After mistakenly switching on autostart (or autoplay), volumio has been kept in a reboot loop. I’m running volumio 2.917 on a rpi3 B+ .
Is there any solution to fix this? I tried shutting down and restarting but after it boots, the reboot loop continues.
Log file is attached.
tekdru-columio-log.txt (53.7 KB)
Found the solution here:
and here
Used this command to uninstall the autoplay plugin.
rm -r auto_play/
