hello, after the latest update realtek wifi broke again, probably related to kernel upgade
Sorry you’re having trouble, but you need to be a lot more specific about the problem, your set up, etc before anyone can help. Have a look at the guidelines and common issues/solutions here:
could you please try with this one?
https://updates.volumio.org/pi/volumio/3.211/Volumio-3.211-2022-01-28-pi.zip
I can not find any documentation on how update manually using a zip, can you link or explain how?
I’d rather not reinstall totally.
thanks
please enable beta updates from the /dev page, then perform a OTA update, you will get that version
That worked fine!
Grazie mille
I’m having WIFI issues all of sudden, my WiFi dongle keeps shutting off after 10 mins after every reboot.
Here is a link to my logs
Looks like 3.211 is working for me
As of last update its Broken again…
From the changelog for V3.233.
https://community.volumio.com/t/volumio-changelog
“NOTE: Many external wifi dongles will stop working , if you encounter this issue please report the wifi dongle model to:
techsupport at volumio dot org”
Thanjs, mailed
Can somebody explain why our WiFi dongles are not working lately ?
Long story short:
We were forced to upgrade the kernel version for Raspberry PI, in order to support the latest model of Raspberry PI 4 v 1.5.
Unfortunately, for those newer kernels, there are no pre-built wi-fi drivers for dongles not already supported by PI. Those were built by a third-party which just stopped providing them.
We tried to support latest PI 1.5 by doing some tricks to retain wi-fi drivers, but it did not ultimately work.
So, we needed to make the choice: upgrade the kernel to support latest PI 4, or drop some wi-fi driver support. Considering that in the future we would have needed to upgrade the kernel anyway, we went for the first choice.
Of course, we could build and maintain those drivers ourselves, but it requires a substantial amount of work which we cannot handle at the moment, and we prefer to prepare a list of supported dongles that you can get if in need.
Is there a way to roll back to prevuis version?
Good news! Can you already say which chipsets work? So I can try to find a matching dongle…
We are waiting for feedbacks from the community…
@DED do you have any news on that? Do we know which dongles work so far?
I went back to 3.175, WiFi is working again
Small input from my side: on my way to the supermarket I passed a Conrad store and decided to check for available WIFI-Dongles and bought 2 cheap (sub 10€) dongles:
At home I found, that both have the RTL8188EUS chipset (thought one had a RALINK chipset in the store) which I can confirm to work :-).
As I only need one dongle: if someone (within Europe) wants the LogiLink send me a PM. It goes a little hard into the USB Port but works without problems.
I have that TP LINK and I’m having problems
Strange. Mine is v3, maybe they changed the chipset?
