So I’ve updated to 3.175 and it is repeatedly updating settings. I can’t even finish playing 1 song. This is a pi4 b hooked up (usb) to a Gustard xpro26 DAC. Anyone else experiencing this? Volumio2 worked fine.
I’d be tempted to re-flash the SD card with the latest version. Unfortunately this would require you to redo all your settings. If you have a spare SD this would be worth trying.
You can reproduce the loop with a slow SD card, either by bad flashing (balenaEtcher seems to give most issues), low class or SD is getting EOL.
I was able to reproduce it on the Odroid N2+ and an ancient 4GB SD.
I have the same issue. Just after login with my premium Account it starts a loop updating the configuration in about every 15s.
“Configuration update Player successfully restarted”
Update:
I turned off all Sources (UPNP Renderer, Shairport-Sync, DLNA Browser). Everything works fine, until i log in with my Premium Account. Just after that, the Looping begins. Tested on both Versions 3.179 and 3.165. As described in Volumio 3 issues: hints and solutions I went back to 3.165. Same Issue. The Log is from 3.165.
Update 2:
tail -f /var/log/mpd.log show repeating:
Jan 13 22:15 : zeroconf: No global port, disabling zeroconf
Jan 13 22:15 : client: [0] opened from local
Jan 13 22:15 : exception: No such directory
Jan 13 22:15 : client: [1] opened from local
Jan 13 22:15 : client: [2] opened from local
Jan 13 22:15 : client: [3] opened from local
Jan 13 22:15 : client: [4] opened from local
Jan 13 22:15 : client: [5] opened from local
Jan 13 22:15 : client: [6] opened from local
Jan 13 22:15 : client: [7] opened from local
Jan 13 22:15 : client: [8] opened from local
Jan 13 22:15 : client: [9] opened from local
Jan 13 22:15 : client: [10] opened from local
Jan 13 22:15 : client: [11] opened from local
Jan 13 22:15 : client: [12] opened from local
Jan 13 22:15 : client: [13] opened from local
Jan 13 22:15 : client: [14] opened from local
Jan 13 22:15 : client: [15] opened from local
Jan 13 22:15 : client: [16] opened from local
Jan 13 22:15 : client: [11] closed
Jan 13 22:15 : client: [10] closed
Jan 13 22:15 : client: [16] closed
Jan 13 22:15 : client: [15] closed
Jan 13 22:15 : client: [14] closed
Jan 13 22:15 : client: [13] closed
Jan 13 22:15 : client: [12] closed
Jan 13 22:15 : client: [9] closed
Jan 13 22:15 : client: [8] closed
Jan 13 22:15 : client: [7] closed
Jan 13 22:15 : client: [6] closed
Jan 13 22:15 : client: [5] closed
Jan 13 22:15 : client: [4] closed
Jan 13 22:15 : client: [3] closed
Jan 13 22:15 : client: [2] closed
Jan 13 22:15 : client: [1] closed
Jan 13 22:15 : client: [0] closed
Jan 13 22:16 : zeroconf: No global port, disabling zeroconf
Jan 13 22:16 : client: [0] opened from local
Jan 13 22:16 : exception: No such directory
Jan 13 22:16 : client: [1] opened from local
Jan 13 22:16 : client: [2] opened from local
Jan 13 22:16 : client: [3] opened from local
Jan 13 22:16 : client: [4] opened from local
Jan 13 22:16 : client: [5] opened from local
Jan 13 22:16 : client: [6] opened from local
Jan 13 22:16 : client: [7] opened from local
Jan 13 22:16 : client: [8] opened from local
Jan 13 22:16 : client: [9] opened from local
Jan 13 22:16 : client: [10] opened from local
Jan 13 22:16 : client: [11] opened from local
Jan 13 22:16 : client: [12] opened from local
Jan 13 22:16 : client: [13] opened from local
Jan 13 22:16 : client: [14] opened from local
Jan 13 22:16 : client: [15] opened from local
Jan 13 22:16 : client: [16] opened from local
Jan 13 22:16 : client: [15] closed
Jan 13 22:16 : client: [14] closed
Jan 13 22:16 : client: [13] closed
Jan 13 22:16 : client: [12] closed
Jan 13 22:16 : client: [11] closed
Jan 13 22:16 : client: [10] closed
Jan 13 22:16 : client: [16] closed
Jan 13 22:16 : client: [9] closed
Jan 13 22:16 : client: [8] closed
Jan 13 22:16 : client: [7] closed
Jan 13 22:16 : client: [6] closed
Jan 13 22:16 : client: [5] closed
Jan 13 22:16 : client: [4] closed
Jan 13 22:16 : client: [3] closed
Jan 13 22:16 : client: [2] closed
Jan 13 22:16 : client: [1] closed
Jan 13 22:16 : client: [0] closed
as soon as I set “Activate MyVolumio On Devices” enabled to “off”, the looping stops and Volumio works as expected. When I set to “on”, the looping starts again.
