I’ve been having a bit of trouble getting the touch screen working with Volumio and my Pi 3B+ and Waveshare 7" 1024x600 screen.
After installing the touch plugin, touch still wasn’t working. I’ve had to manually copy the 99-calibration.conf as well as 99-fbturbo.conf to /usr/share/X11/xorg.conf.d. This did get the touch working but on a rotated axis.
Adding a transform to 99-calibration.conf resolver this ( Option “TransformationMatrix” “0 1 0 -1 0 1 0 0 1”)
This leaves me with a working touch screen that is correctly orientated but appears to have a mismatch in resolution.
As the touch approaches the edge of the screen, allignment with the cursor worsens.
I have tried
DISPLAY=:0.0 xinput_calibrator --precalib 200 3900 200 3900
(the x and y values match the config used by Waveshare in the dtoverlay line in /boot/config.txt) but this made no difference.
Does anyone know of any way to check this or what may be causing the issue?
Many thanks
Rad
gvolt
May 7, 2021, 10:33am
2
Please connect to Volumio via SSH and post the output of
cat /boot/config.txt
and
cat /boot/userconfig.txt
Config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
hdmi_drive=1
dtoverlay=ads7846:cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swap-xy=1,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
include userconfig.txt
There is no data in userconfig.txt
Here’s a picture showing the issue
gvolt
May 7, 2021, 11:47am
4
Could you try removing
from /boot/config.txt?
Without that line, the touch does not work.
I tried changing the line to:
dtoverlay=ads7846:cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swap-xy=0
which allows the touch to work but still exhibits the issue.
gvolt
May 7, 2021, 12:26pm
6
I assumed the screen is the Waveshare 7inch HDMI LCD (C) . Is that correct?
I believe it’s the Waveshare 7inch HDMI LCD
gvolt
May 7, 2021, 12:48pm
8
Ok, then you need the overlay…
Did you already try the settings recommended by Waveshare for “99-calibration.conf”? If not substitute the content of “99-calibration.conf” with:
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "Calibration" "73 4007 3976 84"
Option "SwapAxes" "1"
EndSection
These values have been taken from here . You may also try the differing values from the wiki page your link is pointing to.
gvolt
May 7, 2021, 1:30pm
9
One more thing regarding
Because this line exceeds 80 characters it needs to be split like this:
dtoverlay=ads7846
dtparam=cs=1
dtparam=penirq=25
dtparam=penirq_pull=2
dtparam=speed=50000
dtparam=keep_vref_on=0
dtparam=swapxy=1
dtparam=pmax=255
dtparam=xohms=150
dtparam=xmin=200
dtparam=xmax=3900
dtparam=ymin=200
dtparam=ymax=3900
Without that splitting all parameters after “keep_vref_on=0” would be ignored.
BTW: The config.txt recommendation on Waveshare’s GitHub repo shows “swapxy=0”.
I tried the aternative settings in “99-calibration.conf” which had no effect.
I also tried splitting the settings layout as you suggest in /boot/config.txt but this stops the touch working completely.
I had already changed “swapxy” to 0 after changing it to 1 had no effect on switching the axis.
gvolt
May 7, 2021, 2:15pm
11
I think you need to add
dtparam=spi=on
to /boot/config.txt. IIRC it needs to be placed prior to the overlay entry ( “dtoverlay=ads7846…”).
Unfortunately, the touch still doesn’t work with that setting in place and the dtparam on separate lines.
This feels so close to working that I think I must be missing a config file somewhere, or the Touch plugin installed a config with it’s own settings that don’t match the settings I need for the screen.
gvolt
May 7, 2021, 2:41pm
13
Please post the results of
ls -al /usr/share/X11/xorg.conf.d
and
ls -al /etc/X11/xorg.conf.d/
total 40
drwxr-xr-x 2 root root 4096 May 7 09:01 .
drwxr-xr-x 1 root root 4096 May 4 13:29 ..
-rw-r--r-- 1 root root 1350 Nov 11 2016 10-quirks.conf
-rw-r--r-- 1 root root 788 Sep 30 2016 40-libinput.conf
-rw-r--r-- 1 root root 2747 Oct 28 2016 70-wacom.conf
-rwxr-xr-x 1 root root 411 May 7 13:58 99-calibration.conf
-rwxr-xr-x 1 root root 356 May 6 17:20 99-calibration.conf.old
-rw-r--r-- 1 root root 647 May 7 09:01 99-fbturbo.conf
total 28
drwxr-xr-x 2 root root 4096 May 7 14:39 .
drwxr-xr-x 1 root root 4096 May 4 13:33 ..
-rw-r--r-- 1 root root 316 May 7 14:39 95-touch_display-plugin.conf
-rwxr-xr-x 1 root root 477 May 7 14:38 99-calibration.conf
-rwxr-xr-x 1 root root 440 May 6 19:14 99-calibration.conf.save
The contents of 99-fbturbo.conf are:
Section “Device”
Identifier “Allwinner A10/A13 FBDEV”
Driver “fbturbo”
Option “fbdev” “/dev/fb0”
Option "SwapbuffersWait" "true"
EndSection
gvolt
May 7, 2021, 2:49pm
15
What’s the content of “/etc/X11/xorg.conf.d/99-calibration.conf” please?
cat /etc/X11/xorg.conf.d/99-calibration.conf
Section “InputClass”
Identifier “calibration”
MatchProduct “ADS7846 Touchscreen”
Option “MinX” “208”
Option “MaxX” “3905”
Option “MinY” “288”
Option “MaxY” “3910”
Option “SwapAxes” “0”
Option “EmulateThirdButton” “1”
Option “EmulateThirdButtonTimeout” “1000”
Option “EmulateThirdButtonMoveThreshold” “300”
EndSection
gvolt
May 7, 2021, 3:01pm
17
From the information I gather from Waveshare it seems the screens needs evdev. Maybe you need to run
sudo apt-get install xserver-xorg-input-evdev
and after that
sudo cp -rf /usr/share/X11/xorg.conf.d/10-evdev.conf /etc/X11/xorg.conf.d/45-evdev.conf
This has had an effect - the cursor now moves ahead of the touch point instead of trainling behind.
I tried another calibration with
But this didn’t help after placing the new calibration numbers in “/etc/X11/xorg.conf.d/99-calibration.conf” and “/usr/share/X11/xorg.conf.d/99-calibration.conf”
Could the fact the /boot/config.txt dowsn’t work when setting the params on separate lines be an issue? If later params are being ignored when used on a single line (which is the only way I seem to be able to get the touch working) then the x and y values may not be set
gvolt
May 7, 2021, 3:29pm
19
You don’t need to work on both files. The file in “/etc/X11/xorg.conf.d” should overrule the identically named one in “/usr/share/X11/xorg.conf.d”.
Did you try substituting the content of “/etc/X11/xorg.conf.d/99-calibration.conf” with the lines from post #7 ?
IMHO the one line entry would cause that the parameters starting from “swapxy” would not be respected.
You might remove the parameter keep_vref_on=0 as this seems not be valid for the ads7846 overlay (readme ).
How is your “/boot/config.txt” looking now?
Sorry - I’ve been looking at settings but progress seems to have been made.
I’m now pretty close to calibrated on the X axis but still nowhere near on the Y.
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
dtparam=spi=on
dtoverlay=ads7846:cs=1,penirq=25,penirq_pull=2,speed=50000,xohms=150
