This is something you should ask to the plugin developer ![]()
Volumio 3 is already performing better in some ways than v.2 did for me. For example, the artist view is showing images now (it never worked for me in 2.x).
It’s a small thing, but I noticed that none of the radio stations in my “Favorite Radios” view have icons but the same stations have icons in the “Volumio Selections” station view. See “Linn Jazz” in this example:
Shouldn’t the radio station icons be displayed regardless of the page?
3.163, RPi4
But I do not know who upload it.
@marco79cgn
I like very much your Plugin but there are some issues regarding synch between what is displayed and what is heard. Could tou please take a look.
Just chiming in to say thanks to all the people which already upgraded to Premium, this means a lot to us as this is the proof that you’re enjoying what we put lof of sweat and love into.
We did not expect so many people to jump into Premium, even before release!
Thanks!
Can I install manually a plugin?
@volumio
Is not possible to implement album art in already existing 80s80s webradio under volumio?
Any idea why I am missing the meta-data on the local device, this was working fine several builds ago.
Local device:
Remote/http:
Hi @volumio. Here is my report of my problems, I hope that now I am doing well:
I have installed version 3.163 from scratch, assuming that my problems with 3.159 were going to end but no, it is exactly the same as before. This is:
- Despite being logged in, when I want to access the Complements, it requests the Login.
- The Radio Zone does not activate any option.
- Check for Updates is also unresponsive. I paste here the Lg that I just generated, also in volumio.local / dev I have given Send this myself.
I am attaching a photo, in case my explanation has not been very clear.
All the best.
Hola @volumio . Aquí mi reporte de mis problemas, espero que ahora lo esté haciendo bien:
He instalado desde cero la versión 3.163, suponiendo que mis problemas con la 3.159 iban a terminarse pero no, está exactamente igual que antes. Esto es:
- A pesar d estar logeado, cuando quiero acceder la los Complementos m solicita el Login.
- La Zona de Radios no activa ninguna opción.
- Comprobar Actualizaciones tampoco responde. Pego aquí el Lg que acabo de generar, igualmente en volumio.local/dev he dado a Enviar esto mismo.
Adjunto una foto, por si mi explicación no ha sido muy clara.
Un saludo.
Starting Live Log...
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
info: CALLMETHOD: system_controller system setTestSystem true
info: CoreCommandRouter::executeOnPlugin: system , setTestSystem
info: Device is now in test mode
info: CALLMETHOD: system_controller system setTestPlugins true
info: CoreCommandRouter::executeOnPlugin: system , setTestPlugins
info: Plugins store is now in test mode
info: CALLMETHOD: system_controller system enableSSH true
info: CoreCommandRouter::executeOnPlugin: system , enableSSH
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start ssh.service
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl enable ssh.service
Reloading.
/lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
getty@tty1.service: Current command vanished from the unit file, execution of the command list won't be resumed.
Reloading.
Reloading.
info: enable SSH service success
Starting Daily apt download activities...
apt-daily.service: Succeeded.
Started Daily apt download activities.
error resolving pool 2.debian.pool.ntp.org: System error (-11)
info: CALLMETHOD: system_controller system sendBugReport [object Object]
info: CoreCommandRouter::executeOnPlugin: system , sendBugReport
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig
error resolving pool 3.debian.pool.ntp.org: System error (-11)
error resolving pool 0.debian.pool.ntp.org: System error (-11)
[2021/12/02 21:45:39.815855, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.138 for name WORKGROUP<1d>.
This response was from IP 192.168.1.136, reporting an IP address of 192.168.1.136.
[2021/12/02 21:45:39.816180, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.137 for name WORKGROUP<1d>.
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: appearance , getConfigParam
info: Received Get System Version
info: CoreCommandRouter::Close All Modals sent
info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Test mode enabled
No alpha test mode
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl -p 7
error resolving pool 1.debian.pool.ntp.org: System error (-11)
curl_easy_perform() failed: Couldn't resolve host name
terminate called after throwing an instance of 'std::invalid_argument'
what(): parse error - unexpected end of input
volumio-remote-updater.service: Main process exited, code=killed, status=6/ABRT
volumio-remote-updater.service: Failed with result 'signal'.
volumio-remote-updater.service: Service RestartSec=100ms expired, scheduling restart.
volumio-remote-updater.service: Scheduled restart job, restart counter is at 3.
