Thanks Joni! Would you mind sending a pr to fix this?
ill need to clone the repo first.
Is null or empty string better if âthisState.albumartâ happens to be undefined? (im wondering wether there is another place in the codebase which might expect certain kind of value, because it might introduce different kind of bug)
Always a good idea! Especially as itâs still beta and if youâre anything like me you play around with all the bells and whistles breaking things
So I have an issue on my Volumio 3.159. Pi 3 with a HIFIBerry DAC. Using Media Server to access a Synology Diskstation with an attached USB drive via DLNA. Issue: When I try to select a specific track to play, it doesnât work (error attached). But if I play the entire album and then skip to the track I want, it works perfectly fine.
It seems to work again over here since last night. Super happy, now in Multiroom
SOLUCIONADO! Mi problema no era Volumio 3, era el Router.
He encontrado la soluciĂłn a los problemas que tenĂa con Volumio 3: CambiĂ© el router y Ă©ste denegaba el acceso de Volumio. habilitĂ© el acceso y se solucionaron los problemas.
SOLVED! My problem wasnât Volume 3, it was the Router. I have found the solution to the problems I had with Volumio 3: I changed the router and it denied Volumio access. I enabled access and the issues were fixed.
âGo to Artistâ and âGo to Albumâ are still broken on Manifest UI and can lead to wrong artist or album.
Steps to reproduce 100% success rate.
- add songs to queue
- listen all songs(or select last from queue and rewind to very last seconds and wait till it ends)
- refresh the web gui with F5
- you can see your last song info in the âNow playing screenâ
- select Goto artist/album, it takes the info from Queue position 0 and show that.
- bug reproduces.
E: the underlying issue is that the âpositionâ from getState have reset to 0 when the last song of queue did finish, even thought rest of the info in there still shows the last song of the queue, so the data returned by the call is out of sync with itself in this scenario.
I miss the GPIO Buttons plugin for my status LED on my RaspberryPi 3+
If youre OK with SSHing into Volumio and using the command line you can get GPIO-Buttons working fine in volumio 3.
Just follow the post here Install npm module - problem - #9 by Darmur
OK . Have installed with your method. Is also available. Plugin cannot be started
Did you update the node modules like suggested?
Can you please take this to a separate thread or PMs please? (Manual installation of plugins is not relevant to the purpose of the thread)
Still cannot use qobuz. Volumio 2 works great, Volumio 3 just stops playing. This is the third time reporting this issue. Seems strange that I should be the only one with this problem. Playing Pink Floyds Dark side of the moon stops after track 3 every time. 100% reproducable for me!
Just stops playing
Log http://logs.volumio.org/volumio/9nEWOdF.html
Very strange.
I donât have this problem.
I almost only hear Qobuz in the highest possible quality with Allo BOSS and have not been able to determine it.
That doesnât help you any further, I just wanted to share it in order to be able to narrow it down better.
RPI2, RPI3, Allo Boss, HifiBerry Dac+ Pro XLR.
WLAN, LAN
Only that album? Other albums play as expected?
I recently upgraded my account to the new Premium tier and find that Iâm not getting any album info in the beta version, and album and artist story returns âNot Foundâ. Iâm primarily using Qobuz but have the same problem with locally hosted music. Is this a known issue?
No all albums seems to stop at some point. This one is always at the same place. First noticed it with the lady Gaga a star is born soundtrack. I think both that and dsotm are gapless? Could have something to do with it maybe.
I have reflashed Volumio 3 a couple of times. I am on the latest version now. I have a good strong wifi signal to the pie. Really frustrating.
Change the buffer size, cache or whatever itâs called. But ultimately try another card and/or another way of writing the image. If you been using etcher try Raspberry pi imager it has an option to write a custom image.
Also are you using dsp or custom mpd etc⊠Any plugins?
Tried changing buffer size
No plugins
With or without DAC hat enabled
Flashing with RPI imager
Different SD card
Tried updating mpd. I actually had similar problems with Volumio 2 + Tidal where mpd stopped working randomly. I then updated mpd and it worked flawlessly since then.
I must have some unique combination of hardware or network that just makes this thing not working. I kind of suspect mpd problems now again given the similar trouble with Volumio 2 but I hoped that would be resolved with Volumio 3.
When this happens Volumio hangs but can be recovered by restarting mpd or rebooting Volumio. Pretty useless though when I can only hear 3 tracks of one of my favorite albums.
Thanks for the suggestions! I guess I will have to stick with Volumio 2 for the time being.
