I would refrain from “hacking” the Touch Display plugin, but think the cleaner solution would be to use the gpio control plugin. I have not used that plugin, but saw it fails to start only because the npm module “onoff” is missing. I will reply to this issue in the thread https://community.volumio.com/t/plugin-gpio-control-control-gpio-with-volumio2-events.
Awesome, gpio control is now working on Volumio 3 thanks to you.I was considering switching to Volumio 2
For the challenge (and also because it could be the best experience), I’ll try to hack Touch Display plugin too
I post it on the right thread.
Hey,
i’m from germany, unfortunately my english isn’t the best, i have a pi4 and a 3.5 lcd but i can’t get it to work, i’m also new to raspberry can someone help me
Hi toxedo welcome,
Please post all the info of your pi and 3.5 lcd versions brand ect.
and version of volumio this is needed to be able to help you with it.
ask @gvolt to help you with this.
best regards,
dvo
Display 3.5LCD 480x320pixel XPT2046 ------ works on other systems
Volumio 3.198 on PI4
Plugin Touch Display 3.3.1
SSH is running and /dev/
i used the instructions above but after 3-4 commands i saw that he doesn’t want to create . Unfortunately, my knowledge is no longer sufficient
What’s the brand and exact model name of your screen?
If you can’t identify it, post a picture of the display’s PCB.
You may use DeepL or Google translate ![]()
Display 3.5inch RPI DisplayLCD 480x320pixel XPT2046
nothing more is written on it. runs via gpio
here with it runs on raspbian
Ok, that’s something to start from ![]()
Since I don’t know in what state your Volumio installation is now, I recommend to start with a fresh Volumio system, i.e. start from scratch. Make sure to wair some minutes after the first boot of Volumio so the data partition can fully expand. Otherwise you will not be able to install the Touch Display plugin because of too less space.
The following is more or less a copy of my post above, but has been complemented for Volumio 3 (steps 9 and 10). I have also added steps 11 and 12, because “xserver-xorg-input-evdev” is required for the calibration settings in “99-calibration.conf” to take effect.
Install the Touch Display plugin.
Download the display specific overlay:
wget https://github.com/goodtft/LCD-show/raw/master/usr/tft35a-overlay.dtb
- Copy the overlay to “/boot/overlays/tft35a.dtbo”:
sudo cp tft35a-overlay.dtb /boot/overlays/tft35a.dtbo
- Open “boot/userconfig.txt”:
nano /boot/userconfig.txt
- Add the following lines:
dtparam=spi=on
dtoverlay=tft35a
It could be necessary to add a rotation value to the overlay later on.
Save “/boot/userconfig.txt” by typing Ctrl+x then y and Enter.
Download “99-calibration.conf-35-0” as it might be necessary to calibrate the screen:
wget https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-calibration.conf-35-0
- Create “/etc/X11/xorg.conf.d” in case it’s missing and copy “99-calibration.conf-35-0” to “/etc/X11/xorg.conf.d/99-calibration.conf”:
sudo mkdir -p /etc/X11/xorg.conf.d
sudo cp 99-calibration.conf-35-0 /etc/X11/xorg.conf.d/99-calibration.conf
- Download “99-fbturbo.conf” with
sudo wget https://raw.githubusercontent.com/waveshare/LCD-show/master/usr/share/X11/xorg.conf.d/99-fbturbo.conf -P /usr/share/X11/xorg.conf.d
- Change the driver setting in “99-fbturbo.conf” from “fbturbo” to “fbdev”:
sudo sed 's/"fbturbo"/"fbdev"/' -i /usr/share/X11/xorg.conf.d/99-fbturbo.conf
- Install “xserver-xorg-input-evdev” by running
sudo apt-get -y install xserver-xorg-input-evdev
- After that execute
sudo cp /usr/share/X11/xorg.conf.d/10-evdev.conf /usr/share/X11/xorg.conf.d/45-evdev.conf
Reboot.