Stopped volumio-remote-updater.service.
Started volumio-remote-updater.service.
Error: No active session
[2021-12-02 21:50:37] [connect] Successful connection
[2021-12-02 21:50:37] [connect] WebSocket Connection 127.0.0.1:3000 v-2 "WebSocket++/0.8.2" /socket.io/?EIO=4&transport=websocket&t=1638481837 101
[2021/12/02 21:50:47.955681, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
[2021/12/02 21:50:47.957375, 0] ../source3/nmbd/nmbd_namequery.c:109(query_name_response)
info: Log sent successfully, reply: Cannot send bug report: Error: Command failed: /usr/bin/curl -X POST -H 'Content-Type: multipart/form-data' -F 'logFile=@/tmp/logondemand' -F desc='He instalado la versión 3.163 y continúo con EXACTAMENTE los mismos problemas que con la versión 3.159:' -F 'variant=volumio' 'http://logs.volumio.org:7171/logs/v1'
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:06 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:07 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:08 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:09 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:10 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:11 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:12 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:13 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:14 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:15 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:16 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:17 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:18 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:19 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:20 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:21 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:22 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:23 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:24 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:25 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:26 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:27 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:28 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:29 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:30 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:31 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:32 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:33 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:34 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:35 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:36 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:37 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:38 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:39 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:40 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:41 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:42 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:43 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:44 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:45 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:46 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:47 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:48 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:49 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:50 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:51 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:52 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:53 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:54 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:55 --:--:-- 0curl: (6) Could not resolve host: logs.volumio.org
Saving as: /var/tmp/logondemand
I reckon I am the most frustrated Volumio user in the world ![]()
To recap, somehow Volumio thinks it is being reconfigured and so keeps stopping the song I am playing and after a little while I get the startup sound and if I hit play it starts the song I was playing from the beginning.
I thought I’d spend some serious time looking at it this evening, so I have changed:
- the sd card
- the networking from wired to wireless
- the raspberry pi (from a 4 to a 3)
- the USB disks with my music on
- the power supply
and it still keeps happening - it makes no sense at all. Two odd things I have noticed is that after initial setup my music on USB isn’t indexed properly (it only recognised a dozen albums instead of the 200 or so on my USB disks - doing a rescan fixes this) and it somehow magically knows that I am a superstar member without me having to authenticate
@volumio Can you please help
Many thanks
Andrew
Yes it is possible.
You can to do by SSH command window.
Once downloaded, un zipped etc. enter the directory and issue the command volumio plugin install
If all goes well, once done it will appear within volumio in the installed plugins section. All you need to do is acivate it.
Example of me trying the rotary plugin (unworking though)
wget http://plugins.volumio.org/plugins/volumio/armhf/user_interface/rotaryencoder/rotaryencoder.zip
mkdir ./rotary
miniunzip rotaryencoder.zip -d ./rotary
cd rotary
Allo Katana still not working on raspberry Pi4
Device: RPI 4 $GB
Version: 3.163
Issue: DSD does not play natively.
I have two DACs (Denafrips Aries II and NAD D3045) and with both of those i cant find a way to play DSD natively.
I have tried various DSD from 64 to 1024 and each time they are being converted to PCM with various resulting rate. Trying to play via DoP doesnt work either.
Dec 03 14:02 : decoder: audio_format=dsd64:2, seekable=true
Dec 03 14:02 : playlist: queue song 10:“NAS/PVE1/DSD/Vexel do minante - DSD Piano instrumental
music - 20210-2019 (Classical, Audiophile, test)/12-Conflict-DSD64.dff”
Dec 03 14:02 : alsa_output: opened volumioOutput type=PLUG
Dec 03 14:02 : alsa_output: buffer: size=90…131072 time=255…371520
Dec 03 14:02 : alsa_output: period: size=45…65536 time=127…185760
Dec 03 14:02 : alsa_output: default period_time = buffer_time/4 = 371519/4 = 92879
Dec 03 14:02 : alsa_output: format=S16_LE (Signed 16 bit Little Endian)
Dec 03 14:02 : alsa_output: buffer_size=131072 period_size=32768
Dec 03 14:02 : output: opened “alsa” (alsa) audio_format=352800:16:2
Dec 03 14:02 : output: converting in=dsd64:2 → f=352800:16:2 → out=352800:16:2
cat /proc/asound/card5/pcm0p/sub0/hw_params rpimusic1: Fri Dec 3 14:10:05 2021
access: MMAP_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 352800 (352800/1)
period_size: 32768
buffer_size: 131072
NAD D3045 supports MQA, but this is being converted to PCM as well.
