As mentioned in the official announcement, Volumio team is happy to release the Beta Volumio3 porting for the Radxa RockPi-4B and RockPi-4B+
Hardware Specs
- Rockchip RK3399 Hexa-core 64 bit processor, dual Cortex-A72 (freqency up to 1.8GHz) and quad Cortex-A53 (frequency up to 1.4GHz)
- Up to 4GB DDR4 RAM
- Two USB 3.0 ports and two USB 2.0 ports
- Gigabit Ethernet LAN
- Onboard WiFi 5 AC / BT 5.0 module
- Boot from micro-SD
- Boot from EMMC (on RockPi-4B only, with optional module)
- Onboard DAC with 3.5mm jack
- I2S Bus exposed on 40-pin GPIO connector, same pinout as Raspberry Pi
Recommended variant for a smooth Volumio experience
- 2GB RAM
Remarks
- For installing Volumio on the EMMC module, it is recommended to use the EMMC-to-SD adaptor
- It is recommended to use the official heatsink, because the processor can become very hot
- It is recommended to use a 5V/3A power supply (with no HDD connected via USB)
- It is recommended to use a 5V/5A power supply (if HDD is connected via USB)
Download Links
Version 3.569 - Update Volumio backend, support for Tidal FLAC
Version 3.512 - Update Volumio backend, Supersearch and Infinity playback RC
Version 3.503 - Update Volumio backend, Supersearch and Infinity playback Beta
Version 3.456 - First Beta release
Known Issues
- Bluetooth playback is stuttering with the onboard wireless module