If the display should not have the orientation you are looking for, add a rotation parameter to the overlay in “/boot/userconfig.txt” so it looks something like this:
dtoverlay=tft35a:rotate=90
This would rotate the display (not touch) by 90 degrees clockwise.
Reboot once again.
If the display rotation appears to be correct now, check if the touch function is already properly aligned to the display. If this should not the be case try to find out by what amount touch has to be rotated. Then head over to the Touch Display’s configuration page and set this value in the rotation setting.
Reboot and check if touch is properly aligned to the display now. It is possible that setting the rotation in the prior step does not suffice. This would be the case if the screen’s touch axes are inverted or swapped which is not uncommon on these kind of screens… Then you would have to find out how the axes are inverted or swapped to be able to find a correction.
Edit: Corrected command in step 3.
Thank you in advance for your help
volumio@volumio2:~$ sudo cp tft35a.dtb /boot/overlays/tft35a.dtbo
[sudo] password for volumio:
cp: cannot stat ‘tft35a.dtb’: No such file or directory
Sorry, my bad. Command has to be:
For future readers I have edited posts #165 and #275 accordingly.
Thank you thank you thank you
it works
I’m going to start again now. but the picture is already there
is it still possible to output the sound via hdmi or is there something getting in the way?
Can I make a backup somehow?
THANKs @gvolt
Don’t know, I don’t use HDMI audio out. Just try it. ![]()
You could make an image of the SD card, to have a backup of the whole system (see How can I create a backup of the Volumio SD card using Win32DiskImager?). But IMHO it doesn’t make too much sense if you know how to setup the display.
Works perfectly for my display “waveshare 4inch RPi LCD (A)” , thanks a lot !!!
Hey me again, now I’ve installed PeppyMeter and wanted to show it on the 3.5 display now it’s telling me something about
error: touch_display: Pointer config cannot be applied: Error: ENOENT: no such file or directory, stat ‘/tmp/.X11-unix/X0’
and /dev/
In what concrete situation does the error message occur?
Is the UI displayed at your screen at all?
Is pointer visibility set to “on”? If so, does the error message disappear after setting it to “off”?
Please post the result of
cat /var/log/Xorg.0.log
volumio was displayed, everything was fine. then i installed peppymeter because i needed the 3.5 display for it. now the display is only black illuminated. the error comes when I want to activate the mouse pointer, for example, or play a song
result of
-------------- CLEARED LOG --------------
Do you have the PeppyMeter plugin enabled? If so, does the error also happen with the PeppyMeter plugin disabled?
I first brought volumio up to date (fresh installed) then I installed touch display peppymeter on it install. and then installed the 3.5…
Can I disable peppymeter with one command?
If you installed the PeppyMeter plugin you should be able to disable it. Otherwise I don’t know, because I neither know peppymeter well enough nor what installation steps you took. ![]()
Without knowing your Volumio version I imply you are using Volumio 3.x.
If you cannot exclude the possibility that your system could be messed up by earlier attempts to make the display work, I recommend to start with a fresh Volumio system, i.e. start from scratch. In that case make sure to wait some minutes after the first boot of Volumio so the data partition can fully expand. Otherwise you will not be able to install the Touch Display plugin because of too less space.
Execute
sudo curl -L https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-calibration.conf-5-0 -o /etc/X11/xorg.conf.d/99-calibration.conf
sudo curl -L https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-fbturbo.conf-HDMI -o /usr/share/X11/xorg.conf.d/99-fbturbo.conf
cat >> /boot/userconfig.txt <<EOL
dtparam=spi=on
config_hdmi_boost=7
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
hdmi_cvt 800 480 60 6 0 0 0
dtoverlay=ads7846
dtparam=cs=1
dtparam=penirq=25
dtparam=penirq_pull=2
dtparam=speed=50000
dtparam=swapxy=0
dtparam=pmax=255
dtparam=xohms=150
dtparam=xmin=200
dtparam=xmax=3900
dtparam=ymin=200
dtparam=ymax=3900
EOL
- Reboot.