Thanks I will investigate !
Device? Details? We’re not so good at guessing
RPI 4B w/ RPI 7" display and running Volumio RC1 (3.163). Manifest UI and playing Radio Paradise, no artist data in the RPI, via http all is good. I have re-flashed and updated w/ same behavior.
Sitting on my IOT subnet w/ access to internet and no FW ACLs.
Plugins include Touch Display and Radio Paradise.
Attached via USB to a RME DAC (ADI-2).
Also, a Superstar subscription.
Same w/ local media.
Lastly, this was working fine 2 builds before, 3.152 worked fine.
I’m kinda impressed by how many people listen to the radio stations
@pauljwells thanks for the reply. I do have Superstar and followed your instructions repeatedly with no luck. Then I reflashed both systems and bingo it works. Maybe some older plugin installed in the earlier beta phase was messing things up.
This is more easily reproduced, by adding new items to queue while the selected output device is not attached to Volumio device, this is reproducable with any output device.
Dec 03 16:53:48 passatmediacenter volumio[791]: info: CoreCommandRouter::volumioGetState
Dec 03 16:53:48 passatmediacenter volumio[791]: info: CoreCommandRouter::executeOnPlugin: network , getCachedPAddresses
Dec 03 16:53:48 passatmediacenter volumio[791]: An internal error occurred while serving an albumart. Details: TypeError: Cannot read property 'indexOf' of undefined
Dec 03 16:53:48 passatmediacenter volumio[791]: at ControllerVolumioDiscovery.getThisDevice (/volumio/app/plugins/system_controller/volumiodiscovery/index.js:452:34)
Dec 03 16:53:48 passatmediacenter volumio[791]: at CoreCommandRouter.executeOnPlugin (/volumio/app/index.js:1057:32)
Dec 03 16:53:48 passatmediacenter volumio[791]: at ControllerSystem.getSystemInfo (/volumio/app/plugins/system_controller/system/index.js:431:45)
Dec 03 16:53:48 passatmediacenter volumio[791]: at RESTApiSystem.getSystemInfo (/volumio/app/plugins/user_interface/rest_api/system.js:38:41)
Dec 03 16:53:48 passatmediacenter volumio[791]: at Layer.handle [as handle_request] (/volumio/node_modules/express/lib/router/layer.js:95:5)
Dec 03 16:53:48 passatmediacenter volumio[791]: at next (/volumio/node_modules/express/lib/router/route.js:137:13)
Dec 03 16:53:48 passatmediacenter volumio[791]: at Route.dispatch (/volumio/node_modules/express/lib/router/route.js:112:3)
Dec 03 16:53:48 passatmediacenter volumio[791]: at /volumio/node_modules/express/lib/router/index.js:281:22
Dec 03 16:53:48 passatmediacenter volumio[791]: at Function.process_params (/volumio/node_modules/express/lib/router/index.js:335:12)
Dec 03 16:53:48 passatmediacenter volumio[791]: at next (/volumio/node_modules/express/lib/router/index.js:275:10)
Dec 03 16:53:48 passatmediacenter volumio[791]: at jsonParser (/volumio/node_modules/body-parser/lib/types/json.js:110:7)
Dec 03 16:53:48 passatmediacenter volumio[791]: at trim_prefix (/volumio/node_modules/express/lib/router/index.js:317:13)
Dec 03 16:53:48 passatmediacenter volumio[791]: at /volumio/node_modules/express/lib/router/index.js:284:7
On the line 452 →
albumart: thisState.albumart.indexOf('http://') >= 0 ? thisState.albumart : thisDevice.host + thisState.albumart
Move the string parsing out of the assignment operation with proper checking of undefined value and return empty string or null instead of letting it to crash.
