Correct! 3.165 was in test mode this morning and is promoted to the release. Tinkerboard has 3.167.
Volumio 3 is Live!!!
Everyone happy listening.
Where can I see the differences between my current virtuoso and premium plans? So I can decide if I want to upgradeā¦
It is already available as update. Just make sure you are not in test mode and go in the settings as usual.
Check updates and there youāll find it.
i think the test version of yesterday will block that option 3.165 beta
iām already on the latest version is what it says every timeā¦
Working well here and happy to see that back button finally working!
v3.165 this morning seems to have been an āearly bird pre-release partyā for the alpha and beta testers - nice
I just upgraded to Volumio 3! Everything perfect, I just had to re-scan the library and reinstall the plugins (after logging into MyVolumio).
I also have the impression that the sound is better, but itās probably just a placebo effect! : D
Thank you very much to the whole team, you did a fantastic job!
Only one thing I miss: LastFm plugin! Please give it back! Iām addicted to LastFm scrobbling:
iām still waiting for the Youtube2 plugin of Patrick Kan
No Cd Ripping button on Manifest. New flash from 3.165.
This is known issue and will be addressed in the upcoming days
Okay. Thanks
One suggestion, which I have mentioned before.
Please add time zone as additional part of the first setup.
sudo dpkg-reconfigure tzdata
Autostart should not be rocket science
Enable plugin test mode
will check immediately
Some detected quirks:
The āRun first config Wizardā reloads 3 to 4 times. So halfway entry it stops and reloads
Plugins:
This is a know issue since the beginning of the betas, annoying but not a problem.
I just wait a little after a first boot, hope the devs will find the issue sometime.
Iād also love to have the audiophonicshonoff plugin. Could you manage to get it working somehow?
IMPORTANT!!!
For those of you which are having troubles with payments, our payments provider is currently experiencing some issues.
This issue do not depend on us, and we are actively following the course of events.
For those impacted, donāt worry, any excess payment will be promptly refunded.
What a shame that our payments provider has to have issues right when we launch⦠But, as always, we will take care of any issue
