Hello, I’m using Volumio 3.301 on my RPi3 with Hifiberry DAC 2 HD and Official Touchscreen. Sometimes I’ve got such issues:
playback stuck - time ticking - no sound,
wrong track showing on web and touchscreen,
playback stops… then continues after sometimes without any actions from my side, in such situations I’ve tried to control Volumio via Web or/and Touchscreen - but can’t do it.
I’m using NAS (smb source) as Music Library source. Volumio connected to the same network switch with cable.
Maybe someone can suggest me how to resolve this issues.
PS Generally I’m satisfied with Volumio, thanks for your work
You’re experiencing buffering and stuttering, most likely a network issue - either your Volumio system’s network connection, or the connection to/from your NAS. Or both.
If you’re using wifi, try repositioning. If you connect (as a test) via an ethernet cable, does the problem go away? Sometimes the Pi case, especially metal ones, can reduce your signal.
Edit. Just re-read your post and you are not using wifi. Maybe the network switch?
Sorry, more questions. Did it work ok before? Did you change anything in the system? Do you have another PSU you could try?
Maybe try a basic config without NAS and touchscreen and see if the problem is still there.
Run df -T -h from a command prompt. Is there free space in the overlay?
We are aware of this issue and we are currenty investigating. It impacts qobuz and tidal, when a specific track is selected from an album. When there is news about the ETA of a fix we will let you know.
In the mean time, as a workaround please click on the Play button next to an album to play the whole album, or the big play button on the top of the album. You can navigate to your favorite track using the transport controls.
The issue is related to our hosting infrastructure. It seems some update happened there which causes this issue. We have contacted their support and we hope for a swift solution.
