finally I found a way to reproduce the crucial error that playback is not operating any more. Here is what I did:
- Volumiobuster-3.053-2021-03-06-x86_amd64.img on an x86 PC installed on the internal SSD.
- perform a “factory reset”
- allow “test mode” and “ssh” on the volumio.local/dev page
- login over ssh
- plug in an external HD with the music files
- copy the files to the SSD
cd /data/INTERNAL
cp -R /media/MUSIC/* .
- on the UI start an “update” of the music library (the copy process is still ongoing)
- change the output from SPDIF to HDMI and back
- login to TIDAL
- try to playback something (webradio or TIDAL)
The playback will show the green toasmessage in the upper right corner of the UI
The playback won’t start.
The button in the middle of the control pannes still shows the “START” icon instead of “PAUSE”.
Now the system is in kind of a deadlock.
- UI is working (local and web), Tidal login and TIDAL title search is working.
Change of output is no longer working (no toastmessage “successfully restarted player”)
Playback is not working
Building the local music lib is shown as “in progress” with the rotating arrows but there is no progress in the lib itself.
The MPD has given up (smx systemd[1]: mpd.service: Start operation timed out. Terminating.) - see the last line of the following output:
volumio@smx:/data/INTERNAL$ cat /etc/asound.conf
pcm.!default {
type copy
slave.pcm "volumio"
pcm.volumio {
type copy
slave.pcm "volumioOutput"
# There is always a plug before the hardware to be safe
pcm.volumioOutput {
type plug
slave.pcm "volumioHw"
pcm.volumioHw {
type hw
card "PCH"
device 1
volumio@smx:/data/INTERNAL$ systemctl status mpd.service
● mpd.service - Music Player Daemon
Loaded: loaded (/lib/systemd/system/mpd.service; enabled; vendor preset: enabled)
Active: deactivating (stop-sigterm) (Result: timeout) since Tue 2021-03-09 16:34:31 UTC; 8min ago
Docs: man:mpd(1)
man:mpd.conf(5)
Process: 16387 ExecStartPre=/usr/bin/touch /var/log/mpd.log (code=exited, status=0/SUCCESS)
Process: 16388 ExecStartPre=/bin/chown volumio /var/log/mpd.log (code=exited, status=0/SUCCESS)
Main PID: 16389 (mpd)
Memory: 15.2M
CGroup: /system.slice/mpd.service
└─16389 /usr/bin/mpd --no-daemon
Mar 09 16:40:33 smx systemd[1]: Starting Music Player Daemon...
Mar 09 16:40:34 smx mpd[16389]: Mar 09 16:40 : exception: Decoder plugin 'wildmidi' is unavailable: configuration file does not exist: /etc/timidity/timidity.cfg
Mar 09 16:42:03 smx systemd[1]: mpd.service: Start operation timed out. Terminating.
volumio@smx:/data/INTERNAL$ inxi -Fxxxz
System: Host: smx Kernel: 5.10.20 x86_64 bits: 64 compiler: N/A Console: tty 1 dm: N/A Distro: Debian GNU/Linux 10 (buster)
Machine: Type: Desktop Mobo: ASRock model: J3455-ITX serial: <filter> UEFI: American Megatrends v: P1.40 date: 07/14/2017
CPU: Topology: Quad Core model: Intel Celeron J3455 bits: 64 type: MCP arch: Goldmont rev: 9 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 11980
Speed: 2196 MHz min/max: 800/2300 MHz Core speeds (MHz): 1: 2196 2: 2196 3: 2196 4: 2196
Graphics: Device-1: Intel vendor: ASRock driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5a85
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 181x49
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio: Device-1: Intel Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Audio Cluster vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 00:0e.0 chip ID: 8086:5a98
Sound Server: ALSA v: k5.10.20
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel port: e000
bus ID: 01:00.0 chip ID: 10ec:8168
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.73 TiB used: 681.43 GiB (24.4%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s serial: <filter> rev: 1B6Q
scheme: GPT
ID-2: /dev/sdb type: USB vendor: Western Digital model: WD Elements 25A2 size: 1.82 TiB serial: <filter> rev: 1019
scheme: GPT
Partition: ID-1: / size: 913.00 GiB used: 108.60 GiB (11.9%) fs: overlay source: ERR-102
ID-2: /boot size: 170.8 MiB used: 57.4 MiB (33.6%) fs: vfat dev: /dev/sda1
Sensors: Missing: Required tool sensors not installed. Check --recommends
Info: Processes: 169 Uptime: 57m Memory: 3.70 GiB used: 645.9 MiB (17.0%) Init: systemd v: 241 runlevel: 5 default: 2
Compilers: gcc: N/A Shell: bash v: 5.0.3 running in: tty 1 (SSH) inxi: 3.0.32
volumio@smx:/data/INTERNAL$ lspci -v
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Host Bridge (rev 0b)
Subsystem: ASRock Incorporation Celeron N3350/Pentium N4200/Atom E3900 Series Host Bridge
Flags: bus master, fast devsel, latency 0
00:02.0 VGA compatible controller: Intel Corporation Device 5a85 (rev 0b) (prog-if 00 [VGA controller])
Subsystem: ASRock Incorporation Device 5a85
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at 90000000 (64-bit, non-prefetchable) [size=16M]
Memory at 80000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: i915
Kernel modules: i915
