ 29.240] (**) 6-0014 Goodix Capacitive TouchScreen: always reports core events
[ 29.240] (**) Option "Device" "/dev/input/event1"
[ 29.240] (**) Option "_source" "_driver/libinput"
[ 29.240] (II) libinput: 6-0014 Goodix Capacitive TouchScreen: is a virtual subdevice
[ 29.240] (**) Option "config_info" "udev:/sys/devices/platform/axi/1000120000.pcie/1f00088000.i2c/i2c-6/6-0014/input/input1/event1"
[ 29.240] (II) XINPUT: Adding extended input device "6-0014 Goodix Capacitive TouchScreen" (type: KEYBOARD, id 10)
[ 29.240] (**) Option "xkb_model" "pc105"
[ 29.240] (**) Option "xkb_layout" "us"
[ 29.240] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 29.240] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 29.240] (**) vc4-hdmi-0: always reports core events
[ 29.240] (**) Option "Device" "/dev/input/event2"
[ 29.240] (II) libinput: vc4-hdmi-0: is a virtual subdevice
[ 29.240] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input3/event2"
[ 29.240] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: KEYBOARD, id 11)
[ 29.240] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 29.240] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 29.240] (**) vc4-hdmi-1: always reports core events
[ 29.240] (**) Option "Device" "/dev/input/event3"
[ 29.240] (II) libinput: vc4-hdmi-1: is a virtual subdevice
[ 29.240] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input4/event3"
[ 29.240] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: KEYBOARD, id 12)
[ 32.310] (II) modeset(0): Disabling kernel dirty updates, not required.
xrandr --display :0 --query
Screen 0: minimum 320 x 200, current 320 x 1480, maximum 4096 x 4096
DSI-1 connected primary 320x1480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
320x1480 53.79*+
Thanks Wheaten
