Make it shorter text, people stops reading after couple of lines
Btw, i was on the latest RC before updating today, was there supposed to be a reset for me too, or is this only for v2 → v3 transition? (i didnt lose any of my settings or anything)
Am thinking of getting rid of my old trusty Cubox, buying an RPI so I can get V3 and a premium subscription going - but only if the optical output will work flawlessly…
Glad I checked here on signing up for the 15 day trial. I’ll try again later or tomorrow. My first install of v3 took a few tries to get going once installed but I think it is the confusion over the network. I did a clean restart after putting the network info in, and also disconnected my computer from the hotspot and then everything worked as expected.
It works (Allo Boss 1.2, Virtuoso plan). Sound quality occurs to me even better it used to be. Am I right?
One problem though. DSD 256 (11.28 mhz/1 bit playback) does not come right. Sound is cut to pieces. I doubled buffer to 4mb, did not help. I don’t rememeber this would happen with 2.*.
Any ideas?
Just upgraded from Volumio 2 → Volumio 3 from System interface. Everything is fine but, as noted elsewhere it resets to factory defaults so all my settings, favorites and configurations are lost. The plugin for Backup/Restore would have helped but it is not available yet.
Also waiting for the Pandora plugin, hope it becomes available soon.
Finally, I copied my saved music to the Internal Storage folder but it is not available from the Music Library. Did something change? If I connect by ssh I see the mp3 files that I uploaded, but they are in /data/INTERNAL.
Have you tried connecting via the hotspot that the Primo creates on first startup? “Upon first use, Primo will create a network called “Volumio”. Simply connect your device to
it (password: volumio2) and the User Interface will automatically pop up.”
Is there still an investigation going on for this? Are you able to replicate the issue?
It is still happening on version 3.165 (the final Volunio 3 version).