00:0e.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Audio Cluster (rev 0b)
Subsystem: ASRock Incorporation Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
Flags: bus master, fast devsel, latency 0, IRQ 130
Memory at 91310000 (64-bit, non-prefetchable) [size=16K]
Memory at 91000000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
00:0f.0 Communication controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Trusted Execution Engine (rev 0b)
Subsystem: ASRock Incorporation Celeron N3350/Pentium N4200/Atom E3900 Series Trusted Execution Engine
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at 9131b000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:12.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SATA AHCI Controller (rev 0b) (prog-if 01 [AHCI 1.0])
Subsystem: ASRock Incorporation Celeron N3350/Pentium N4200/Atom E3900 Series SATA AHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 125
Memory at 91314000 (32-bit, non-prefetchable) [size=8K]
Memory at 91318000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at 91317000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:13.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #1 (rev fb) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 120
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: 91200000-912fffff
Kernel driver in use: pcieport
00:13.1 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #2 (rev fb) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 121
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:13.2 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #3 (rev fb) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: 91100000-911fffff
00:13.3 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #4 (rev fb) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
00:15.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series USB xHCI (rev 0b) (prog-if 30 [XHCI])
Subsystem: ASRock Incorporation Celeron N3350/Pentium N4200/Atom E3900 Series USB xHCI
Flags: bus master, medium devsel, latency 0, IRQ 124
Memory at 91300000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Low Pin Count Interface (rev 0b)
Subsystem: ASRock Incorporation Celeron N3350/Pentium N4200/Atom E3900 Series Low Pin Count Interface
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.1 SMBus: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SMBus Controller (rev 0b)
Subsystem: ASRock Incorporation Celeron N3350/Pentium N4200/Atom E3900 Series SMBus Controller
Flags: medium devsel, IRQ -2147483648
Memory at 91316000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 11)
Subsystem: ASRock Incorporation Motherboard (one of many)
Flags: bus master, fast devsel, latency 0, IRQ 22
I/O ports at e000 [size=256]
Memory at 91204000 (64-bit, non-prefetchable) [size=4K]
Memory at 91200000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 126
I/O ports at d050 [size=8]
I/O ports at d040 [size=4]
I/O ports at d030 [size=8]
I/O ports at d020 [size=4]
I/O ports at d000 [size=32]
Memory at 91100000 (32-bit, non-prefetchable) [size=512]
Logfile of the mpd ends with:
volumio@smx:/data/INTERNAL$ cat /var/log/mpd.log
Mar 09 16:34 : update: added USB/MUSIK/E/Earth & Fire/Song Of The Marching Children , Atlantis/09 - Fanfare.flac
Mar 09 16:34 : update: added USB/MUSIK/E/Earth & Fire/Song Of The Marching Children , Atlantis/10 - Theme From Atlantis.flac
Mar 09 16:34 : player: played "http://stream.live.vc.bbcmedia.co.uk/bbc_radio_fourfm?s=1615299811&e=1615314211&h=057e7b7618a3d3c22a23bac4ee67f781"
Mar 09 16:34 : update: added USB/MUSIK/E/Earth & Fire/Song Of The Marching Children , Atlantis/11 - Love, Please Close The Door.flac
Mar 09 16:34 : zeroconf: No global port, disabling zeroconf
Mar 09 16:37 : zeroconf: No global port, disabling zeroconf
Mar 09 16:40 : zeroconf: No global port, disabling zeroconf
Mar 09 16:43 : zeroconf: No global port, disabling zeroconf
Mar 09 16:46 : zeroconf: No global port, disabling zeroconf
Mar 09 16:49 : zeroconf: No global port, disabling zeroconf
Mar 09 16:52 : zeroconf: No global port, disabling zeroconf
Mar 09 16:55 : zeroconf: No global port, disabling zeroconf
Mar 09 16:58 : zeroconf: No global port, disabling zeroconf
Mar 09 17:01 : zeroconf: No global port, disabling zeroconf
Mar 09 17:04 : zeroconf: No global port, disabling zeroconf
Mar 09 17:07 : zeroconf: No global port, disabling zeroconf
Mar 09 17:10 : zeroconf: No global port, disabling zeroconf
Mar 09 17:13 : zeroconf: No global port, disabling zeroconf
Mar 09 17:16 : zeroconf: No global port, disabling zeroconf
Mar 09 17:19 : zeroconf: No global port, disabling zeroconf
Mar 09 17:22 : zeroconf: No global port, disabling zeroconf
Mar 09 17:25 : zeroconf: No global port, disabling zeroconf
Link to the logfile: http://logs.volumio.org/volumiobuster/WQhSXhL.html
Hope it helps to solve this issue.
Tell me if you need more information.
Cheers,
Robert
